Hi - I'm running kernel 4.18.8-odroidc2 under stretch and I've installed
  linux-headers-next-odroidc2
  linux-source-4.18.8-next-odroidc2
where the kernel image was
  linux-image-next-odroidc2
The system in general rocks  - I was worried about not being able to use my RTL8812AU in the monitor mode - but it works!
But I have 2 issues with 4.18.8-odroidc2, first the RTC PCF8563 module.
The .config file includes the following entries
  CONFIG_RTC_DRV_PCF85363=m
  # CONFIG_RTC_DRV_PCF8563 is not set
The Odroid C2 RTC shield is the one not set, namely, the PCF8563
See
  https://www.hardkernel.com/shop/rtc-shield/
Now if I try to build the loadable module
  make ARCH=arm64 scripts
  make ARCH=arm64 distclean
the last command generates the following error
  scripts/Makefile.clean:15: drivers/gpu/drm/nouveau/Makefile: No such file or director
and if I just type
 make ARCH=arm64
make[1]: *** No rule to make target 'arch/arm64/kernel/vdso/gettimeofday.S', needed by 'arch/arm64/kernel/vdso/gettimeofday.o'.  Stop.
So I have to punt. I must be doing something wrong.
Any help would be greatly appreciated!
-- Cinaed
The 4.18.8-odroidc2 kernel builds.
And the Makefile for the headers is identical to the Makefile for the kernel - which would explain the problem with not being able to build a loadable object using the headers.
