jock Posted August 23, 2018 Posted August 23, 2018 Since kernel 4.18, on my rk3288 tv-box USB devices have always had problems when plugged in after the box boot (ie: USB device not working at all) I found that the problem is described and solved by this patch: https://patchwork.kernel.org/patch/10535905/ Applying it to latest 4.18.4 kernel the functionality is restored, and I can't see similar patches in rockchip-dev. I think it should be applied to all rockchip SoCs at least until it gets merged into mainline
TonyMac32 Posted August 23, 2018 Posted August 23, 2018 I am working on restoring the vendor kernel for rk3288, if you could, a pull request would be greatly appreciated
jock Posted August 24, 2018 Author Posted August 24, 2018 Pull request opened: <https://github.com/armbian/build/pull/1090> It's my first time, I hope I did not make any mistake
