xeniter Posted October 1, 2018 Posted October 1, 2018 Hi i try to get a ov5640 camera running on a banana pi m2 plus board. i builded the csi driver and it gets loaded, however i am not able to take picture: root@bananapim2plus:~/cap-v4l2# ./cap 1280 768 4 1 -999 -1 -1 ---- cap parameters ----- width: 1280 height: 768 v4l2 buffers: 4 exposure: -999 hflip: -1 vflip: -1 Mode: V4L2_MODE_VIDEO Driver: "sun6i-video" Card: "sun6i-csi" Bus: "platform:camera" Version: 1.0 Capabilities: 84200001 v4l2: unable to enumerate input. v4l2: failed to init camera. root@bananapim2plus:~/cap-v4l2# dmesg [23141.993618] sun6i-csi 1cb0000.camera: -> sun6i_csi_set_power() [23141.993653] sun6i-csi 1cb0000.camera: -> sun6i_csi_set_power() =>DONE_1 [23142.007416] sun6i-csi 1cb0000.camera: -> sun6i_csi_set_power() [23142.007451] sun6i-csi 1cb0000.camera: -> sun6i_csi_set_power() =>DONE_2 Does anyone know how the video 4 linux call path is for initializing a camera? I loaded the ov6540 module but it never gets probed. i assume the i2c must be somehow linked in the dts file together, but i wasn't able to find a complete working example. my dts file now, which loads at least the sun6i-csi driver but it should be insert i2c section, if i put it there, i does not get loaded. csi { status = "okay"; port { #address-cells = <1>; #size-cells = <0>; // Parallel bus endpoint csi_from_ov5640: endpoint { remote-endpoint = <&ov5640_to_csi>; bus-width = <8>; data-shift = <2>; hsync-active = <1>; // Active high vsync-active = <0>; // Active low data-active = <1>; // Active high pclk-sample = <1>; // Rising }; }; }; camera@1cb0000 { compatible = "allwinner,sun8i-h3-csi", "allwinner,sun6i-a31-csi"; reg = <0x1cb0000 0x1000>; interrupts = <0x0 0x54 0x4>; clocks = <0x3 0x2d 0x3 0x6a 0x3 0x62>; clock-names = "bus", "mod", "ram"; resets = <0x3 0x1e>; pinctrl-names = "default"; pinctrl-0 = <0x27>; status = "okay"; phandle = <0x63>; // powerdown-gpios = <&gpio1 19 GPIO_ACTIVE_HIGH>; // reset-gpios = <&gpio1 20 GPIO_ACTIVE_LOW>; //powerdown-gpios = <0xc 0x3 0xd 0x0>; // PD14 active high ?? port { ov5640_to_csi: endpoint { remote-endpoint = <&csi_from_ov5640>; bus-width = <8>; data-shift = <2>; hsync-active = <1>; // Active high vsync-active = <0>; // Active low data-active = <1>; // Active high pclk-sample = <1>; // Rising }; }; }; According to the kernel doku: https://elixir.bootlin.com/linux/latest/source/Documentation/devicetree/bindings/media/video-interfaces.txt it should be a device node from the i2c, but then it doesn't load the camera modul. If i add compatible="ovti,ov5640" the ov5640 modul get loaded but does not to anything. no even a simple print, which modul/function/program should call the i2c probing? when i load i2c normal, the modul works (i2cdetect does probe something on the i2 lines). Next isse i have, the V4L2 looks like changed to a builtin modul, is it somehow possible to change it back to a modul? would like to printk debug the v4l2 async file. When i set it back in the config file to "m" it asks again and says this is a invalid option? Anyone an idea? or have a working dts file for a ovXXXX camera with i2c running with the sun6i-csi modul?
xeniter Posted October 3, 2018 Author Posted October 3, 2018 got it finally running, still some issues got first picture main problem was DTS setup (clocks and pins configuration) if anyone would like to get it running (OV5640 on a banana pi m2 plus board (sun8i-h3 allwinner) with latest dev kernel (4.18.11)) build armbian for banana with dev branch: ./compile.sh KERNEL_ONLY=no BUILD_DESKTOP=no INSTALL_HEADERS=yes BRANCH=dev RELEASE=stretch BOARD=bananapim2plus -j4 choose change kernel config, choose following as modul: CONFIG_VIDEO_OV5640=m CONFIG_VIDEO_SUN6I_CSI=m i prefer moduls for debug purposes adjust DTS file for Camera and CSI interface, not sure if its completely correct, at least i got a picture /dts-v1/; / { interrupt-parent = <0x1>; #address-cells = <0x1>; #size-cells = <0x1>; model = "Banana Pi BPI-M2-Plus"; compatible = "sinovoip,bpi-m2-plus", "allwinner,sun8i-h3"; chosen { #address-cells = <0x1>; #size-cells = <0x1>; ranges; stdout-path = "serial0:115200n8"; framebuffer-hdmi { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "mixer0-lcd0-hdmi"; clocks = <0x2 0x6 0x3 0x66 0x3 0x6f>; status = "disabled"; }; framebuffer-tve { compatible = "allwinner,simple-framebuffer", "simple-framebuffer"; allwinner,pipeline = "mixer1-lcd1-tve"; clocks = <0x2 0x7 0x3 0x67>; status = "disabled"; }; }; sound { compatible = "simple-audio-card"; simple-audio-card,format = "i2s"; simple-audio-card,name = "allwinner,hdmi"; simple-audio-card,mclk-fs = <0x100>; status = "disabled"; phandle = <0x34>; simple-audio-card,codec { sound-dai = <0x4>; }; simple-audio-card,cpu { sound-dai = <0x5>; }; }; clocks { #address-cells = <0x1>; #size-cells = <0x1>; ranges; osc24M_clk { #clock-cells = <0x0>; compatible = "fixed-clock"; clock-frequency = <0x16e3600>; clock-output-names = "osc24M"; phandle = <0x13>; }; osc32k_clk { #clock-cells = <0x0>; compatible = "fixed-clock"; clock-frequency = <0x8000>; clock-output-names = "osc32k"; phandle = <0x14>; }; internal-osc-clk { #clock-cells = <0x0>; compatible = "fixed-clock"; clock-frequency = <0xf42400>; clock-accuracy = <0x11e1a300>; clock-output-names = "iosc"; phandle = <0x28>; }; }; display-engine { compatible = "allwinner,sun8i-h3-display-engine"; allwinner,pipelines = <0x6>; status = "okay"; phandle = <0x35>; }; soc { compatible = "simple-bus"; #address-cells = <0x1>; #size-cells = <0x1>; ranges; clock@1000000 { reg = <0x1000000 0x100000>; clocks = <0x3 0x65 0x3 0x30>; clock-names = "mod", "bus"; resets = <0x3 0x22>; #clock-cells = <0x1>; #reset-cells = <0x1>; compatible = "allwinner,sun8i-h3-de2-clk"; phandle = <0x2>; }; mixer@1100000 { compatible = "allwinner,sun8i-h3-de2-mixer-0"; reg = <0x1100000 0x100000>; clocks = <0x2 0x0 0x2 0x6>; clock-names = "bus", "mod"; resets = <0x2 0x0>; phandle = <0x6>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@1 { reg = <0x1>; phandle = <0x36>; endpoint { remote-endpoint = <0x7>; phandle = <0x8>; }; }; }; }; syscon@1c00000 { compatible = "allwinner,sun8i-h3-system-controller", "syscon"; reg = <0x1c00000 0x1000>; phandle = <0x15>; }; dma-controller@1c02000 { compatible = "allwinner,sun8i-h3-dma"; reg = <0x1c02000 0x1000>; interrupts = <0x0 0x32 0x4>; clocks = <0x3 0x15>; resets = <0x3 0x6>; #dma-cells = <0x1>; phandle = <0x1a>; }; lcd-controller@1c0c000 { compatible = "allwinner,sun8i-h3-tcon-tv", "allwinner,sun8i-a83t-tcon-tv"; reg = <0x1c0c000 0x1000>; interrupts = <0x0 0x56 0x4>; clocks = <0x3 0x2a 0x3 0x66>; clock-names = "ahb", "tcon-ch1"; resets = <0x3 0x1b>; reset-names = "lcd"; phandle = <0x37>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@0 { reg = <0x0>; phandle = <0x38>; endpoint { remote-endpoint = <0x8>; phandle = <0x7>; }; }; port@1 { #address-cells = <0x1>; #size-cells = <0x0>; reg = <0x1>; phandle = <0x39>; endpoint@1 { reg = <0x1>; remote-endpoint = <0x9>; phandle = <0x25>; }; }; }; }; mmc@1c0f000 { reg = <0x1c0f000 0x1000>; pinctrl-names = "default"; pinctrl-0 = <0xa>; resets = <0x3 0x7>; reset-names = "ahb"; interrupts = <0x0 0x3c 0x4>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun7i-a20-mmc"; clocks = <0x3 0x16 0x3 0x47 0x3 0x49 0x3 0x48>; clock-names = "ahb", "mmc", "output", "sample"; vmmc-supply = <0xb>; bus-width = <0x4>; cd-gpios = <0xc 0x5 0x6 0x1>; phandle = <0x3a>; }; mmc@1c10000 { reg = <0x1c10000 0x1000>; pinctrl-names = "default"; pinctrl-0 = <0xd>; resets = <0x3 0x8>; reset-names = "ahb"; interrupts = <0x0 0x3d 0x4>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun7i-a20-mmc"; clocks = <0x3 0x17 0x3 0x4a 0x3 0x4c 0x3 0x4b>; clock-names = "ahb", "mmc", "output", "sample"; vmmc-supply = <0xb>; vqmmc-supply = <0xb>; mmc-pwrseq = <0xe>; bus-width = <0x4>; non-removable; phandle = <0x3b>; wifi@1 { reg = <0x1>; compatible = "brcm,bcm4329-fmac"; interrupt-parent = <0xc>; interrupts = <0x6 0xa 0x8>; interrupt-names = "host-wake"; phandle = <0x3c>; }; }; mmc@1c11000 { reg = <0x1c11000 0x1000>; resets = <0x3 0x9>; reset-names = "ahb"; interrupts = <0x0 0x3e 0x4>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; compatible = "allwinner,sun7i-a20-mmc"; clocks = <0x3 0x18 0x3 0x4d 0x3 0x4f 0x3 0x4e>; clock-names = "ahb", "mmc", "output", "sample"; pinctrl-names = "default"; pinctrl-0 = <0xf>; vmmc-supply = <0xb>; vqmmc-supply = <0xb>; bus-width = <0x8>; non-removable; phandle = <0x3d>; }; usb@1c19000 { compatible = "allwinner,sun8i-h3-musb"; reg = <0x1c19000 0x400>; clocks = <0x3 0x20>; resets = <0x3 0x11>; interrupts = <0x0 0x47 0x4>; interrupt-names = "mc"; phys = <0x10 0x0>; phy-names = "usb"; extcon = <0x10 0x0>; status = "okay"; dr_mode = "otg"; phandle = <0x3e>; }; eeprom@01c14000 { compatible = "allwinner,sun8i-h3-sid"; reg = <0x1c14000 0x400>; phandle = <0x3f>; }; phy@1c19400 { compatible = "allwinner,sun8i-h3-usb-phy"; reg = <0x1c19400 0x2c 0x1c1a800 0x4 0x1c1b800 0x4 0x1c1c800 0x4 0x1c1d800 0x4>; reg-names = "phy_ctrl", "pmu0", "pmu1", "pmu2", "pmu3"; clocks = <0x3 0x58 0x3 0x59 0x3 0x5a 0x3 0x5b>; clock-names = "usb0_phy", "usb1_phy", "usb2_phy", "usb3_phy"; resets = <0x3 0x0 0x3 0x1 0x3 0x2 0x3 0x3>; reset-names = "usb0_reset", "usb1_reset", "usb2_reset", "usb3_reset"; status = "okay"; #phy-cells = <0x1>; usb0_id_det-gpios = <0x11 0x0 0x6 0x0>; usb0_vbus-supply = <0x12>; phandle = <0x10>; }; usb@1c1a000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1a000 0x100>; interrupts = <0x0 0x48 0x4>; clocks = <0x3 0x21 0x3 0x25>; resets = <0x3 0x12 0x3 0x16>; status = "okay"; phandle = <0x40>; }; usb@1c1a400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1a400 0x100>; interrupts = <0x0 0x49 0x4>; clocks = <0x3 0x21 0x3 0x25 0x3 0x5c>; resets = <0x3 0x12 0x3 0x16>; status = "okay"; phandle = <0x41>; }; usb@1c1b000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1b000 0x100>; interrupts = <0x0 0x4a 0x4>; clocks = <0x3 0x22 0x3 0x26>; resets = <0x3 0x13 0x3 0x17>; phys = <0x10 0x1>; phy-names = "usb"; status = "okay"; phandle = <0x42>; }; usb@1c1b400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1b400 0x100>; interrupts = <0x0 0x4b 0x4>; clocks = <0x3 0x22 0x3 0x26 0x3 0x5d>; resets = <0x3 0x13 0x3 0x17>; phys = <0x10 0x1>; phy-names = "usb"; status = "okay"; phandle = <0x43>; }; usb@1c1c000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1c000 0x100>; interrupts = <0x0 0x4c 0x4>; clocks = <0x3 0x23 0x3 0x27>; resets = <0x3 0x14 0x3 0x18>; phys = <0x10 0x2>; phy-names = "usb"; status = "okay"; phandle = <0x44>; }; usb@1c1c400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1c400 0x100>; interrupts = <0x0 0x4d 0x4>; clocks = <0x3 0x23 0x3 0x27 0x3 0x5e>; resets = <0x3 0x14 0x3 0x18>; phys = <0x10 0x2>; phy-names = "usb"; status = "okay"; phandle = <0x45>; }; usb@1c1d000 { compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; reg = <0x1c1d000 0x100>; interrupts = <0x0 0x4e 0x4>; clocks = <0x3 0x24 0x3 0x28>; resets = <0x3 0x15 0x3 0x19>; phys = <0x10 0x3>; phy-names = "usb"; status = "disabled"; phandle = <0x46>; }; usb@1c1d400 { compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; reg = <0x1c1d400 0x100>; interrupts = <0x0 0x4f 0x4>; clocks = <0x3 0x24 0x3 0x28 0x3 0x5f>; resets = <0x3 0x15 0x3 0x19>; phys = <0x10 0x3>; phy-names = "usb"; status = "disabled"; phandle = <0x47>; }; ccu: clock@1c20000 { reg = <0x1c20000 0x400>; clocks = <0x13 0x14>; clock-names = "hosc", "losc"; #clock-cells = <0x1>; #reset-cells = <0x1>; compatible = "allwinner,sun8i-h3-ccu"; phandle = <0x3>; }; pinctrl@1c20800 { reg = <0x1c20800 0x400>; interrupts = <0x0 0xb 0x4 0x0 0x11 0x4>; clocks = <0x3 0x36 0x13 0x14>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <0x3>; interrupt-controller; #interrupt-cells = <0x3>; compatible = "allwinner,sun8i-h3-pinctrl"; phandle = <0xc>; csi { pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11"; function = "csi"; phandle = <0x27>; }; emac0 { pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD7", "PD8", "PD9", "PD10", "PD12", "PD13", "PD15", "PD16", "PD17"; function = "emac"; drive-strength = <0x28>; phandle = <0x16>; }; i2c0 { pins = "PA11", "PA12"; function = "i2c0"; phandle = <0x21>; }; i2c1 { pins = "PA18", "PA19"; function = "i2c1"; phandle = <0x22>; }; i2c2 { pins = "PE12", "PE13"; function = "i2c2"; phandle = <0x23>; }; i2s0 { pins = "PA18", "PA19", "PA20", "PA21"; function = "i2s0"; phandle = <0x48>; }; i2s1 { pins = "PG10", "PG11", "PG12", "PG13"; function = "i2s1"; phandle = <0x49>; }; mmc0 { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; function = "mmc0"; drive-strength = <0x1e>; bias-pull-up; phandle = <0xa>; }; mmc1 { pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5"; function = "mmc1"; drive-strength = <0x1e>; bias-pull-up; phandle = <0xd>; }; mmc2_8bit { pins = "PC5", "PC6", "PC8", "PC9", "PC10", "PC11", "PC12", "PC13", "PC14", "PC15", "PC16"; function = "mmc2"; drive-strength = <0x1e>; bias-pull-up; phandle = <0xf>; }; spdif { pins = "PA17"; function = "spdif"; phandle = <0x4a>; }; spi0 { pins = "PC0", "PC1", "PC2", "PC3"; function = "spi0"; phandle = <0x1b>; }; spi1 { pins = "PA15", "PA16", "PA14", "PA13"; function = "spi1"; phandle = <0x1c>; }; uart0 { pins = "PA4", "PA5"; function = "uart0"; phandle = <0x1e>; }; uart1 { pins = "PG6", "PG7"; function = "uart1"; phandle = <0x1f>; }; uart1_rts_cts { pins = "PG8", "PG9"; function = "uart1"; phandle = <0x20>; }; uart2 { pins = "PA0", "PA1"; function = "uart2"; phandle = <0x4b>; }; uart3 { pins = "PA13", "PA14"; function = "uart3"; phandle = <0x4c>; }; uart3_rts_cts { pins = "PA15", "PA16"; function = "uart3"; phandle = <0x4d>; }; }; timer@1c20c00 { compatible = "allwinner,sun4i-a10-timer"; reg = <0x1c20c00 0xa0>; interrupts = <0x0 0x12 0x4 0x0 0x13 0x4>; clocks = <0x13>; }; ethernet@1c30000 { compatible = "allwinner,sun8i-h3-emac"; syscon = <0x15>; reg = <0x1c30000 0x10000>; interrupts = <0x0 0x52 0x4>; interrupt-names = "macirq"; resets = <0x3 0xc>; reset-names = "stmmaceth"; clocks = <0x3 0x1b>; clock-names = "stmmaceth"; #address-cells = <0x1>; #size-cells = <0x0>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x16>; phy-supply = <0x17>; phy-handle = <0x18>; phy-mode = "rgmii"; phandle = <0x4e>; mdio { #address-cells = <0x1>; #size-cells = <0x0>; compatible = "snps,dwmac-mdio"; phandle = <0x19>; }; mdio-mux { compatible = "allwinner,sun8i-h3-mdio-mux"; #address-cells = <0x1>; #size-cells = <0x0>; mdio-parent-bus = <0x19>; mdio@1 { compatible = "allwinner,sun8i-h3-mdio-internal"; reg = <0x1>; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x4f>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x1>; clocks = <0x3 0x43>; resets = <0x3 0x27>; phandle = <0x50>; }; }; mdio@2 { reg = <0x2>; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x51>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x0>; phandle = <0x18>; }; }; }; }; spi@1c68000 { compatible = "allwinner,sun8i-h3-spi"; reg = <0x1c68000 0x1000>; interrupts = <0x0 0x41 0x4>; clocks = <0x3 0x1e 0x3 0x52>; clock-names = "ahb", "mod"; dmas = <0x1a 0x17 0x1a 0x17>; dma-names = "rx", "tx"; pinctrl-names = "default"; pinctrl-0 = <0x1b>; resets = <0x3 0xf>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x52>; }; spi@1c69000 { compatible = "allwinner,sun8i-h3-spi"; reg = <0x1c69000 0x1000>; interrupts = <0x0 0x42 0x4>; clocks = <0x3 0x1f 0x3 0x53>; clock-names = "ahb", "mod"; dmas = <0x1a 0x18 0x1a 0x18>; dma-names = "rx", "tx"; pinctrl-names = "default"; pinctrl-0 = <0x1c>; resets = <0x3 0x10>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x53>; }; watchdog@1c20ca0 { compatible = "allwinner,sun6i-a31-wdt"; reg = <0x1c20ca0 0x20>; interrupts = <0x0 0x19 0x4>; phandle = <0x54>; }; spdif@1c21000 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-spdif"; reg = <0x1c21000 0x400>; interrupts = <0x0 0xc 0x4>; clocks = <0x3 0x35 0x3 0x57>; resets = <0x3 0x29>; clock-names = "apb", "spdif"; dmas = <0x1a 0x2>; dma-names = "tx"; status = "disabled"; phandle = <0x55>; }; pwm@1c21400 { compatible = "allwinner,sun8i-h3-pwm"; reg = <0x1c21400 0x8>; clocks = <0x13>; #pwm-cells = <0x3>; status = "disabled"; phandle = <0x56>; }; i2s@1c22000 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-i2s"; reg = <0x1c22000 0x400>; interrupts = <0x0 0xd 0x4>; clocks = <0x3 0x38 0x3 0x54>; clock-names = "apb", "mod"; dmas = <0x1a 0x3 0x1a 0x3>; resets = <0x3 0x2b>; dma-names = "rx", "tx"; status = "disabled"; phandle = <0x57>; }; i2s@1c22400 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-i2s"; reg = <0x1c22400 0x400>; interrupts = <0x0 0xe 0x4>; clocks = <0x3 0x39 0x3 0x55>; clock-names = "apb", "mod"; dmas = <0x1a 0x4 0x1a 0x4>; resets = <0x3 0x2c>; dma-names = "rx", "tx"; status = "disabled"; phandle = <0x58>; }; i2s@1c22800 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-i2s"; reg = <0x1c22800 0x400>; interrupts = <0x0 0xf 0x4>; clocks = <0x3 0x3a 0x3 0x56>; clock-names = "apb", "mod"; dmas = <0x1a 0x1b>; resets = <0x3 0x2d>; dma-names = "tx"; status = "disabled"; phandle = <0x5>; }; codec@1c22c00 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-codec"; reg = <0x1c22c00 0x400>; interrupts = <0x0 0x1d 0x4>; clocks = <0x3 0x34 0x3 0x6d>; clock-names = "apb", "codec"; resets = <0x3 0x28>; dmas = <0x1a 0xf 0x1a 0xf>; dma-names = "rx", "tx"; allwinner,codec-analog-controls = <0x1d>; status = "disabled"; phandle = <0x59>; }; serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x1c28000 0x400>; interrupts = <0x0 0x0 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x3 0x3e>; resets = <0x3 0x31>; dmas = <0x1a 0x6 0x1a 0x6>; dma-names = "rx", "tx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x1e>; phandle = <0x5a>; }; serial@1c28400 { compatible = "snps,dw-apb-uart"; reg = <0x1c28400 0x400>; interrupts = <0x0 0x1 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x3 0x3f>; resets = <0x3 0x32>; dmas = <0x1a 0x7 0x1a 0x7>; dma-names = "rx", "tx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x1f 0x20>; phandle = <0x5b>; }; serial@1c28800 { compatible = "snps,dw-apb-uart"; reg = <0x1c28800 0x400>; interrupts = <0x0 0x2 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x3 0x40>; resets = <0x3 0x33>; dmas = <0x1a 0x8 0x1a 0x8>; dma-names = "rx", "tx"; status = "disabled"; phandle = <0x5c>; }; serial@1c28c00 { compatible = "snps,dw-apb-uart"; reg = <0x1c28c00 0x400>; interrupts = <0x0 0x3 0x4>; reg-shift = <0x2>; reg-io-width = <0x4>; clocks = <0x3 0x41>; resets = <0x3 0x34>; dmas = <0x1a 0x9 0x1a 0x9>; dma-names = "rx", "tx"; status = "disabled"; phandle = <0x5d>; }; i2c@1c2ac00 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1c2ac00 0x400>; interrupts = <0x0 0x6 0x4>; clocks = <0x3 0x3b>; resets = <0x3 0x2e>; pinctrl-names = "default"; pinctrl-0 = <0x21>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x5e>; }; i2c@1c2b000 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1c2b000 0x400>; interrupts = <0x0 0x7 0x4>; clocks = <0x3 0x3c>; resets = <0x3 0x2f>; pinctrl-names = "default"; pinctrl-0 = <0x22>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x5f>; }; csi@1cb0000 { compatible = "allwinner,sun8i-h3-csi", "allwinner,sun6i-a31-csi"; reg = <0x1cb0000 0x1000>; interrupts = <0x0 0x54 0x4>; clocks = <0x3 0x2d 0x3 0x6a 0x3 0x62>; // 0x3==ccu 0x2d=45=CLK_BUS_CSI 0x6a=106=CLK_CSI_SCLK 0x62=98=CLK_DRAM_CSI // #define CLK_DRAM_VE 97 // #define CLK_VE 108 clock-names = "bus", "mod", "ram"; resets = <0x3 0x1e>; // 0x3==ccu // #define RST_BUS_CSI 30 pinctrl-names = "default"; pinctrl-0 = <0x27>; status = "okay"; phandle = <0x63>; port { #address-cells = <1>; #size-cells = <0>; // Parallel bus endpoint csi_from_ov5640: endpoint { remote-endpoint = <&ov5640_to_csi>; bus-width = <8>; data-shift = <2>; hsync-active = <1>; // Active high vsync-active = <0>; // Active low data-active = <1>; // Active high pclk-sample = <1>; // Rising }; }; }; // SDA = PE13 // SCK = PE12 // clock / resets // https://github.com/torvalds/linux/blob/master/include/dt-bindings/reset/sun8i-h3-ccu.h // https://github.com/torvalds/linux/blob/master/include/dt-bindings/clock/sun8i-h3-ccu.h i2c@1c2b400 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1c2b400 0x400>; interrupts = <0x0 0x8 0x4>; clocks = <0x3 0x3d>; // 0x03=ccu // #define CLK_BUS_I2C2 61 resets = <0x3 0x30>; // 0x03=ccu // #define RST_BUS_I2C2 48 pinctrl-names = "default"; pinctrl-0 = <0x23>; status = "okay"; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x60>; ov5640: camera@3c { compatible = "ovti,ov5640"; reg = <0x3c>; clocks = <&ccu 107>; // 0x3=&ccu #define CLK_CSI_MCLK 107 clock-names = "xclk"; assigned-clock-rates = <24000000>; assigned-clocks = <&ccu 107>; // 0x3=&ccu #define CLK_CSI_MCLK 107 pinctrl-names = "default"; reset-gpio = <0xc 4 14 1>; // PE14 // 0xc phandle pinctrl, GPIO_ACTIVE_LOW=1 pwdn-gpio = <0xc 4 15 0>; // PE15 // 0xc phandle pinctrl, GPIO_ACTIVE_HIGH=0 /* enable-gpios = <0xc 3 14 1>; // PD14 // 0xc phandle pinctrl, GPIO_ACTIVE_HIGH=0 #define GPIO_ACTIVE_HIGH 0 #define GPIO_ACTIVE_LOW 1 */ port { ov5640_to_csi: endpoint { remote-endpoint = <&csi_from_ov5640>; bus-width = <8>; data-shift = <2>; hsync-active = <1>; // Active high vsync-active = <0>; // Active low data-active = <1>; // Active high pclk-sample = <1>; // Rising }; }; }; }; /*i2c@1c2b400 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1c2b400 0x400>; interrupts = <0x0 0x8 0x4>; clocks = <0x3 0x3d>; resets = <0x3 0x30>; pinctrl-names = "default"; pinctrl-0 = <0x23>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x60>; };*/ /*camera@1cb0000 { compatible = "allwinner,sun8i-h3-csi", "allwinner,sun6i-a31-csi"; reg = <0x1cb0000 0x1000>; interrupts = <0x0 0x54 0x4>; clocks = <0x3 0x2d 0x3 0x6a 0x3 0x62>; clock-names = "bus", "mod", "ram"; resets = <0x3 0x1e>; pinctrl-names = "default"; pinctrl-0 = <0x27>; status = "disabled"; phandle = <0x63>; };*/ interrupt-controller@1c81000 { compatible = "arm,gic-400"; reg = <0x1c81000 0x1000 0x1c82000 0x2000 0x1c84000 0x2000 0x1c86000 0x2000>; interrupt-controller; #interrupt-cells = <0x3>; interrupts = <0x1 0x9 0xf04>; phandle = <0x1>; }; hdmi@1ee0000 { #sound-dai-cells = <0x0>; compatible = "allwinner,sun8i-h3-dw-hdmi", "allwinner,sun8i-a83t-dw-hdmi"; reg = <0x1ee0000 0x10000>; reg-io-width = <0x1>; interrupts = <0x0 0x58 0x4>; clocks = <0x3 0x2f 0x3 0x70 0x3 0x6f>; clock-names = "iahb", "isfr", "tmds"; resets = <0x3 0x21>; reset-names = "ctrl"; phys = <0x24>; phy-names = "hdmi-phy"; status = "okay"; phandle = <0x4>; ports { #address-cells = <0x1>; #size-cells = <0x0>; port@0 { reg = <0x0>; phandle = <0x61>; endpoint { remote-endpoint = <0x25>; phandle = <0x9>; }; }; port@1 { reg = <0x1>; phandle = <0x62>; endpoint { remote-endpoint = <0x26>; phandle = <0x33>; }; }; }; }; hdmi-phy@1ef0000 { compatible = "allwinner,sun8i-h3-hdmi-phy"; reg = <0x1ef0000 0x10000>; clocks = <0x3 0x2f 0x3 0x70 0x3 0x6>; clock-names = "bus", "mod", "pll-0"; resets = <0x3 0x20>; reset-names = "phy"; #phy-cells = <0x0>; phandle = <0x24>; }; rtc@1f00000 { compatible = "allwinner,sun6i-a31-rtc"; reg = <0x1f00000 0x54>; interrupts = <0x0 0x28 0x4 0x0 0x29 0x4>; phandle = <0x64>; }; clock@1f01400 { compatible = "allwinner,sun8i-h3-r-ccu"; reg = <0x1f01400 0x100>; clocks = <0x13 0x14 0x28 0x3 0x9>; clock-names = "hosc", "losc", "iosc", "pll-periph"; #clock-cells = <0x1>; #reset-cells = <0x1>; phandle = <0x29>; }; codec-analog@1f015c0 { compatible = "allwinner,sun8i-h3-codec-analog"; reg = <0x1f015c0 0x4>; phandle = <0x1d>; }; ir@1f02000 { compatible = "allwinner,sun5i-a13-ir"; clocks = <0x29 0x4 0x29 0xb>; clock-names = "apb", "ir"; resets = <0x29 0x0>; interrupts = <0x0 0x25 0x4>; reg = <0x1f02000 0x400>; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x2a>; phandle = <0x65>; }; i2c@1f02400 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x1f02400 0x400>; interrupts = <0x0 0x2c 0x4>; pinctrl-names = "default"; pinctrl-0 = <0x2b>; clocks = <0x29 0x9>; resets = <0x29 0x5>; status = "disabled"; #address-cells = <0x1>; #size-cells = <0x0>; phandle = <0x66>; }; pinctrl@1f02c00 { compatible = "allwinner,sun8i-h3-r-pinctrl"; reg = <0x1f02c00 0x400>; interrupts = <0x0 0x2d 0x4>; clocks = <0x29 0x3 0x13 0x14>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <0x3>; interrupt-controller; #interrupt-cells = <0x3>; phandle = <0x11>; ir { pins = "PL11"; function = "s_cir_rx"; phandle = <0x2a>; }; r-i2c { pins = "PL0", "PL1"; function = "s_i2c"; phandle = <0x2b>; }; }; thermal-sensor@1c25000 { compatible = "allwinner,sun8i-h3-ths"; reg = <0x1c25000 0x100>; clocks = <0x3 0x37 0x3 0x45>; clock-names = "bus", "mod"; resets = <0x3 0x2a>; #thermal-sensor-cells = <0x0>; #io-channel-cells = <0x0>; phandle = <0x2d>; }; gpu@1c40000 { compatible = "allwinner,sun8i-h3-mali", "arm,mali-400"; reg = <0x1c40000 0x10000>; interrupts = <0x0 0x61 0x4 0x0 0x62 0x4 0x0 0x63 0x4 0x0 0x64 0x4 0x0 0x66 0x4 0x0 0x67 0x4 0x0 0x65 0x4>; interrupt-names = "gp", "gpmmu", "pp0", "ppmmu0", "pp1", "ppmmu1", "pmu"; clocks = <0x3 0x31 0x3 0x72>; clock-names = "bus", "core"; resets = <0x3 0x23>; assigned-clocks = <0x3 0x72>; assigned-clock-rates = <0x16e36000>; phandle = <0x67>; }; }; opp_table0 { compatible = "operating-points-v2"; opp-shared; phandle = <0x2c>; opp@648000000 { opp-hz = <0x0 0x269fb200>; opp-microvolt = <0xfde80 0xfde80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@816000000 { opp-hz = <0x0 0x30a32c00>; opp-microvolt = <0x10c8e0 0x10c8e0 0x13d620>; clock-latency-ns = <0x3b9b0>; }; opp@1008000000 { opp-hz = <0x0 0x3c14dc00>; opp-microvolt = <0x124f80 0x124f80 0x13d620>; clock-latency-ns = <0x3b9b0>; }; }; cpus { #address-cells = <0x1>; #size-cells = <0x0>; cpu@0 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x0>; clocks = <0x3 0xe>; clock-names = "cpu"; operating-points-v2 = <0x2c>; #cooling-cells = <0x2>; phandle = <0x2f>; }; cpu@1 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x1>; operating-points-v2 = <0x2c>; }; cpu@2 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x2>; operating-points-v2 = <0x2c>; }; cpu@3 { compatible = "arm,cortex-a7"; device_type = "cpu"; reg = <0x3>; operating-points-v2 = <0x2c>; }; }; iio-hwmon { compatible = "iio-hwmon"; io-channels = <0x2d>; }; thermal-zones { cpu-thermal { polling-delay-passive = <0xfa>; polling-delay = <0x3e8>; thermal-sensors = <0x2d>; trips { cpu_warm { temperature = <0xfde8>; hysteresis = <0x7d0>; type = "passive"; phandle = <0x2e>; }; cpu_hot_pre { temperature = <0x11170>; hysteresis = <0x7d0>; type = "passive"; phandle = <0x30>; }; cpu_hot { temperature = <0x124f8>; hysteresis = <0x7d0>; type = "passive"; phandle = <0x31>; }; cpu_very_hot_pre { temperature = <0x14c08>; hysteresis = <0x7d0>; type = "passive"; phandle = <0x68>; }; cpu_very_hot { temperature = <0x15f90>; hysteresis = <0x7d0>; type = "passive"; phandle = <0x32>; }; cpu_crit { temperature = <0x19a28>; hysteresis = <0x7d0>; type = "critical"; phandle = <0x69>; }; }; cooling-maps { cpu_warm_limit_cpu { trip = <0x2e>; cooling-device = <0x2f 0xffffffff 0x2>; }; cpu_hot_pre_limit_cpu { trip = <0x30>; cooling-device = <0x2f 0x2 0x3>; }; cpu_hot_limit_cpu { trip = <0x31>; cooling-device = <0x2f 0x3 0x4>; }; cpu_very_hot_pre_limit_cpu { trip = <0x32>; cooling-device = <0x2f 0x5 0x6>; }; cpu_very_hot_limit_cpu { trip = <0x32>; cooling-device = <0x2f 0x7 0xffffffff>; }; }; }; }; timer { compatible = "arm,armv7-timer"; interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>; }; ahci-5v { compatible = "regulator-fixed"; regulator-name = "ahci-5v"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; regulator-boot-on; enable-active-high; gpio = <0xc 0x1 0x8 0x0>; status = "disabled"; phandle = <0x6a>; }; usb0-vbus { compatible = "regulator-fixed"; regulator-name = "usb0-vbus"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; enable-active-high; gpio = <0xc 0x3 0xb 0x0>; status = "okay"; phandle = <0x12>; }; usb1-vbus { compatible = "regulator-fixed"; regulator-name = "usb1-vbus"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; regulator-boot-on; enable-active-high; gpio = <0xc 0x7 0x6 0x0>; status = "disabled"; phandle = <0x6b>; }; usb2-vbus { compatible = "regulator-fixed"; regulator-name = "usb2-vbus"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; regulator-boot-on; enable-active-high; gpio = <0xc 0x7 0x3 0x0>; status = "disabled"; phandle = <0x6c>; }; vcc3v0 { compatible = "regulator-fixed"; regulator-name = "vcc3v0"; regulator-min-microvolt = <0x2dc6c0>; regulator-max-microvolt = <0x2dc6c0>; phandle = <0x6d>; }; vcc3v3 { compatible = "regulator-fixed"; regulator-name = "vcc3v3"; regulator-min-microvolt = <0x325aa0>; regulator-max-microvolt = <0x325aa0>; phandle = <0xb>; }; vcc5v0 { compatible = "regulator-fixed"; regulator-name = "vcc5v0"; regulator-min-microvolt = <0x4c4b40>; regulator-max-microvolt = <0x4c4b40>; phandle = <0x6e>; }; aliases { ethernet0 = "/soc/ethernet@1c30000"; serial0 = "/soc/serial@1c28000"; serial1 = "/soc/serial@1c28400"; }; connector { compatible = "hdmi-connector"; type = [61 00]; port { endpoint { remote-endpoint = <0x33>; phandle = <0x26>; }; }; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; pwr_led { label = "bananapi-m2-plus:red:pwr"; gpios = <0x11 0x0 0xa 0x0>; default-state = "on"; }; }; gpio_keys { compatible = "gpio-keys"; pinctrl-names = "default"; sw4 { label = "power"; linux,code = <0x100>; gpios = <0x11 0x0 0x3 0x1>; }; }; gmac-3v3 { compatible = "regulator-fixed"; regulator-name = "gmac-3v3"; regulator-min-microvolt = <0x325aa0>; regulator-max-microvolt = <0x325aa0>; startup-delay-us = <0x186a0>; enable-active-high; gpio = <0xc 0x3 0x6 0x0>; phandle = <0x17>; }; wifi_pwrseq { compatible = "mmc-pwrseq-simple"; pinctrl-names = "default"; reset-gpios = <0x11 0x0 0x7 0x1>; phandle = <0xe>; }; __symbols__ { sound_hdmi = "/sound"; osc24M = "/clocks/osc24M_clk"; osc32k = "/clocks/osc32k_clk"; iosc = "/clocks/internal-osc-clk"; de = "/display-engine"; display_clocks = "/soc/clock@1000000"; mixer0 = "/soc/mixer@1100000"; mixer0_out = "/soc/mixer@1100000/ports/port@1"; mixer0_out_tcon0 = "/soc/mixer@1100000/ports/port@1/endpoint"; syscon = "/soc/syscon@1c00000"; dma = "/soc/dma-controller@1c02000"; tcon0 = "/soc/lcd-controller@1c0c000"; tcon0_in = "/soc/lcd-controller@1c0c000/ports/port@0"; tcon0_in_mixer0 = "/soc/lcd-controller@1c0c000/ports/port@0/endpoint"; tcon0_out = "/soc/lcd-controller@1c0c000/ports/port@1"; tcon0_out_hdmi = "/soc/lcd-controller@1c0c000/ports/port@1/endpoint@1"; mmc0 = "/soc/mmc@1c0f000"; mmc1 = "/soc/mmc@1c10000"; brcmf = "/soc/mmc@1c10000/wifi@1"; mmc2 = "/soc/mmc@1c11000"; usb_otg = "/soc/usb@1c19000"; sid = "/soc/eeprom@01c14000"; usbphy = "/soc/phy@1c19400"; ehci0 = "/soc/usb@1c1a000"; ohci0 = "/soc/usb@1c1a400"; ehci1 = "/soc/usb@1c1b000"; ohci1 = "/soc/usb@1c1b400"; ehci2 = "/soc/usb@1c1c000"; ohci2 = "/soc/usb@1c1c400"; ehci3 = "/soc/usb@1c1d000"; ohci3 = "/soc/usb@1c1d400"; ccu = "/soc/clock@1c20000"; pio = "/soc/pinctrl@1c20800"; csi_pins = "/soc/pinctrl@1c20800/csi"; emac_rgmii_pins = "/soc/pinctrl@1c20800/emac0"; i2c0_pins = "/soc/pinctrl@1c20800/i2c0"; i2c1_pins = "/soc/pinctrl@1c20800/i2c1"; i2c2_pins = "/soc/pinctrl@1c20800/i2c2"; i2s0_pins = "/soc/pinctrl@1c20800/i2s0"; i2s1_pins = "/soc/pinctrl@1c20800/i2s1"; mmc0_pins = "/soc/pinctrl@1c20800/mmc0"; mmc1_pins = "/soc/pinctrl@1c20800/mmc1"; mmc2_8bit_pins = "/soc/pinctrl@1c20800/mmc2_8bit"; spdif_tx_pins_a = "/soc/pinctrl@1c20800/spdif"; spi0_pins = "/soc/pinctrl@1c20800/spi0"; spi1_pins = "/soc/pinctrl@1c20800/spi1"; uart0_pins_a = "/soc/pinctrl@1c20800/uart0"; uart1_pins = "/soc/pinctrl@1c20800/uart1"; uart1_rts_cts_pins = "/soc/pinctrl@1c20800/uart1_rts_cts"; uart2_pins = "/soc/pinctrl@1c20800/uart2"; uart3_pins = "/soc/pinctrl@1c20800/uart3"; uart3_rts_cts_pins = "/soc/pinctrl@1c20800/uart3_rts_cts"; emac = "/soc/ethernet@1c30000"; mdio = "/soc/ethernet@1c30000/mdio"; internal_mdio = "/soc/ethernet@1c30000/mdio-mux/mdio@1"; int_mii_phy = "/soc/ethernet@1c30000/mdio-mux/mdio@1/ethernet-phy@1"; external_mdio = "/soc/ethernet@1c30000/mdio-mux/mdio@2"; ext_rgmii_phy = "/soc/ethernet@1c30000/mdio-mux/mdio@2/ethernet-phy@1"; spi0 = "/soc/spi@1c68000"; spi1 = "/soc/spi@1c69000"; wdt0 = "/soc/watchdog@1c20ca0"; spdif = "/soc/spdif@1c21000"; pwm = "/soc/pwm@1c21400"; i2s0 = "/soc/i2s@1c22000"; i2s1 = "/soc/i2s@1c22400"; i2s2 = "/soc/i2s@1c22800"; codec = "/soc/codec@1c22c00"; uart0 = "/soc/serial@1c28000"; uart1 = "/soc/serial@1c28400"; uart2 = "/soc/serial@1c28800"; uart3 = "/soc/serial@1c28c00"; i2c0 = "/soc/i2c@1c2ac00"; i2c1 = "/soc/i2c@1c2b000"; i2c2 = "/soc/i2c@1c2b400"; gic = "/soc/interrupt-controller@1c81000"; hdmi = "/soc/hdmi@1ee0000"; hdmi_in = "/soc/hdmi@1ee0000/ports/port@0"; hdmi_in_tcon0 = "/soc/hdmi@1ee0000/ports/port@0/endpoint"; hdmi_out = "/soc/hdmi@1ee0000/ports/port@1"; hdmi_out_con = "/soc/hdmi@1ee0000/ports/port@1/endpoint"; hdmi_phy = "/soc/hdmi-phy@1ef0000"; csi = "/soc/camera@1cb0000"; rtc = "/soc/rtc@1f00000"; r_ccu = "/soc/clock@1f01400"; codec_analog = "/soc/codec-analog@1f015c0"; ir = "/soc/ir@1f02000"; r_i2c = "/soc/i2c@1f02400"; r_pio = "/soc/pinctrl@1f02c00"; ir_pins_a = "/soc/pinctrl@1f02c00/ir"; r_i2c_pins = "/soc/pinctrl@1f02c00/r-i2c"; ths = "/soc/thermal-sensor@1c25000"; mali = "/soc/gpu@1c40000"; cpu0_opp_table = "/opp_table0"; cpu0 = "/cpus/cpu@0"; cpu_warm = "/thermal-zones/cpu-thermal/trips/cpu_warm"; cpu_hot_pre = "/thermal-zones/cpu-thermal/trips/cpu_hot_pre"; cpu_hot = "/thermal-zones/cpu-thermal/trips/cpu_hot"; cpu_very_hot_pre = "/thermal-zones/cpu-thermal/trips/cpu_very_hot_pre"; cpu_very_hot = "/thermal-zones/cpu-thermal/trips/cpu_very_hot"; cpu_crit = "/thermal-zones/cpu-thermal/trips/cpu_crit"; reg_ahci_5v = "/ahci-5v"; reg_usb0_vbus = "/usb0-vbus"; reg_usb1_vbus = "/usb1-vbus"; reg_usb2_vbus = "/usb2-vbus"; reg_vcc3v0 = "/vcc3v0"; reg_vcc3v3 = "/vcc3v3"; reg_vcc5v0 = "/vcc5v0"; hdmi_con_in = "/connector/port/endpoint"; reg_gmac_3v3 = "/gmac-3v3"; wifi_pwrseq = "/wifi_pwrseq"; }; }; Still does not work at start, because it does not set power enable pin, still have to set i manually: #define SUNXI_PD_BASE 96 #define SUNXI_PE_BASE 128 # POWER ENABLE = 1 PIN PD14echo "110" > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio110/direction echo "1" > /sys/class/gpio/gpio110/value # CSI PWDN = 0 (no power down), PIN PE15echo "143" > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio143/direction echo "0" > /sys/class/gpio/gpio143/value check if it worked, load modul again: root@bananapim2plus:~# modprobe ov5640 [ 1594.303237] ov5640 1-003c: 1-003c supply DOVDD not found, using dummy regulator [ 1594.303349] ov5640 1-003c: 1-003c supply DVDD not found, using dummy regulator [ 1594.303442] ov5640 1-003c: 1-003c supply AVDD not found, using dummy regulator [ 1594.335815] ov5640_find_mode fps=1 width=1280 height=720 nearest=1 root@bananapim2plus:~# v4l2-ctl -d /dev/video0 -D Driver Info (not using libv4l2): Driver name : sun6i-video Card type : sun6i-csi Bus info : platform:csi Driver version: 4.18.11 Capabilities : 0x84200001 Video Capture Streaming Extended Pix Format Device Capabilities Device Caps : 0x04200001 Video Capture Streaming Extended Pix Format root@bananapim2plus:~# v4l2-ctl --all -d /dev/video0 Driver Info (not using libv4l2): Driver name : sun6i-video Card type : sun6i-csi Bus info : platform:csi Driver version: 4.18.11 Capabilities : 0x84200001 Video Capture Streaming Extended Pix Format Device Capabilities Device Caps : 0x04200001 Video Capture Streaming Extended Pix Format Priority: 2 Video input : 0 (ov5640 1-003c: ok) Format Video Capture: Width/Height : 1280/720 Pixel Format : 'UYVY' Field : Unknown (001fffff) Bytes per Line : 2560 Size Image : 1843200 Colorspace : sRGB Transfer Function : sRGB YCbCr/HSV Encoding: ITU-R 601 Quantization : Full Range Flags : c0caee48 User Controls contrast (int) : min=0 max=255 step=1 default=0 value=0 flags=slider saturation (int) : min=0 max=255 step=1 default=64 value=64 flags=slider hue (int) : min=0 max=359 step=1 default=0 value=0 flags=slider white_balance_automatic (bool) : default=1 value=1 flags=update red_balance (int) : min=0 max=4095 step=1 default=0 value=0 flags=inactive, slider blue_balance (int) : min=0 max=4095 step=1 default=0 value=0 flags=inactive, slider exposure (int) : min=0 max=65535 step=1 default=0 value=1 flags=inactive, volatile gain_automatic (bool) : default=1 value=1 flags=update gain (int) : min=0 max=1023 step=1 default=0 value=22 flags=inactive, volatile power_line_frequency (menu) : min=0 max=3 default=1 value=1 Camera Controls auto_exposure (menu) : min=0 max=1 default=0 value=0 flags=update Image Processing Controls test_pattern (menu) : min=0 max=1 default=0 value=0 cap example from github did not work for me, have to find out why root@bananapim2plus:~/cap-v4l2# ./cap 1280 720 4 1 -999 -1 -1 https://github.com/avafinger/gc2035/issues/4 ---- cap parameters ----- width: 1280 height: 720 v4l2 buffers: 4 exposure: -999 hflip: -1 vflip: -1 Mode: V4L2_MODE_VIDEO Driver: "sun6i-video" Card: "sun6i-csi" Bus: "platform:csi" Version: 1.0 Capabilities: 84200001 Input: 0 v4l2: unable to set stream parm. v4l2: failed to init camera. python example worked (= https://stackoverflow.com/questions/48793174/why-is-my-ov5640-camera-picture-vertical-bars-when-using-python-and-opencv Finally got a picture (:
@lex Posted October 3, 2018 Posted October 3, 2018 On 10/3/2018 at 12:49 PM, xeniter said: cap example from github did not work for me, have to find out why root@bananapim2plus:~/cap-v4l2# ./cap 1280 720 4 1 -999 -1 -1 https://github.com/avafinger/gc2035/issues/4 Expand The reason is the cap-v4l2 expects YUV420 and the driver delivers YUYV. Change the format and you will be fine.
