blub4747 Posted October 13, 2018 Posted October 13, 2018 Hi guys, I just started using the new Armbian release on my cubietruck and Banana Pi boards and encountered the following problem. On the Cubieboard the wired interface first did not receive any IP address at all. I than tried as alternative to connect the wireless interface through the armbian-config tool. Which did work fine. However the wired interface is now receiving the same IP address like the wireless one. Currently the only way to resolve this issue is by going again through armbian config tool. I am also experiencing the symptoms on my banana pi board except that it does not have any wireless interface. Which therefore means that I need to access the main console via USB keyboard and use the armbian-config tool. Can you guys please help me to permanently resolve this issue? Thank you, blub4747 Quote lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 18.04.1 LTS Release: 18.04 Codename: bionic
StevePi Posted October 15, 2018 Posted October 15, 2018 (edited) Hi, had the same problem here with bananapi. The LAN interface got no IPV4 Address, only IPV6 (over DHCP). I have removed networkmanager and assigned a static IPv4 Address in my router for the BPi board. That solved my problem. This is only a workaround, not a solution. I think the problem should be reproducible with the current Armbian distro. Steve Edited October 15, 2018 by StevePi
blub4747 Posted October 17, 2018 Author Posted October 17, 2018 Hi there, I solved the problem by building my own images by using the armbian build machine and the problem is gone is since than. Thank you anyway for your feedback.
Aekei8ei Posted October 17, 2018 Posted October 17, 2018 Hello, equally to StevePi in another thread, my Banana Pi does not get an IPv4 from LAN port DHCP. Armbian Version is 5.59 + apt full-upgrade. If I use nmcli to manually set the IPv4 to DHCP, it works until reboot. Anybody experienced similar behaviour?
