Could anybody confirm building Bananapim2 jessie next exits after compiling u-boot around line 142-146 in common.sh?
wc: ... /output/debs/linux-u-boot-next-bananapim2_5.05_armhf.deb: no such file or directory
The debs directory is empty. (I didn't check for hidden files.)
I had Jessie Next fail while building Uboot just now, but that was for orangepih3.
I'm in the process of cleaning out the directory tree and starting again from scratch in case there is anything left over from the BPI M1+ builds that I have been doing recently
Already up-to-date.
M       debootstrap.sh
Already on 'master'
Your branch is up-to-date with 'origin/master'.
[ o.k. ] Command line: setting BUILD_DESKTOP to [ no ]
[ o.k. ] Command line: setting RELEASE to [ jessie ]
[ o.k. ] Command line: setting BRANCH to [ next ]
[ o.k. ] Command line: setting PROGRESS_DISPLAY to [ plain ]
[ o.k. ] Command line: setting PROGESS_LOG_TO_FILE to [ yes ]
[ o.k. ] Command line: setting BOARD to [ orangepih3 ]
[ o.k. ] Command line: setting COMPRESS_OUTPUTIMAGE to [ no ]
[ o.k. ] Command line: setting DEST_LANG to [ en_GB.UTF-8 ]
[ o.k. ] Command line: setting EXTENDED_DEBOOTSTRAP to [ yes ]
[ o.k. ] Command line: setting APT_PROXY_ADDR to [ nas-1.local:3142 ]
[ o.k. ] Preparing [ host ]
[ o.k. ] Using user configuration override [ userpatches/lib.config ]
[ o.k. ] Starting Armbian build script [ @host ]
[ o.k. ] Building [ Armbian 5.05 Orangepih3 Debian jessie next ]
[ o.k. ] Syncing clock [ host ]
[ o.k. ] source downloading [ @host ]
[ o.k. ] ... creating a shallow clone [ u-boot v2016.03-rc2 ]
Cloning into '/home/nick/hg/p158-linux-images/sources/u-boot/v2016.03-rc2'...
remote: Counting objects: 12306, done.
remote: Compressing objects: 100% (11140/11140), done.
remote: Total 12306 (delta 2197), reused 4257 (delta 941)
Receiving objects: 100% (12306/12306), 15.53 MiB | 5.00 KiB/s, done.
Resolving deltas: 100% (2197/2197), done.
Checking connectivity... done.
[ o.k. ] ... updating [ linux-vanilla ]
[ o.k. ] ... updating [ sunxi-tools ]
[ o.k. ] ... updating [ rt8192cu ]
[ o.k. ] ... updating [ sunxi-display-changer ]
[ o.k. ] ... updating [ mt7601 ]
[ o.k. ] Compiling sunxi tools [ @host & target ]
[ o.k. ] Cleaning [ /home/nick/hg/p158-linux-images/sources/u-boot/v2016.03-rc2 ]
[ o.k. ] Cleaning [ /home/nick/hg/p158-linux-images/sources/linux-vanilla/v4.4.5 ]
[ o.k. ] Cleaning [ /home/nick/hg/p158-linux-images/output/debs ]
[ o.k. ] Started patching process for [ kernel sunxi-next 4.4.5 ]
[ o.k. ] Looking for user patches in [ userpatches/kernel/sunxi-next ]
[ o.k. ] ... 0010-bananapi_m1_plus_dts.patch [ succeeded ]
[ o.k. ] ... 0012-bananapi_r1_dts.patch [ succeeded ]
[ o.k. ] ... 0013-lamobo_r1_dts.patch [ succeeded ]
[ o.k. ] ... 14-bpi-spi.patch [ succeeded ]
[ o.k. ] ... 15-bpi-disable-uart.patch [ succeeded ]
[ o.k. ] ... OrangePI-01-h3-2733b9fa0ad18f1deb240d8d1ea92957d7f2270d.patch [ succeeded ]
[ o.k. ] ... OrangePI-02-h3-3bff045590a3dd40341398b4ba15859fb9f7001e.patch [ succeeded ]
[ o.k. ] ... OrangePI-03-h3-08c956b56c98e500ac79ac4957025c2c05460fad.patch [ succeeded ]
[ o.k. ] ... OrangePI-04-h3-e49065f413b616b6c2fa794e20510f821361f08d.patch [ succeeded ]
[ o.k. ] ... OrangePI-05-h3-1832b6cde1381ac783d5921c2c916bf1423aa60f.patch [ succeeded ]
[ o.k. ] ... OrangePI-06-h3-4e776aacfc9f723783806246cea618f413db55e3.patch [ succeeded ]
[ o.k. ] ... OrangePI-07-h3-c54e26726f75e388d39aa80e604774b0ea6d5a2f.patch [ succeeded ]
[ o.k. ] ... OrangePI-08-h3-fe78c12c1a4f4f271d0cc8b2f5eb341c95f40c66.patch [ succeeded ]
[ o.k. ] ... OrangePI-09-h3-cca1f932be385e576d975836895188fa55c52945.patch [ succeeded ]
[ o.k. ] ... OrangePI-10-h3-3bde21d14f6521dc237a952ae2f6d3dea982f786.patch [ succeeded ]
[ o.k. ] ... OrangePI-11-h3-303ed9315574a4764eba097b5c2fe00cd5a90e8f.patch [ succeeded ]
[ o.k. ] ... OrangePI-12-h3-5b030647d83ab4680901d42cb115d9dc95b22440.patch [ succeeded ]
[ o.k. ] ... OrangePI-13-h3-f31f74a2c3070ba35e9eea03f7afda86d3e715ee.patch [ succeeded ]
[ o.k. ] ... OrangePI-14-h3-42bbc4bb30ac2e1abaf34357d6e122d8881d6d17.patch [ succeeded ]
[ o.k. ] ... axp20x-sysfs-interface.patch [ succeeded ]
[ o.k. ] ... bananapi-codec.patch [ succeeded ]
[ o.k. ] ... bananapi-r1-switch-driver.patch [ succeeded ]
[ o.k. ] ... bananapipro-wifi-codec-led-fix.patch [ succeeded ]
[ o.k. ] ... brcmfmac_ap_banana_ct.patch [ succeeded ]
[ o.k. ] ... cubieboard_enable_mmc0_trigger_to_green_LED.patch [ succeeded ]
[ o.k. ] ... cubietruck_enable_mmc0_trigger_to_green_LED.patch [ succeeded ]
[ o.k. ] ... headers-packing.patch [ succeeded ]
[ o.k. ] ... orangepi-mini-codec.patch [ succeeded ]
[ o.k. ] ... packaging-next.patch [ succeeded ]
[ o.k. ] ... pcDuino3-nano-codec.patch [ succeeded ]
[ o.k. ] ... spi_allow_transfer_larger.patch [ succeeded ]
[ o.k. ] ... sunxi-audio-capture-allin1.patch [ succeeded ]
[ o.k. ] ... support_for_second_mmc_cubieboard2.patch [ succeeded ]
[ o.k. ] Started patching process for [ u-boot u-boot-next 2016.03-rc2 ]
[ o.k. ] Looking for user patches in [ userpatches/u-boot/u-boot-next ]
[ o.k. ] ... add-awsom-uboot.patch [ succeeded ]
[ o.k. ] ... add-cubieboard4.patch [ succeeded ]
[ warn ] ... bananapi-enable-ldo4.patch [ failed ]
[ o.k. ] ... u-boot-02-support-cheap-mmc.patch [ succeeded ]
[ o.k. ] Compiling uboot. Please wait. [ 2016.03-rc2 ]
scripts/kconfig/conf  --silentoldconfig Kconfig
*** Configuration file ".config" not found!
*** Please run some configurator (e.g. "make oldconfig" or
*** "make menuconfig" or "make xconfig").
make[2]: *** [silentoldconfig] Error 1
make[1]: *** [silentoldconfig] Error 2
make: *** No rule to make target `include/config/auto.conf', needed by `include/config/uboot.release'. Stop.
[ o.k. ] Target directory [ /home/nick/hg/p158-linux-images/output/debs/ ]
[ o.k. ] Building deb [ linux-u-boot-next-orangepih3_5.05_armhf.deb ]
[ error ] ERROR in function compile_uboot [ common.sh:146 ]
[ error ] Building u-boot failed, check configuration
[ o.k. ] Process terminated
Thanks for your reply. My log looks a bit different.
[snip]
[[0;32m o.k. [0m] Compiling uboot. Please wait. [[0;33m 2016.01 [0m]
  CHK     include/config.h
  GEN     include/autoconf.mk
  GEN     include/autoconf.mk.dep
[snip]
  CC      spl/lib/strto.o
  LD      spl/lib/built-in.o
  LD      spl/u-boot-spl
  OBJCOPY spl/u-boot-spl.bin
  MKSUNXI spl/sunxi-spl.bin
  CAT     u-boot-sunxi-with-spl.bin
[[0;32m o.k. [0m] Target directory [[0;33m /home/pibuilder/m2-armbian/output/debs/ [0m]
[[0;32m o.k. [0m] Building deb [[0;33m linux-u-boot-next-bananapim2_5.05_armhf.deb [0m]
wc: /home/pibuilder/m2-armbian/output/debs/linux-u-boot-next-bananapim2_5.05_armhf.deb: No such file or directory
rm: cannot remove '/home/pibuilder/m2-armbian/output/debs/linux-u-boot-next-bananapim2_5.05_armhf.deb': No such file or directory
[[0;31m error [0m] ERROR in function compile_uboot [[0;33m common.sh:146 [0m]
[[0;31m error [0m] Building u-boot failed, check configuration
[[0;32m o.k. [0m] Process terminated
Interesting that there are 2 different issues, sadly I don't know enough about uboot or the build process to look at this at least not tonight.
I have just tried building BPI Pro and that seems to have built fine so it would appear to be board / SoC specific.
Hopefully one of the devs will be along soon to help out :-)
New Line 37:
make $CTHREADS $BOOTCONFIG CROSS_COMPILE=arm-linux-gnueabihf-
Output for Armbian:
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
*** Can't find default configuration "arch/../configs/orangepi_h3_defconfig"!
make[1]: *** [orangepi_h3_defconfig] Error 1
make: *** [orangepi_h3_defconfig] Error 2
mv: cannot move ‘output/images/Armbian_5.05_Bananapipro_Debian_jessie_4.4.5.raw’ to ‘./Armbian_5.05_Bananapipro_Debian_jessie_4.4.5.raw’: Permission denied
New line 37 and 138.
# configuration written to .config
  GEN     spl/include/autoconf.mk
  CHK     include/config/uboot.release
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  CFG     u-boot.cfg
  CHK     include/generated/version_autogenerated.h
  CC      lib/asm-offsets.s
  CC      arch/arm/lib/asm-offsets.s
  CHK     include/generated/asm-offsets.h
  CHK     include/generated/generic-asm-offsets.h
  HOSTCC  tools/gen_eth_addr
  HOSTCC  tools/bmp_logo
  HOSTCC  tools/img2srec
  HOSTCC  tools/mkenvimage.o
  HOSTCC  tools/os_support.o
  WRAP    tools/lib/crc32.c
  HOSTCC  tools/aisimage.o
  LDS     u-boot.lds
  HOSTCC  tools/atmelimage.o
  WRAP    tools/common/bootm.c
  HOSTCC  tools/default_image.o
  WRAP    tools/lib/fdtdec_common.c
  WRAP    tools/lib/fdtdec.c
  HOSTCC  tools/fit_common.o
  HOSTCC  tools/fit_image.o
  HOSTCC  tools/gpimage.o
  HOSTCC  tools/gpimage-common.o
  WRAP    tools/common/image-fit.c
  HOSTCC  tools/image-host.o
  WRAP    tools/common/image.c
  HOSTCC  tools/imagetool.o
  HOSTCC  tools/imximage.o
  HOSTCC  tools/kwbimage.o
  WRAP    tools/lib/md5.c
  HOSTCC  tools/lpc32xximage.o
  HOSTCC  tools/mxsimage.o
  HOSTCC  tools/omapimage.o
  HOSTCC  tools/pblimage.o
  HOSTCC  tools/pbl_crc32.o
  WRAP    tools/lib/rc4.c
  HOSTCC  tools/rkcommon.o
  HOSTCC  tools/rkimage.o
  HOSTCC  tools/rksd.o
  HOSTCC  tools/rkspi.o
  HOSTCC  tools/socfpgaimage.o
  WRAP    tools/lib/sha1.c
  WRAP    tools/lib/sha256.c
  WRAP    tools/common/hash.c
  HOSTCC  tools/ublimage.o
  HOSTCC  tools/zynqimage.o
  WRAP    tools/lib/libfdt/fdt.c
  WRAP    tools/lib/libfdt/fdt_ro.c
  WRAP    tools/lib/libfdt/fdt_rw.c
  WRAP    tools/lib/libfdt/fdt_strerror.c
  WRAP    tools/lib/libfdt/fdt_wip.c
  WRAP    tools/lib/libfdt/fdt_region.c
  HOSTCC  tools/dumpimage.o
  HOSTCC  tools/mkimage.o
  HOSTCC  tools/mksunxiboot
  HOSTCC  tools/proftool
  HOSTCC  tools/fdtgrep.o
tools/bmp_logo --gen-info ./tools/logos/denx.bmp > include/bmp_logo.h
tools/bmp_logo --gen-data ./tools/logos/denx.bmp > include/bmp_logo_data.h
  HOSTCC  tools/lib/crc32.o
  HOSTCC  tools/common/bootm.o
  HOSTCC  tools/lib/fdtdec_common.o
  HOSTCC  tools/lib/fdtdec.o
  HOSTCC  tools/common/image-fit.o
  HOSTCC  tools/common/image.o
  HOSTCC  tools/lib/md5.o
  HOSTCC  tools/lib/rc4.o
  HOSTCC  tools/lib/sha1.o
  HOSTCC  tools/lib/sha256.o
  HOSTCC  tools/common/hash.o
  HOSTCC  tools/lib/libfdt/fdt.o
  HOSTCC  tools/lib/libfdt/fdt_ro.o
  HOSTCC  tools/lib/libfdt/fdt_rw.o
  HOSTCC  tools/lib/libfdt/fdt_strerror.o
  HOSTCC  tools/lib/libfdt/fdt_wip.o
  HOSTCC  tools/lib/libfdt/fdt_region.o
  HOSTLD  tools/mkenvimage
  HOSTLD  tools/dumpimage
  HOSTLD  tools/mkimage
  HOSTLD  tools/fdtgrep
  LD      arch/arm/cpu/built-in.o
  CC      arch/arm/cpu/armv7/cache_v7.o
  CC      board/sunxi/board.o
  AS      arch/arm/lib/vectors.o
  CC      board/sunxi/gmac.o
  CC      arch/arm/cpu/armv7/cpu.o
  LD      board/sunxi/built-in.o
  CC      arch/arm/cpu/armv7/cp15.o
  AS      arch/arm/lib/crt0.o
  CC      arch/arm/cpu/armv7/syslib.o
  AS      arch/arm/cpu/armv7/lowlevel_init.o
  AS      arch/arm/lib/relocate.o
  AS      arch/arm/cpu/armv7/nonsec_virt.o
  CC      arch/arm/lib/bootm-fdt.o
  CC      arch/arm/lib/bootm.o
  CC      arch/arm/cpu/armv7/virt-v7.o
  CC      arch/arm/lib/sections.o
  CC      arch/arm/cpu/armv7/virt-dt.o
  CC      arch/arm/lib/stack.o
  CC      arch/arm/lib/interrupts.o
  AS      arch/arm/cpu/armv7/psci.o
  CC      common/init/board_init.o
  CC      arch/arm/lib/reset.o
  LD      common/init/built-in.o
  CC      arch/arm/lib/cache.o
  CC      common/main.o
  CC      arch/arm/cpu/armv7/sunxi/timer.o
  CC      arch/arm/lib/cache-cp15.o
  CC      arch/arm/cpu/armv7/sunxi/board.o
  AR      arch/arm/lib/lib.a
  CC      common/exports.o
  CC      arch/arm/cpu/armv7/sunxi/clock.o
  CC      arch/arm/lib/eabi_compat.o
  LD      arch/arm/lib/built-in.o
  CC      common/hash.o
  CC      arch/arm/cpu/armv7/sunxi/cpu_info.o
  CC      arch/arm/cpu/armv7/sunxi/dram_helpers.o
  CC      common/cli_hush.o
  CC      arch/arm/cpu/armv7/sunxi/pinmux.o
  CC      arch/arm/cpu/armv7/sunxi/usb_phy.o
  CC      common/autoboot.o
  CC      arch/arm/cpu/armv7/sunxi/prcm.o
  CC      arch/arm/cpu/armv7/sunxi/p2wi.o
  CC      arch/arm/cpu/armv7/sunxi/clock_sun6i.o
  CC      common/board_f.o
  CC      common/board_r.o
  CC      arch/arm/cpu/armv7/sunxi/tzpc.o
  CC      common/cmd_boot.o
  CC      arch/arm/cpu/armv7/sunxi/pmic_bus.o
  CC      common/cmd_bootm.o
  CC      common/bootm.o
  AS      arch/arm/cpu/armv7/sunxi/psci_sun6i.o
  CC      common/bootm_os.o
  CC      common/cmd_help.o
  LD      arch/arm/cpu/armv7/sunxi/built-in.o
  CC      common/cmd_version.o
  AS      arch/arm/cpu/armv7/start.o
  CC      common/env_attr.o
  CC      common/env_callback.o
  CC      common/env_flags.o
  LD      arch/arm/cpu/armv7/built-in.o
  CC      common/env_mmc.o
  CC      common/cmd_source.o
  CC      disk/part.o
  CC      common/cmd_bdinfo.o
  CC      disk/part_dos.o
  CC      common/cmd_console.o
  CC      common/cmd_echo.o
  CC      disk/part_efi.o
  CC      common/cmd_elf.o
  CC      common/cmd_exit.o
  CC      common/cmd_ext4.o
  LD      disk/built-in.o
  CC      common/cmd_ext2.o
  CC      common/cmd_fat.o
  CC      common/cmd_fdt.o
  CC      common/fdt_support.o
  LD      drivers/dma/built-in.o
  LD      drivers/adc/built-in.o
  CC      common/cmd_fs.o
  CC      drivers/gpio/gpio-uclass.o
  LD      drivers/block/built-in.o
  CC      common/cmd_gpio.o
  CC      drivers/gpio/sunxi_gpio.o
  CC      common/cmd_itest.o
  CC      drivers/core/device.o
  LD      drivers/gpio/built-in.o
  CC      common/cmd_load.o
  CC      drivers/core/lists.o
  CC      drivers/core/root.o
  CC      drivers/core/uclass.o
  CC      drivers/core/util.o
  CC      common/cmd_mem.o
  CC      drivers/core/device-remove.o
  CC      common/miiphyutil.o
  CC      drivers/crypto/fsl/sec.o
  CC      drivers/core/simple-bus.o
  CC      common/cmd_mii.o
  LD      drivers/crypto/fsl/built-in.o
  CC      drivers/core/dump.o
  LD      drivers/crypto/rsa_mod_exp/built-in.o
  CC      common/cmd_mdio.o
  LD      drivers/core/built-in.o
  LD      drivers/crypto/built-in.o
  LD      drivers/dfu/built-in.o
  CC      common/cmd_misc.o
  LD      drivers/hwmon/built-in.o
  CC      drivers/input/keyboard-uclass.o
  LD      drivers/memory/built-in.o
  CC      common/cmd_mmc.o
  LD      drivers/misc/built-in.o
  CC      drivers/input/input.o
  CC      common/cmd_net.o
  CC      drivers/pcmcia/tqm8xx_pcmcia.o
  CC      drivers/input/key_matrix.o
  CC      common/cmd_part.o
  LD      drivers/pcmcia/built-in.o
  LD      drivers/input/built-in.o
  CC      common/cmd_pcmcia.o
  CC      common/cmd_pxe.o
  LD      drivers/pwm/built-in.o
  CC      common/cmd_setexpr.o
  CC      common/cmd_test.o
  CC      common/cmd_usb.o
  CC      drivers/rtc/date.o
  CC      common/usb.o
  LD      drivers/rtc/built-in.o
  CC      common/usb_hub.o
  LD      drivers/soc/built-in.o
  LD      drivers/sound/built-in.o
  LD      drivers/thermal/built-in.o
  CC      common/usb_storage.o
  LD      drivers/timer/built-in.o
  LD      drivers/tpm/built-in.o
  LD      drivers/twserial/built-in.o
  CC      common/cmd_ximg.o
  CC      drivers/video/cfb_console.o
  LD      drivers/watchdog/built-in.o
  CC      common/iomux.o
  CC      common/flash.o
  CC      common/edid.o
  CC      common/splash.o
  CC      common/menu.o
  CC      drivers/video/sunxi_display.o
  CC      drivers/video/videomodes.o
  CC      common/usb_kbd.o
  LD      drivers/video/bridge/built-in.o
  LD      drivers/video/built-in.o
  CC      common/cmd_nvedit.o
  LD      drivers/built-in.o
  LD      drivers/i2c/built-in.o
  CC      common/env_common.o
  CC      drivers/mmc/mmc.o
  LD      drivers/mtd/built-in.o
  CC      drivers/mmc/sunxi_mmc.o
  CC      common/console.o
  CC      drivers/mmc/mmc_write.o
  CC      common/dlmalloc.o
  LD      drivers/mtd/onenand/built-in.o
  LD      drivers/mmc/built-in.o
  CC      common/malloc_simple.o
  CC      common/image.o
  LD      drivers/mtd/spi/built-in.o
  CC      common/image-fdt.o
  CC      common/memsize.o
  CC      drivers/net/designware.o
  CC      common/stdio.o
  CC      common/cli_simple.o
  LD      drivers/net/built-in.o
  CC      common/cli.o
  CC      common/cli_readline.o
  CC      drivers/net/phy/phy.o
  CC      common/command.o
  CC      common/s_record.o
  LD      drivers/net/phy/built-in.o
  CC      common/xyzModem.o
  CC      common/cmd_disk.o
  LD      drivers/pci/built-in.o
  LD      common/built-in.o
  LD      drivers/power/battery/built-in.o
  CC      drivers/power/axp221.o
  LD      drivers/power/built-in.o
  LD      drivers/power/fuel_gauge/built-in.o
  LD      drivers/power/mfd/built-in.o
  LD      drivers/power/pmic/built-in.o
  LD      drivers/power/regulator/built-in.o
  CC      drivers/serial/serial-uclass.o
  CC      drivers/spi/spi.o
  LD      drivers/usb/dwc3/built-in.o
  CC      drivers/serial/ns16550.o
  LD      drivers/spi/built-in.o
  LD      drivers/serial/built-in.o
  LD      drivers/usb/emul/built-in.o
  LD      drivers/usb/eth/built-in.o
  LD      drivers/usb/gadget/built-in.o
  LD      drivers/usb/gadget/udc/built-in.o
  CC      drivers/usb/host/usb-uclass.o
  LD      drivers/usb/musb/built-in.o
  CC      drivers/usb/host/ohci-hcd.o
  LD      drivers/usb/phy/built-in.o
  LD      drivers/usb/ulpi/built-in.o
  CC      drivers/usb/host/ohci-sunxi.o
  CC      drivers/usb/host/ehci-hcd.o
  CC      drivers/usb/host/ehci-sunxi.o
  LD      drivers/usb/host/built-in.o
  CC      fs/fs.o
  LD      drivers/usb/musb-new/built-in.o
  CC      fs/ext4/ext4fs.o
  CC      fs/ext4/ext4_common.o
  CC      net/checksum.o
  CC      fs/ext4/dev.o
  CC      net/arp.o
  CC      lib/libfdt/fdt.o
  LD      fs/ext4/built-in.o
  CC      net/bootp.o
  CC      lib/libfdt/fdt_ro.o
  CC      lib/libfdt/fdt_rw.o
  CC      fs/fat/fat_write.o
  CC      net/eth.o
  CC      lib/libfdt/fdt_strerror.o
  CC      fs/fat/file.o
  CC      lib/libfdt/fdt_sw.o
  CC      net/net.o
  CC      lib/libfdt/fdt_wip.o
  LD      fs/fat/built-in.o
  CC      net/nfs.o
  LD      fs/built-in.o
  CC      lib/libfdt/fdt_empty_tree.o
  CC      net/ping.o
  CC      lib/libfdt/fdt_addresses.o
  LD      test/built-in.o
  CC      lib/libfdt/fdt_region.o
  CC      net/tftp.o
  CC      test/dm/cmd_dm.o
  LD      lib/libfdt/built-in.o
  LD      net/built-in.o
  CC      lib/crc7.o
  LD      test/dm/built-in.o
  CC      lib/zlib/zlib.o
  CC      lib/crc8.o
  CC      lib/crc16.o
  CC      lib/fdtdec.o
  CC      lib/fdtdec_common.o
  LD      lib/zlib/built-in.o
  CC      lib/gunzip.o
  CC      lib/initcall.o
  CC      lib/lmb.o
  CC      lib/ldiv.o
  CC      lib/net_utils.o
  CC      lib/qsort.o
  CC      lib/rc4.o
  CC      lib/list_sort.o
  CC      lib/strmhz.o
  CC      lib/hashtable.o
  CC      lib/errno.o
  CC      lib/display_options.o
  CC      lib/crc32.o
  CC      lib/ctype.o
  CC      lib/div64.o
  CC      lib/hang.o
  CC      lib/linux_compat.o
  CC      lib/linux_string.o
  CC      lib/membuff.o
  CC      lib/slre.o
  CC      lib/string.o
  CC      lib/time.o
  CC      lib/uuid.o
  CC      lib/vsprintf.o
  CC      lib/panic.o
  CC      lib/strto.o
  LD      lib/built-in.o
  CC      examples/standalone/stubs.o
  CC      examples/standalone/hello_world.o
  LD      examples/standalone/libstubs.o
  LD      examples/standalone/hello_world
  OBJCOPY examples/standalone/hello_world.srec
  OBJCOPY examples/standalone/hello_world.bin
  LD      u-boot
  OBJCOPY u-boot.bin
  DTC     arch/arm/dts/sun6i-a31-app4-evb1.dtb
  OBJCOPY u-boot.srec
  DTC     arch/arm/dts/sun6i-a31-colombus.dtb
  DTC     arch/arm/dts/sun6i-a31-hummingbird.dtb
  DTC     arch/arm/dts/sun6i-a31-i7.dtb
  DTC     arch/arm/dts/sun6i-a31-m9.dtb
  DTC     arch/arm/dts/sun6i-a31-mele-a1000g-quad.dtb
  DTC     arch/arm/dts/sun6i-a31-mixtile-loftq.dtb
  DTC     arch/arm/dts/sun6i-a31s-cs908.dtb
  DTC     arch/arm/dts/sun6i-a31s-primo81.dtb
  DTC     arch/arm/dts/sun6i-a31s-sinovoip-bpi-m2.dtb
  MKIMAGE u-boot.img
  SHIPPED dts/dt.dtb
  CAT     u-boot-dtb.bin
  COPY    u-boot.dtb
  MKIMAGE u-boot-dtb.img
  LD      spl/arch/arm/cpu/built-in.o
  CC      spl/board/sunxi/board.o
  AS      spl/arch/arm/lib/vectors.o
  CC      spl/arch/arm/cpu/armv7/cache_v7.o
  CC      spl/board/sunxi/gmac.o
  CC      spl/arch/arm/cpu/armv7/cpu.o
  LD      spl/board/sunxi/built-in.o
  AS      spl/arch/arm/lib/crt0.o
  CC      spl/arch/arm/cpu/armv7/cp15.o
  CC      spl/common/spl/spl.o
  CC      spl/arch/arm/lib/spl.o
  CC      spl/arch/arm/cpu/armv7/syslib.o
  CC      spl/arch/arm/lib/sections.o
  AS      spl/arch/arm/cpu/armv7/lowlevel_init.o
  CC      spl/arch/arm/lib/stack.o
  CC      spl/arch/arm/lib/interrupts.o
  AS      spl/arch/arm/cpu/armv7/nonsec_virt.o
  CC      spl/arch/arm/lib/reset.o
  CC      spl/arch/arm/lib/cache.o
  CC      spl/arch/arm/cpu/armv7/virt-v7.o
  CC      spl/arch/arm/lib/cache-cp15.o
  CC      spl/arch/arm/cpu/armv7/virt-dt.o
  CC      spl/common/spl/spl_mmc.o
  AR      spl/arch/arm/lib/lib.a
  AS      spl/arch/arm/cpu/armv7/psci.o
  CC      spl/arch/arm/lib/eabi_compat.o
  LD      spl/common/spl/built-in.o
  LD      spl/arch/arm/lib/built-in.o
  CC      spl/common/init/board_init.o
  LD      spl/common/init/built-in.o
  CC      spl/arch/arm/cpu/armv7/sunxi/timer.o
  CC      spl/disk/part.o
  CC      spl/common/cmd_nvedit.o
  LD      spl/disk/built-in.o
  CC      spl/arch/arm/cpu/armv7/sunxi/board.o
  CC      spl/common/env_common.o
  CC      spl/common/console.o
  CC      spl/arch/arm/cpu/armv7/sunxi/clock.o
  CC      spl/common/dlmalloc.o
  CC      spl/common/malloc_simple.o
  CC      spl/arch/arm/cpu/armv7/sunxi/cpu_info.o
  CC      spl/common/image.o
  CC      spl/common/memsize.o
  CC      spl/arch/arm/cpu/armv7/sunxi/dram_helpers.o
  CC      spl/common/stdio.o
  CC      spl/common/cli_simple.o
  CC      spl/arch/arm/cpu/armv7/sunxi/pinmux.o
  CC      spl/common/cli.o
  CC      spl/arch/arm/cpu/armv7/sunxi/usb_phy.o
  CC      spl/common/cli_readline.o
  CC      spl/common/command.o
  CC      spl/arch/arm/cpu/armv7/sunxi/prcm.o
  CC      spl/common/s_record.o
  CC      spl/common/xyzModem.o
  CC      spl/arch/arm/cpu/armv7/sunxi/p2wi.o
  CC      spl/common/cmd_disk.o
  AS      spl/arch/arm/cpu/armv7/start.o
  LD      spl/common/built-in.o
  CC      spl/arch/arm/cpu/armv7/sunxi/clock_sun6i.o
  CC      spl/arch/arm/cpu/armv7/sunxi/tzpc.o
  CC      spl/arch/arm/cpu/armv7/sunxi/pmic_bus.o
  CC      spl/arch/arm/cpu/armv7/sunxi/dram_sun6i.o
  AS      spl/arch/arm/cpu/armv7/sunxi/fel_utils.o
  CC      spl/drivers/gpio/sunxi_gpio.o
  CC      spl/drivers/mmc/mmc.o
  LD      spl/arch/arm/cpu/armv7/sunxi/built-in.o
  LD      spl/drivers/gpio/built-in.o
  LD      spl/arch/arm/cpu/armv7/built-in.o
  CC      spl/drivers/mmc/sunxi_mmc.o
  LD      spl/drivers/mmc/built-in.o
  CC      spl/drivers/power/axp221.o
  LD      spl/drivers/power/pmic/built-in.o
  LD      spl/drivers/power/regulator/built-in.o
  LD      spl/drivers/power/built-in.o
  CC      spl/drivers/serial/serial.o
  CC      spl/drivers/serial/serial_ns16550.o
  LD      spl/dts/built-in.o
  CC      spl/drivers/serial/ns16550.o
  LD      spl/fs/built-in.o
  LD      spl/drivers/serial/built-in.o
  LD      spl/drivers/built-in.o
  CC      spl/lib/hashtable.o
  CC      spl/lib/errno.o
  CC      spl/lib/display_options.o
  LDS     spl/u-boot-spl.lds
  CC      spl/lib/crc32.o
  CC      spl/lib/ctype.o
  CC      spl/lib/div64.o
  CC      spl/lib/hang.o
  CC      spl/lib/linux_compat.o
  CC      spl/lib/linux_string.o
  CC      spl/lib/membuff.o
  CFG     spl/u-boot-spl.cfg
  CC      spl/lib/slre.o
  CC      spl/lib/time.o
  CC      spl/lib/string.o
  CC      spl/lib/vsprintf.o
  CC      spl/lib/panic.o
  CC      spl/lib/strto.o
  LD      spl/u-boot-spl
dpkg-deb: error: control directory has bad permissions 2755 (must be >=0755 and <=0775)
The error is the same as here. http://forum.armbian.com/index.php/topic/693-sunxi-a31s-banana-pi-m2-syntax-error-in-configurationsh/#entry5070
For me, modifying configuration.sh to point at the correct defconfig file in uboot did the trick.
	orangepih3)#enabled
		#description H3 quad core (Orange Pi PC/One/2/Lite)
		#build 3wip
		LINUXFAMILY="sun8i"
		BOOTCONFIG="orangepi_pc_defconfig"
		MODULES="8189es #gpio_sunxi #w1-sunxi #w1-gpio #w1-therm #gc2035"
		MODULES_NEXT=""
		CPUMIN="480000"
		CPUMAX="1296000"
		GOVERNOR="interactive"
Sadly I don't think this will solve Schwemmlandebene's problem :-(
As expected everything works with a new user in Ubuntu. I can't say what causes the change of the file permission. Sooner or later I will switch to an early Ubuntu snapshot of the VM,
@zador thanks for your help, too.
