orange pi one H3 idles somewhat warm in part due to a power regulator that switches only between 1.1 and 1.3 v. orange pi pc could idle at pretty low temperatures (closer to room without a heat sink due to a better power regulator as well), and the h3 runs rather hot say > 70deg C when under loads
the trouble is the SOC die is 14x14mm, and if one wants to use a large heat sink, it wouldn't fit and you would need to use the copper shim method, to provide some clearance to fit a large heat sink
that is troublesome and hence , i made do and made an attempt to try out *small* heat sinks, e.g.
https://www.aliexpress.com/item/10pcs-Computer-Cooler-Radiator-Aluminum-Heatsink-Heat-sink-for-Electronic-Chip-Heat-dissipation-Cooling-Pads-14/32890197245.html
the dealer provided some thermal tapes, it is convenient, but i did not use them, instead i used some ordinary heat sink compounds like this
https://www.ebay.com/sch/i.html?_from=R40&_nkw=hy510&_sacat=0&_sop=15
the results looks like this, i used a little too much thermal compound and they ooze from the edges
tests
platform: debian stretch mainline kernel (switched to development / nightly builds) Linux orangepione 4.14.68-sunxi #161 SMP
to evaluate how well such small heat sink works i made it (H3) do some math (square matrix multiplication) based on codes adapted from
https://github.com/mtrebi/matrix-multiplication-threading.git
this probably won't give the best mflops, gflops but it is able to run all 4 threads concurrently doing the matrix multiplication
the test does a multi-threaded 1000x1000 matrix multiplication concurrently, this is 2N^3 flops (2 billion floating point ops)
here are the results
orange pi one
no heat sink idle
  Reveal hidden contents
heat sink idle
i noted that the idle temperatures are about 5 degrees lower average vs without the heat sink
no heat sink load 5 cycles of 1000x1000 matrix multiplication (each cycle takes about 10-11 secs hence about 1 min run)
ok so that is 180mflops (no heat sink) vs 214mflops (heat sink), note that in this particular case, i started off at lower temperatures (i.e. after the board just started), hence, there is more thermal headroom which results in a higher difference. this is quite reflective of a transient load.
no heat sink load 10 cycles of 1000x1000 matrix multiplication (each cycle takes about 10-11 secs hence about 2 minutes run)
ok so that is 178 Mflops no heat sink vs 194 Mflops, with heat sink
no heat sink
960000    6162    6162    6162    6162 <<< cpu spend most of the time here
1008000    3307    3307    3307    3307 <<< cpu spend most of the time here
vs heat sink
1008000    6528    6528    6528    6528 <<< cpu spend most of the time here
1200000    7056    7056    7056    7056  <<< cpu spend most of the time here
this case would more likely reflect sustained loads
conclusion
the small heat sink is probably inadequate but nevertheless it made a modest improvement
the cpu is able to spend more of the time at the higher frequencies under load vs without heat sink, hence the Mflops improvement
for transient conditions (i.e. short high loads) this small heat sink apparently made a visible difference as seen in the Mflops improvement
somewhat lower idle temperatures (for orange pi one), orange pi pc could do without a heat sink at idle
out of curiosity i fine tuned the source codes making use of the quad execute for floating point on cortex a7 (simply unroll the loop)
https://community.arm.com/processors/f/discussions/5277/cortex-a7-pipeline-is-non-symmetric-what-does-this-attribute-mean
2389.49Mflops !
now that looks like the power of a modern arm cortex a7 processor. my guess is the gains are from pipelining efficiencies and the fp quad execute
the command to build is c++ -O2 -std=gnu++11 -pthread -o mat main.cpp
then run ./mat
sources attached
main.cppFetching info...
yes that is the orange pi one or orange pi pc (H3) mainline kernel
and for all that speeds the temperatures (with heatsink) looked uneventful (no high temps etc)
