man-FIRE Posted October 8, 2018 Posted October 8, 2018 Hello, I love armbian and I know the gpio is working on the directory /sys/class/gpio/gpio(number) but I really need to use armbian + the gpio module gpio-sunxi modprobe gpio-sunxi ls /sys/class/gpio_sw/ normal_led PA10 PA13 PA18 PA20 PA6 PA9 PC2 PC7 PG7 PL10 PA0 PA11 PA14 PA19 PA21 PA7 PC0 PC3 PD14 PG8 standby_led PA1 PA12 PA15 PA2 PA3 PA8 PC1 PC4 PG6 PG9 echo 1 > /sys/class/gpio_sw/standby_led/data echo 0 > /sys/class/gpio_sw/standby_led/data is it possible to active this module with kernel 3 or 4, if yes where is possible to enable it ? in the kernel config ?
chwe Posted October 8, 2018 Posted October 8, 2018 From the title: pi zero H2 So then it's placed in the wrong sub-forum. Do you plan to use BSP 3.4 Kernel or 4.x mainline? (depending on this I'll move it in the right sub-forum). In mainline GPIOs are handled either by sysFS (deprecated) or libgpiod. If you plan to have something 'future-proof' you should consider switch to a libgpiod based approach.
man-FIRE Posted October 8, 2018 Author Posted October 8, 2018 BSP 3.4 Kernel with sysFS (deprecated) give me the option to active modprobe gpio-sunxi ?
chwe Posted October 9, 2018 Posted October 9, 2018 https://github.com/armbian/build/blob/53acd5be582d53b87d8cfd01f35633b159b4ca3f/config/kernel/linux-sun8i-default.config#L2014-L2016 with the 3.4 kernel you can use GPIO-sunxi and sysfs: https://github.com/armbian/build/blob/53acd5be582d53b87d8cfd01f35633b159b4ca3f/config/kernel/linux-sun8i-default.config#L1979 but 3.4 is an old kernel, and if your board doesn't do any hw accelerated videodecoding I would go for a recent 4.14.y kernel with armbian next were we still offer sysfs and additionally you've the opportunity to use libgpiod.
