Hi, I tried to add the mcp251x overlay for Nanopi-NEO-Plus2 (Allwinner H5) using armbian-add-overlay command but got the error below. Does anybody know why? Below, you can find the dts file. Any help would be appreciated.
Compiling the overlay
dtc: livetree.c:521: get_node_by_phandle: Assertion `(phandle != 0) && (phandle != -1)' failed.
/usr/sbin/armbian-add-overlay: line 76:  2078 Aborted  dtc -@ -q -I dts -O dtb -o ${temp_dir}/${fname}.dtbo $1
Error compiling the overlay
spi-mcp251x.dts
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5";
        fragment@0 {
                target-path = "/clocks";
                __overlay__ {
                        #address-cells = <1>;
                        #size-cells = <1>;
                        can0_osc_fixed: can0_osc_fixed {
                                compatible = "fixed-clock";
                                #clock-cells = <0>;
                                clock-frequency  = <8000000>;
        fragment@1 {
                target = <&pio>;
                __overlay__ {
                        can0_pin_irq: can0_pin_irq {
                                pins = "PA7";
                                function = "irq";
                                bias-pull-up;
        fragment@2 {
                target = <&spi1>;
                __overlay__ {
                        #size-cells = <0>;
                        status = "okay";
                        mcp2515 {
                                reg = <0>;
                                compatible = "microchip,mcp2515";
                                pinctrl-names = "default";
                                pinctrl-0 = <&can0_pin_irq>;
                                spi-max-frequency = <10000000>;
                                interrupt-parent = <&pio>;
                                interrupts = <0 7 2>; /* PA7 IRQ_TYPE_EDGE_FALLING */
                                clocks = <&can0_osc_fixed>;
                                status = "okay";
