spot62 0 Posted August 7, 2018 Share Posted August 7, 2018 Hi, After running nand-sata-install at the step "eMMC install: Formating /dev/mmcblk1 to ext4 ... please wait:" mount: wrong fs type, bad option, bad superblock on /dev/mmcblk1p1, missing codepage or helper program, or other error In some cases useful info is found in syslog - try dmesg | tail or so. dmesg: [ 72.516530] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value [ 73.928286] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value [ 74.238966] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value [ 74.822857] +mmc_blk_issue_discard_rq,1809 [ 74.822921] mmc2:mmc_do_erase: erase from 8192 to 40959 arg 0x00000003 [ 74.839657] -mmc_blk_issue_discard_rq,1845 [ 74.839923] +mmc_blk_issue_discard_rq,1809 [ 74.839975] mmc2:mmc_do_erase: erase from 40960 to 4235263 arg 0x00000003 [ 75.908687] -mmc_blk_issue_discard_rq,1845 [ 75.908733] +mmc_blk_issue_discard_rq,1809 [ 75.908749] mmc2:mmc_do_erase: erase from 4235264 to 8429567 arg 0x00000003 [ 77.046410] -mmc_blk_issue_discard_rq,1845 [ 77.046454] +mmc_blk_issue_discard_rq,1809 [ 77.046472] mmc2:mmc_do_erase: erase from 8429568 to 12623871 arg 0x00000003 [ 78.106266] -mmc_blk_issue_discard_rq,1845 [ 78.106311] +mmc_blk_issue_discard_rq,1809 [ 78.106329] mmc2:mmc_do_erase: erase from 12623872 to 15117183 arg 0x00000003 [ 78.738142] -mmc_blk_issue_discard_rq,1845 [ 82.851026] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value [ 82.957791] EXT4-fs (mmcblk1p1): Unrecognized mount option "compress-force=zlib" or missing value and my NanoPi Neo Air could not boot from eMMC Help me, please. Thank you. Link to post Share on other sites
spot62 0 Posted August 8, 2018 Author Share Posted August 8, 2018 after removing the mount options "-o compress-force=zlib" from nand-sata-install script the warnings is disappeared, the current rootfs was copied to mmcblk1p1 (i see by mount), but my NanoPi Neo Air could not boot from eMMC U-Boot SPL 2018.05-armbian (Aug 08 2018 - 07:11:15 +0000) DRAM: 512 MiB Trying to boot from MMC2 MMC Device 1 not found spl: could not find mmc device. error: -19 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### What's wrong? Link to post Share on other sites
spot62 0 Posted August 8, 2018 Author Share Posted August 8, 2018 wrong u-boot options, solved. Link to post Share on other sites
