How to enable Permanent hdparm setting in Jessie?
nemonein
Hi.
I'm using CubieTruck with Armbian Jessie, attached with a Sata disk.
I have tried these method to run hdparm when the system reboots, but none of them was successful.
  • /etc/hdparm.conf
  • /etc/udev/rules.d/50-hdparm.rules
  • /usr/lib/systemd/system-sleep/hdparm_set
Finally, I chose the /etc/rc.local file, and add the hdparm command.
hdparm -B 127 -S 242 /dev/sda
However, it is not working always.
I rebooted several times, and check the APM status with 'hdparm -B /dev/sda', the results vary.
Sometimes it shows APM_level = not supported, but some other times APM_level = 127, as I specified.
I don't know what was wrong about the command.
 ** I've found out that hddtemp(which is used everytime I log on to Armbian, by /etc/update-motd.d/30-sysinfo) 'sometimes' resets the apm level.
Beside the other methods, I want to know why /etc/hdparm.conf does not work.
I added these lines in hdparm.conf.
/dev/disk/by-id/ata-SAMSUNG_HD103SJ_S246J1RZB00034 {
apm = 127
spindown_time = 242
However, it does not work at all.
Can anyone give a clue?
Hi,
I had the same problem, tryed everything but the disk "keeps forgetting" apm params.
The only solution (=patch) I could find is setting a cron job to re-record params every 10 minutes
#!/bin/bash
#hdparm -S starts disk, send only if already spinned up
if /sbin/hdparm -C /dev/diskX | grep "active" > /dev/null; then
 /sbin/hdparm -S120 /dev/diskX
 touch /tmp/disksaving
fi
if /sbin/hdparm -C /dev/diskX | grep "standby" > /dev/null; then
fi
/sbin/hdparm -B255 /dev/diskX
touch /tmp/disksaving is a quick&dirty way to check last run
