Hallo dear friend, I am a beginner . I bought a banana pi h3, I tried to turn it on, powering it to 5 volts, I connected mouse, keyboard, and monitor (with hdmi-vga adapter) but not signs of life, only the red LED is on , os image is loaded in sd card.
I tried to press the on and reset buttons but nothing.
I hope you can help me. Many thanks. Daniele.
  • Tido changed the title to Banana pi with H3 not running
https://www.ebay.it/itm/Banana-Pi-BPI-M2-H3-Mini-Quad-Core-H3-Single-Board-Compu/273470048891?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Thank you for the answer,This is the model of banana pi that i have purchased, i don't understand when I turn on the banana, nothing happens, only the red LED lights up, the monitor stays off, and I do not even see the wifi signal on the router.
Maybe the banana is worse or I'm wrong about the procedure?
Ok thank you, but my question is as follows:
the banana pi without so the monitor turns it on o no? My monitor remains off, and also wifi signal is not there.If I was wrong to load so on sd card,the banana pi at least the monitor should turn on?
