nopnop2002 Posted December 9, 2018 Share Posted December 9, 2018 Hello. I added overlays=pwm to /boot/armbianEnv.txt and reboot system. $ cat /boot/armbianEnv.txt verbosity=1 logo=disabled console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 rootdev=UUID=3d863bb3-b616-4229-94e7-8c92ac95501a rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u overlays=pwm Armbian can't boot-up. ** Unable to read "/boot/boot.env" from mmc0:1 ** Failed (-5) In: serial Out: serial Err: serial Net: phy interface0 eth0: ethernet@1c30000 230454 bytes read in 23 ms (9.6 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 USB4: USB EHCI 1.00 USB5: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning bus 4 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3708 bytes read in 18 ms (201.2 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 214 bytes read in 15 ms (13.7 KiB/s) 5104363 bytes read in 264 ms (18.4 MiB/s) 6985408 bytes read in 359 ms (18.6 MiB/s) Found mainline kernel configuration 32108 bytes read in 60 ms (522.5 KiB/s) 884 bytes read in 130 ms (5.9 KiB/s) Applying kernel provided DT overlay sun8i-h3-pwm.dtbo 4179 bytes read in 127 ms (31.3 KiB/s) Applying kernel provided DT fixup script (sun8i-h3-fixup.scr) ## Executing script at 44000000 Warning: Disabling ttyS0 console due to enabled PWM overlay ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5104299 Bytes = 4.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Ramdisk to 49b21000, end 49fff2ab ... OK reserving fdt memory region: addr=43000000 size=6e000 Loading Device Tree to 49ab0000, end 49b20fff ... OK Starting kernel ... System information $ cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepipc BOARD_NAME="Orange Pi PC" BOARDFAMILY=sun8i VERSION=5.65 LINUXFAMILY=sunxi BRANCH=next ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage Can't I use sun8i-h3-pwm.dtbo? Link to comment Share on other sites More sharing options...
nopnop2002 Posted December 10, 2018 Author Share Posted December 10, 2018 I was wrong. I used USB-TTL converter with a debugg port. When I remove USB-TTL converter,my SG90 work perfect. #!/bin/bash #Export PWM channel for user control. sudo sh -c "echo 0 > /sys/class/pwm/pwmchip0/export" #Select the period of PWM signal. Value is in nanoseconds. sudo sh -c "echo 20000000 > /sys/class/pwm/pwmchip0/pwm0/period" #Change the polarity of the PWM signal. #The polarity can only be changed if the PWM is not enabled. sudo sh -c "echo "normal" > /sys/class/pwm/pwmchip0/pwm0/polarity" #Enable the PWM signal. sudo sh -c "echo 1 > /sys/class/pwm/pwmchip0/pwm0/enable" #Select the duty cycle. Value is in nanoseconds and must be less than the period. #Move to Center sudo sh -c "echo 1450000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle" sleep 2 #Move to Angle +90 sudo sh -c "echo 2350000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle" sleep 2 #Move to Angle -90 sudo sh -c "echo 600000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle" sleep 2 #Move to Center sudo sh -c "echo 1450000 > /sys/class/pwm/pwmchip0/pwm0/duty_cycle" sleep 2 #Disable the PWM signal. sudo sh -c "echo 0 > /sys/class/pwm/pwmchip0/pwm0/enable" #UnExport PWM channel for user control. sudo sh -c "echo 0 > /sys/class/pwm/pwmchip0/unexport" Link to comment Share on other sites More sharing options...
