peter12 Posted September 15, 2018 Posted September 15, 2018 Hello, please, is it possible (if yes, how or what are available parameters) to run nand-sata-install from command line "one liner" - I mean without going to programm GUI? I would like to just run one command with predefined command line parameters and it should automatically copy microsd to emmc storage. Many thanks
tkaiser Posted September 15, 2018 Posted September 15, 2018 16 minutes ago, peter12 said: is it possible (if yes, how or what are available parameters) to run nand-sata-install from command line "one liner" - I mean without going to programm GUI? Nope. Since if you're able to provide the appropriate parameters and did the prerequisits (device nodes, creating partitions) you can also call the few commands nand-sata-install uses internally. So by tweaking the script you get such a CLI parametrization but are on your own to get there.
peter12 Posted September 15, 2018 Author Posted September 15, 2018 what a pity. But thanks for reply anyway. Maybe later I will try to understand commands used in nand-sata-install script and potentially convert it to command line feature. This would be a nice feature for future.
tkaiser Posted September 15, 2018 Posted September 15, 2018 1 hour ago, peter12 said: This would be a nice feature for future Why?
peter12 Posted September 16, 2018 Author Posted September 16, 2018 On 9/15/2018 at 1:05 PM, tkaiser said: Why? I think it is much easier to just execute one liner than go through many steps in GUI.
