migg Posted October 21, 2018 Posted October 21, 2018 (edited) I have a samsumg evo sdcard, one of the tops in performance according to So trying this with very slow sd cards probably wont produce a benefit Im using balbes 5.55 armbian I installed a swapfile with 2G , with sudo apt-get install dphys-swapfile sudo vim /etc/dphys-swapfile look for #CONF_SWAPSIZE= and change for CONF_SWAPSIZE=2000 then restart the system or sudo dphys-swapfile swapon It can take seconds (in my samsung evo) or 20 minutes (on an old kingston and raspberry pi running raspbian), so dont worry if it takes half hour the first run needs to create the swapfile, and its huge my beelink gt1 ultimate comes with 3 GB of ram, but i was only able to boot it using a dtb (meson-gxm-q200.dtb) that gives me 2 GB, so when i open 10 tabs in my browser i start with problems and freezes.... i know, its too much, but im used to it, so doing this im able to browser better the swapfile will start at boot every time as service, so you dont have to enter any command after this As pointed by talraash Quote Worth adding a warning. For everyone who wants to use it. Using a swap on a microsd will significantly increase its wear, and reduced life of you card. Expand Edited October 21, 2018 by migg good warning about sd life
migg Posted October 21, 2018 Author Posted October 21, 2018 another change to gain a bit more of memory is vim .config/psd/psd.conf look for #USE_OVERLAYFS="no" and change for USE_OVERLAYFS="yes" you can restart the system, or close your browser and systemctl --user stop psd.service systemctl --user start psd.service More info about this https://wiki.archlinux.org/index.php/Profile-sync-daemon#What_is_overlayfs_mode.3F https://wiki.archlinux.org/index.php/Profile-sync-daemon
talraash Posted October 21, 2018 Posted October 21, 2018 Worth adding a warning. For everyone who wants to use it. Using a swap on a microsd will significantly increase its wear, and may reduced life of you card.
migg Posted October 21, 2018 Author Posted October 21, 2018 On 10/21/2018 at 4:25 PM, talraash said: Worth adding a warning. For everyone who wants to use it. Using a swap on a microsd will significantly increase its wear, and reduced life of you card. Expand I agree, the more you use it the closer you get to its end, but i haven experienced that with my kingston, and i ran it on a raspberry pi with raspbian for almost 3 years, with only 1 GB of ram, so i swapped a lot and i have the beelink gt1 ultimate+samsumg evo since july working all day, and still endures it, when it stop working i will have to buy another evo 32 GB for 7-8 euros and rethink the use of the swap file, for now im looking to use it according to my needs... and stressing it only some times.
