Hello,
I love armbian and I know the gpio is working on the directory /sys/class/gpio/gpio(number) but I really need to use armbian + the gpio module gpio-sunxi
modprobe gpio-sunxi
ls /sys/class/gpio_sw/
normal_led  PA10  PA13    PA18  PA20  PA6  PA9  PC2  PC7     PG7  PL10
PA0        PA11  PA14    PA19  PA21  PA7  PC0  PC3  PD14  PG8  standby_led
PA1        PA12  PA15    PA2   PA3   PA8  PC1  PC4  PG6     PG9
echo 1 > /sys/class/gpio_sw/standby_led/data
echo 0 > /sys/class/gpio_sw/standby_led/data
is it possible to active this module with kernel 3 or 4, if yes where is possible to enable it ? in the kernel config ?
From the title: pi zero H2
So then it's placed in the wrong sub-forum. Do you plan to use BSP 3.4 Kernel or 4.x mainline? (depending on this I'll move it in the right sub-forum).
In mainline GPIOs are handled either by sysFS (deprecated) or libgpiod. If you plan to have something 'future-proof'  you should consider switch to a libgpiod based approach.
https://github.com/armbian/build/blob/53acd5be582d53b87d8cfd01f35633b159b4ca3f/config/kernel/linux-sun8i-default.config#L2014-L2016
with the 3.4 kernel you can use GPIO-sunxi and sysfs:
https://github.com/armbian/build/blob/53acd5be582d53b87d8cfd01f35633b159b4ca3f/config/kernel/linux-sun8i-default.config#L1979
but 3.4 is an old kernel, and if your board doesn't do any hw accelerated videodecoding I would go for a recent 4.14.y kernel with armbian next were we still offer sysfs and additionally you've the opportunity to use libgpiod.
