Vishal Posted September 12, 2018 Posted September 12, 2018 While using ubuntu1604-kernel4.4-VAAPLI.img I took downloaded from the server, I came across the following problem. While trying to develop device drivers for kernel space, I realized we dont have any linux headers in the said system. I have tried looking up for the same at Rockchip's github as well as wiki site, but could not find one. Can anyone point me to the correct linux headers ? I am using RK3288 development board, and current my version using "uname -r" is "4.4.55+"
tkaiser Posted September 12, 2018 Posted September 12, 2018 On 9/12/2018 at 9:22 AM, Vishal said: ubuntu1604-kernel4.4-VAAPLI.img Expand What't this? In case you want to install linux-headers on Armbian the procedure is as follows: https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver
Vishal Posted September 13, 2018 Author Posted September 13, 2018 Thanks for the prompt response, really appreciate it. But the steps mentioned in the above link did not work for me. After installing the said package, I got the following errors on building my test driver ubuntu@localhost:~/vishal/kernel_modules/wow_display_manager$ make make -C /lib/modules/'4.4.71-rockchip'/build/ M=/home/ubuntu/vishal/kernel_modules/wow_display_manager modules make[1]: Entering directory '/usr/src/linux-headers-4.4.71-rockchip' CC [M] /home/ubuntu/vishal/kernel_modules/wow_display_manager/wow-display-manager.o gcc: error: unrecognized command line option ‘-mgeneral-regs-only’ scripts/Makefile.build:264: recipe for target '/home/ubuntu/vishal/kernel_modules/wow_display_manager/wow-display-manager.o' failed make[2]: *** [/home/ubuntu/vishal/kernel_modules/wow_display_manager/wow-display-manager.o] Error 1 Makefile:1419: recipe for target '_module_/home/ubuntu/vishal/kernel_modules/wow_display_manager' failed make[1]: *** [_module_/home/ubuntu/vishal/kernel_modules/wow_display_manager] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-4.4.71-rockchip' Makefile:8: recipe for target 'all' failed make: *** [all] Error 2 ubuntu@localhost:~/vishal/kernel_modules/wow_display_manager$ We have a Rockchip RK3288 based development board with a bare minimum Ubuntu ported on top of the Kernel as mentioned here https://github.com/rockchip-linux/kernel The details of Ubuntu are mentioned here http://opensource.rock-chips.com/wiki_Linux_user_guide Is it possible to generate linux-headers from kernel? They are the prerequisites for building kernel level device drivers. Thanks in advance.
tkaiser Posted September 13, 2018 Posted September 13, 2018 On 9/13/2018 at 4:25 AM, Vishal said: But the steps mentioned in the above link did not work for me Expand That's because you do NOT use Armbian and therefore instructions for Armbian won't work. As expected. You might have your reasons to do everything complicated and manually though...
