try
sudo h3disp -m 5 -d
and reboot
If you get a clear display, you can set the display area to 800x480 later by modifying the script.bin file.
[disp_init]
disp_init_enable = 1
disp_mode = 0
screen0_output_type = 3
screen0_output_mode = 5
screen1_output_type = 3
screen1_output_mode = 5
fb0_format = 0
fb0_width = 800
fb0_height = 480
fb1_format = 0
fb1_width = 0
fb1_height = 0
hdcp_enable = 1
6 hours ago, nopnop2002 said:
try
sudo h3disp -m 5 -d
and reboot
[disp_init]
disp_mode = 0
fb0_format = 0
fb0_width = 800
fb0_height = 480
fb1_format = 0
fb1_width = 0
fb1_height = 0
hdcp_enable = 1
also in latest image of armbian i founded that you can change resolution of display. no need to set it with h3disp.
