cam Posted November 20, 2018 Posted November 20, 2018 I haven't had any luck getting the ov5640 camera module working with the nanopi air. I have compiled the latest dev version of bionic and enabled the ov5640 as a module in menuconfig. I currently cannot get it showing up under /dev/video* Any ideas?
@lex Posted November 20, 2018 Posted November 20, 2018 A couple of things to check: * check if ov5640 and csi are loaded. dmesg|grep 5640 & dmesg|grep csi * check if you have the correct camera module
cam Posted November 21, 2018 Author Posted November 21, 2018 Thanks for your reply! I double checked I definitely have the cam500b. This is the output of: dmesg|grep 5640 & dmesg|grep csi root@nanopiair:~# dmesg|grep 5640 & dmesg|grep csi [1] 1425 [ 8.895031] ov5640 0-003c: Linked as a consumer to regulator.5 [ 8.895101] ov5640 0-003c: Linked as a consumer to regulator.6 [ 8.895156] ov5640 0-003c: Linked as a consumer to regulator.4 [1]+ Done dmesg | grep --color=auto 5640 It looks like the ov5640 driver has loaded but not the CSI?
Lubo Posted November 22, 2018 Posted November 22, 2018 Hello cam, I managed to get the camera module ov3640 working with the NanoPi M1 and OrangePi PC+ on armbian with Ubuntu xenial (3.4.113). A driver for the ov3640 is missing there, so I used a driver for the ov5640 with some modifications. In addition, I had to change a section [csi0] in the /boot/script.bin (it's a symbolic link) file. You can convert the linked BIN file (probably /boot/bin/nanopiair.bin) to readable FEX file by command bin2fex. You can edit the FEX file and convert it back to BIN file by command fex2bin. For more information just visit http://linux-sunxi.org/Fex_Guide In the section csi_gpio_configuration of that page you can see something like this: [csi0] vip_used = 1 vip_mode = 0 vip_dev_qty = 1 vip_define_sensor_list = 0 vip_csi_pck = port:PE00<2><default><default><default> vip_csi_mck = port:PE01<2><default><default><default> vip_csi_hsync = port:PE02<2><default><default><default> vip_csi_vsync = port:PE03<2><default><default><default> vip_csi_d0 = port:PE04<2><default><default><default> vip_csi_d1 = port:PE05<2><default><default><default> vip_csi_d2 = port:PE06<2><default><default><default> vip_csi_d3 = port:PE07<2><default><default><default> vip_csi_d4 = port:PE08<2><default><default><default> vip_csi_d5 = port:PE09<2><default><default><default> vip_csi_d6 = port:PE10<2><default><default><default> vip_csi_d7 = port:PE11<2><default><default><default> vip_csi_sck = port:PE12<2><default><default><default> vip_csi_sda = port:PE13<2><default><default><default> vip_dev0_mname = "ov3640" vip_dev0_pos = "front" vip_dev0_lane = 1 vip_dev0_twi_id = 2 vip_dev0_twi_addr = 120 vip_dev0_isp_used = 0 vip_dev0_fmt = 0 vip_dev0_stby_mode = 0 vip_dev0_vflip = 1 vip_dev0_hflip = 0 vip_dev0_iovdd = "" vip_dev0_iovdd_vol = 2800000 vip_dev0_avdd = "" vip_dev0_avdd_vol = 2800000 vip_dev0_dvdd = "" vip_dev0_dvdd_vol = 1800000 vip_dev0_afvdd = "" vip_dev0_afvdd_vol = 2800000 vip_dev0_power_en = port:PA17<1><default><default><1> vip_dev0_reset = port:PE14<1><default><default><1> vip_dev0_pwdn = port:PE15<1><default><default><0> vip_dev0_flash_en = vip_dev0_flash_mode = vip_dev0_af_pwdn = vip_dev0_act_used = 0 vip_dev0_act_name = "ad5820_act" vip_dev0_act_slave = 24 This is a configuration for the CSI interface. Note the important properties: vip_dev0_mname - kernel module name, in my case it is ov3640. You should set it to ov5640. vip_dev0_twi_addr - I2C (TWI) address of your I2C device. For the OV5640 it is 0x78 but must be set in decimals which is 120. Everything else should be left as it was. After changing the FEX file you have to convert it back to the BIN file and store it at the same location as before. Then reboot is needed. Afterwards, you need to load the modules: # modprobe ov5640 vfe_v4l2 Also you can check system logs to see more information: # dmesg Hopefully, I helped you Good luck!
@lex Posted November 22, 2018 Posted November 22, 2018 (edited) On 11/20/2018 at 11:20 PM, cam said: It looks like the ov5640 driver has loaded but not the CSI? I was looking for errors, CSI does not really show up in dmesg. Seems no errors. I think more info is needed so others can help: armbianmonitor -u PS: You should have something similar to this depending on how is your kernel defconfig: Module Size Used by sun6i_csi 24576 0 videobuf2_dma_contig 20480 1 sun6i_csi ov5640 32768 1 videobuf2_memops 16384 1 videobuf2_dma_contig videobuf2_v4l2 20480 1 sun6i_csi v4l2_fwnode 16384 2 ov5640,sun6i_csi videobuf2_common 36864 2 sun6i_csi,videobuf2_v4l2 v4l2_common 16384 1 ov5640 videodev 139264 6 ov5640,v4l2_fwnode,v4l2_common,videobuf2_common,sun6i_csi,videobuf2_v4l2 sunxi_cir 16384 0 media 24576 3 ov5640,videodev,sun6i_csi hci_uart 36864 0 btintel 16384 1 hci_uart bluetooth 327680 2 hci_uart,btintel ecdh_generic 28672 1 bluetooth brcmfmac 188416 0 brcmutil 16384 1 brcmfmac ipv6 397312 18 Edited November 22, 2018 by @lex modules loaded as reference
gnarmbiac Posted December 14, 2018 Posted December 14, 2018 OS: Armbian_5.67_Nanopiair_Ubuntu_xenial_next_4.14.88.img, Ubuntu 16.04.5 LTS Trying to get the CAM500B working with ov5640. Nothing looks anything like what's been described here. No sign of 5640 or csi in dmesg. No /dev/video0. No vfe_v4l2 module available. No /boot/script.bin. No /boot/bin/nanopiair.bin. cir, i2c, spi are active from armbian-config. I have /lib/modules/4.14.88-sunxi/kernel/drivers/media/i2c/ov5640.ko It loads (modprobe). Nothing changes in dmesg. Any clues much appreciated!
