Hi,
After running nand-sata-install at the step
"eMMC install: Formating /dev/mmcblk1 to ext4 ... please wait:"
mount: wrong fs type, bad option, bad superblock on /dev/mmcblk1p1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
dmesg:
[   72.516530] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value
[   73.928286] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value
[   74.238966] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value
[   74.822857] +mmc_blk_issue_discard_rq,1809
[   74.822921] mmc2:mmc_do_erase: erase from 8192 to 40959 arg 0x00000003
[   74.839657] -mmc_blk_issue_discard_rq,1845
[   74.839923] +mmc_blk_issue_discard_rq,1809
[   74.839975] mmc2:mmc_do_erase: erase from 40960 to 4235263 arg 0x00000003
[   75.908687] -mmc_blk_issue_discard_rq,1845
[   75.908733] +mmc_blk_issue_discard_rq,1809
[   75.908749] mmc2:mmc_do_erase: erase from 4235264 to 8429567 arg 0x00000003
[   77.046410] -mmc_blk_issue_discard_rq,1845
[   77.046454] +mmc_blk_issue_discard_rq,1809
[   77.046472] mmc2:mmc_do_erase: erase from 8429568 to 12623871 arg 0x00000003
[   78.106266] -mmc_blk_issue_discard_rq,1845
[   78.106311] +mmc_blk_issue_discard_rq,1809
[   78.106329] mmc2:mmc_do_erase: erase from 12623872 to 15117183 arg 0x00000003
[   78.738142] -mmc_blk_issue_discard_rq,1845
[   82.851026] EXT4-fs (mmcblk1p1): Unrecognized mount option "flush" or missing value
[   82.957791] EXT4-fs (mmcblk1p1): Unrecognized mount option "compress-force=zlib" or missing value
and my NanoPi Neo Air could not boot from eMMC
Help me, please. Thank you.
after removing the mount options "-o compress-force=zlib" from nand-sata-install script the warnings is disappeared, the current rootfs was copied to mmcblk1p1 (i see by mount), but my NanoPi Neo Air could not boot from eMMC
U-Boot SPL 2018.05-armbian (Aug 08 2018 - 07:11:15 +0000)
DRAM: 512 MiB
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device. error: -19
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
What's wrong?
