MEMEs Posted November 10, 2018 Posted November 10, 2018 Hi there, I have set up a tinkerboard S and I'm loving armbian so far. I only just encountered a weird problem. When i try to code in spyder3 there seems to be a messup in the keys i press and the key that is produced in spyder3. The funny thing is that this only occurs in spyder. When I type in terminal or gummi everything works fine. I am connecting to my TB using vnc using X. I've googled a bit around and found this could be a error of the XKEYBOARD as written here (I am however still not sure): https://github.com/spyder-ide/spyder/issues/3713 However I cant apply the proposed solution. I've found i need to go to /etc/X11/xorg.conf.d/01-armbian-defaults.conf But this file only has the following contents: Section "Monitor" Identifier "Monitor0" Option "DPMS" "false" EndSection Section "ServerFlags" Option "BlankTime" "0" Option "StandbyTime" "0" Option "SuspendTime" "0" Option "OffTime" "0" EndSection Does anyone have the idea where i can enable the XKEYBOARD feauture? And should this even be the correct solution? Thank you in advance,
