Changes in memory to improve browsing
I have a samsumg evo sdcard, one of the tops in performance according to
So trying this with very slow sd cards probably wont produce a benefit
Im using balbes 5.55 armbian
I installed a swapfile with 2G ,  with
sudo apt-get install dphys-swapfile
sudo vim /etc/dphys-swapfile
look for
#CONF_SWAPSIZE=
and change for
CONF_SWAPSIZE=2000
then restart the system or
sudo dphys-swapfile swapon
It can take seconds (in my samsung evo) or 20 minutes (on an old kingston and raspberry pi running raspbian), so dont worry if it takes half hour
the first run needs to create the swapfile, and its huge
my beelink gt1 ultimate comes with 3 GB of ram, but i was only able to boot it using a dtb (meson-gxm-q200.dtb) that gives me 2 GB, so when i open 10 tabs in my browser i start with problems and freezes.... i know, its too much, but im used to it, so doing this im able to browser better
the swapfile will start at boot every time as service, so you dont have to enter any command after this
As pointed by talraash
Worth adding a warning. For everyone who wants to use it. Using a swap on a microsd will significantly increase its wear, and reduced life of you card.
Edited by migg
good warning about sd life
another change to gain a bit more of memory is
vim .config/psd/psd.conf
look for
#USE_OVERLAYFS="no"
and change for
USE_OVERLAYFS="yes"
you can restart the system, or close your browser and
systemctl --user stop psd.service
systemctl --user start psd.service
More info about this
https://wiki.archlinux.org/index.php/Profile-sync-daemon#What_is_overlayfs_mode.3F
Worth adding a warning. For everyone who wants to use it. Using a swap on a microsd will significantly increase its wear, and may reduced life of you card.
I agree, the more you use it the closer you get to its end,  but i haven experienced that with my kingston, and i ran it on a raspberry pi with raspbian for almost 3 years, with only 1 GB of ram, so i swapped a lot
and i have the beelink gt1 ultimate+samsumg evo since july working all day, and still endures it, when it stop working i will have to buy another evo 32 GB for 7-8 euros and rethink the use of the swap file, for now im looking to use it according to my needs... and stressing it only some times.
