moved to community forums cause BPi M2 Zero is officially not supported.
On 12/11/2018 at 5:16 PM, adiif1 said:
Is already building 4 images and none works: /
all on default settings
without boot-logs there's nothing I'm willing to do. You've to solder the 3 UART pins and then attach an USB-UART to get an output during boot.
:O
but hdmi no work ? :d
U-Boot SPL 2018.05-armbian (Dec 11 2018 - 23:49:46 +0100)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2018.05-armbian (Dec 11 2018 - 23:49:46 +0100) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Banana Pi BPI-M2-Zero
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
Failed (-5)
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
230454 bytes read in 22 ms (10 MiB/s)
starting USB...
No controllers found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3798 bytes read in 12 ms (308.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
201 bytes read in 10 ms (19.5 KiB/s)
4917465 bytes read in 256 ms (18.3 MiB/s)
6904160 bytes read in 354 ms (18.6 MiB/s)
28663 bytes read in 46 ms (608.4 KiB/s)
4155 bytes read in 94 ms (43 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    4917401 Bytes = 4.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49b4f000, end 49fff899 ... OK
   reserving fdt memory region: addr=43000000 size=6d000
   Loading Device Tree to 49adf000, end 49b4efff ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Debian GNU/Linux 9 bananapim2zero ttyS0
Edited by Tido
added spoiler
no idea, never tested.. I patched it in so that it has at least csc support but I'm not interested in HDMI and I've no display spare to test it on mine..
hmm okey, thanx
next bug? power led no turn on
The current dev and next images (kernel 4.19 and 4.20, resp.) I have built using the armbian build system worked instantly with the BPi M2 Zero. Very nice!
However, I could not get cpu frequency scaling to work. Is there a hint how to get it working?
Edited by Hans Heukenkamp
typo
On 9/1/2019 at 9:41 PM, ProDigit said:
I'll have this board (on preorder), and want to be kept in the loop for updates!
with the green + in the  right upper corner you can follow a thread without even writing in it. :P
just out of curiosity.. what use-case do you have for the board?
