Slawek Posted August 23, 2018 Share Posted August 23, 2018 Hi, I'm trying to use the popular LTE USB modem Huawei E3372s (Stick mode) with NanoPi Duo. Modem is in Network card mode - USB_Modeswitch was installed and started root@nanopiduo:~# lsusb Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 002: ID 0525:a4a7 Netchip Technology, Inc. Linux-USB Serial Gadget (CDC ACM mode) Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 003: ID 12d1:1506 Huawei Technologies Co., Ltd. Modem/Networkcard Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub WVDial is installed and configured: /etc/wvdial.conf [Dialer Orange] Modem = /dev/ttyUSB1 Init3 = AT+CGDCONT=1,"IP","internet" Username = "internet" Password = "internet" Phone = "*99#" Dial Command = ATDTW Stupid Mode = yes Dial Attempts = 0 the connection to my provider is going fine: root@nanopiduo:~# wvdial orange& [1] 2752 root@nanopiduo:~# --> WvDial: Internet dialer version 1.61 --> Initializing modem. --> Sending: ATZ ATZ OK --> Sending: ATQ0 V1 E1 S0=0 ATQ0 V1 E1 S0=0 OK --> Sending: AT+CGDCONT=1,"IP","internet" AT+CGDCONT=1,"IP","internet" OK --> Modem initialized. --> Sending: ATDTW*99# --> Waiting for carrier. ATDTW*99# CONNECT --> Carrier detected. Starting PPP immediately. --> Starting pppd at Mon Jan 29 06:38:27 2018 --> Pid of pppd: 2753 --> Using interface ppp0 --> local IP address 10.89.114.208 --> remote IP address 10.64.64.64 --> primary DNS address 194.204.159.1 --> secondary DNS address 194.204.152.34 root@nanopiduo:~# ifconfig eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether b2:9b:24:4e:11:e2 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 35 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 64 bytes 5184 (5.0 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 64 bytes 5184 (5.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 ppp0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500 inet 10.93.28.221 netmask 255.255.255.255 destination 10.64.64.64 ppp txqueuelen 3 (Point-to-Point Protocol) RX packets 7 bytes 106 (106.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 8 bytes 157 (157.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500 ether 12:42:33:5d:22:81 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 but I can't ping nothing on the Internet: root@nanopiduo:~# ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. ^C --- 8.8.8.8 ping statistics --- 8 packets transmitted, 0 received, 100% packet loss, time 7254ms The modem (E3372s) with RPi 3 and latest Raspbian works perfectly. Also plugged into my Windows 10 PC works OK. Nano Pi Duo is powered from good 3A 5V power source and USB socket for Huawei 3371s is separately powered from this same source (not via pins on Nano Pi Duo). checked with: Armbian_5.38_Nanopiduo_Debian_stretch_next_4.14.15, Armbian_5.38_Nanopiduo_Ubuntu_xenial_next_4.14.15.img and also with nanopi-duo_friendlycore-xenial_4.14.52_20180628.img. If you have any idea what should I check any suggestions will be very appreciated. Slawek Link to comment Share on other sites More sharing options...
@lex Posted August 23, 2018 Share Posted August 23, 2018 route can reveal something, post the result of route from duo and from rpi. Link to comment Share on other sites More sharing options...
Slawek Posted August 24, 2018 Author Share Posted August 24, 2018 Thanks for your suggestion. Here are results: NanoPi Duo (Armbian_5.38_Nanopiduo_Debian_stretch_next_4.14.15.img) before connection: root@nanopiduo:~# route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 0.0.0.0 0.0.0.0 U 1002 0 0 eth0 link-local 0.0.0.0 255.255.0.0 U 0 0 0 eth0 root@nanopiduo:~# ip route default dev eth0 scope link metric 1002 linkdown 169.254.0.0/16 dev eth0 proto kernel scope link src 169.254.11.58 linkdown after connection: CONNECT --> Carrier detected. Starting PPP immediately. --> Starting pppd at Thu Aug 23 18:52:19 2018 --> Pid of pppd: 1099 --> Using interface ppp0 --> local IP address 10.91.179.3 --> remote IP address 10.64.64.64 --> primary DNS address 194.204.159.1 --> secondary DNS address 194.204.152.34 root@nanopiduo:~# route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 0.0.0.0 0.0.0.0 U 1002 0 0 eth0 10.64.64.64 0.0.0.0 255.255.255.255 UH 0 0 0 ppp0 link-local 0.0.0.0 255.255.0.0 U 0 0 0 eth0 root@nanopiduo:~# root@nanopiduo:~# ip route default dev eth0 scope link metric 1002 linkdown 10.64.64.64 dev ppp0 proto kernel scope link src 10.95.40.137 169.254.0.0/16 dev eth0 proto kernel scope link src 169.254.11.58 linkdown results of ping: root@nanopiduo:~# ping 8.8.8.8 PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. From 169.254.10.53 icmp_seq=1 Destination Host Unreachable From 169.254.10.53 icmp_seq=2 Destination Host Unreachable From 169.254.10.53 icmp_seq=3 Destination Host Unreachable ^C --- 8.8.8.8 ping statistics --- 6 packets transmitted, 0 received, +3 errors, 100% packet loss, time 5193ms pipe 4 root@nanopiduo:~# ping -I ppp0 8.8.8.8 PING 8.8.8.8 (8.8.8.8) from 10.91.179.3 ppp0: 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=2 ttl=118 time=639 ms 64 bytes from 8.8.8.8: icmp_seq=3 ttl=118 time=1108 ms 64 bytes from 8.8.8.8: icmp_seq=4 ttl=118 time=225 ms ^C --- 8.8.8.8 ping statistics --- 11 packets transmitted, 3 received, 72% packet loss, time 10434ms rtt min/avg/max/mdev = 225.175/657.813/1108.846/360.991 ms, pipe 2 RPi 3 (2018-06-27-raspbian-stretch-lite.img) Before connection route table is empty. After connection: root@nanopiduo:~# route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 0.0.0.0 0.0.0.0 U 0 0 0 ppp0 10.64.64.64 0.0.0.0 255.255.255.255 UH 0 0 0 ppp0 root@nanopiduo:~# ip route default dev ppp0 scope link 10.64.64.64 dev ppp0 proto kernel scope link src 10.90.159.69 and ping is working nice and smooth: PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data. 64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=134 ms 64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=45.7 ms 64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=40.4 ms 64 bytes from 8.8.8.8: icmp_seq=4 ttl=117 time=43.8 ms 64 bytes from 8.8.8.8: icmp_seq=5 ttl=117 time=43.8 ms --- 8.8.8.8 ping statistics --- 5 packets transmitted, 5 received, 0% packet loss, time 4008ms rtt min/avg/max/mdev = 40.454/61.783/134.997/36.647 ms Seams that on Armbian the default and link-local are bind to eth0 but on RPi to ppp0. Could be the source of my problems? Both installations are super fresh - just images flashed to SD on NPi USB_Modeswitch installed (o raspbian is included in distro) plus on both on RPi wvdial installed and configured. Nothing else. Link to comment Share on other sites More sharing options...
@lex Posted August 25, 2018 Share Posted August 25, 2018 16 hours ago, Slawek said: Could be the source of my problems? Yes. Try to add a gw to ppp0, something like: route add default gw {IP-ADDRESS} {INTERFACE-NAME} Not sure is the best way ( i am not sysadmin), it should be automagically done by some package. route add default gw 10.64.64.64 ppp0 Link to comment Share on other sites More sharing options...
Slawek Posted August 25, 2018 Author Share Posted August 25, 2018 Hi @lex, many thanks for you effort. Finally I have it working.... but it was made .... automagically by installing new Armbian from this Tuesday 21'th (Armbian_5.59_Nanopiduo_Ubuntu_bionic_next_4.14.65.img or Armbian_5.59_Nanopiduo_Debian_stretch_next_4.14.65.img - both are working perfectly) The routing table is set after connection exactly this same as it was in Raspbian on my RPi3. I don't know what was the source of problems but now is working OK, so we can close the topic. BTW: there was no success with manual altering of route table on previous Armbian tested. Link to comment Share on other sites More sharing options...
