How can I disable the first run scripts that force you create a new user on a fresh install? And how do I get it to accept simple passwords?
reasons why simple passwords might be a bad idea:
by allowing simple passwords or default passwords active (e.g. 1234 is one of the 'dumbest' you can imagine when it's set permanently).
from armbian.com:
Secure
Images are made fully automatised from sources. Releases are PGP signed and code is regularly inspected by community.
You can do whatever you want to do here: https://github.com/armbian/build/blob/master/config/templates/customize-image.sh.template
but there won't be any official images with disabled/lowered security.
Using customize-image.sh to create an image.  Add to or replace script:
#!/bin/bash
# remove new user prompt
rm /root/.not_logged_in_yet
# change to weak password
echo "root:qwerty" | chpasswd
If you are trying to do this from official images.  After writing image to sdcard, mount, chroot, and run above.  Or mount, remove .not_logged_in_yet, and manually create new password by using mkpasswd and insert into /etc/shadow.  For more info, check man pages for shadow, mkpasswd.
Edit: For official images; mount sdcard, create /boot/armbian_first_run.txt and copy code into the file.  It should exec them on first run.
Edited by lrrr
Additional info
