jock Posted August 23, 2018 Share Posted August 23, 2018 Since kernel 4.18, on my rk3288 tv-box USB devices have always had problems when plugged in after the box boot (ie: USB device not working at all) I found that the problem is described and solved by this patch: https://patchwork.kernel.org/patch/10535905/ Applying it to latest 4.18.4 kernel the functionality is restored, and I can't see similar patches in rockchip-dev. I think it should be applied to all rockchip SoCs at least until it gets merged into mainline Link to comment Share on other sites More sharing options...
TonyMac32 Posted August 23, 2018 Share Posted August 23, 2018 I am working on restoring the vendor kernel for rk3288, if you could, a pull request would be greatly appreciated Link to comment Share on other sites More sharing options...
jock Posted August 24, 2018 Author Share Posted August 24, 2018 Pull request opened: <https://github.com/armbian/build/pull/1090> It's my first time, I hope I did not make any mistake Link to comment Share on other sites More sharing options...
