vivekpk Posted April 23, 2019 Share Posted April 23, 2019 yes, i am using i2c and gpio along with the spi Link to comment Share on other sites More sharing options...
vivekpk Posted April 23, 2019 Share Posted April 23, 2019 19 minutes ago, martinayotte said: It depends : are you using those ? Simply edit again /boot/armbianEnv.txt and add "param_spidev_spi_bus=0" or "param_spidev_spi_bus=1" depending which bus you want to activate... and then reboot ... thanks, will check with this and let you know the result Link to comment Share on other sites More sharing options...
vivekpk Posted April 25, 2019 Share Posted April 25, 2019 On 4/23/2019 at 9:40 PM, martinayotte said: It depends : are you using those ? Simply edit again /boot/armbianEnv.txt and add "param_spidev_spi_bus=0" or "param_spidev_spi_bus=1" depending which bus you want to activate... and then reboot ... Thanks It worked Link to comment Share on other sites More sharing options...
