Preamble: I have done numerous hours of reading and searching (due diligence). See end.
I have a FA NanoPi NEO Core-2 LTS with shield and 64G M.2 (This shield uses JMS567-LGBB1A chip USB to sata for M.2 access).  I have successfully installed Armbian from SD to and booted from the eMMC.
Armbian Stretch mainline kernel 4.14.y - This image https://dl.armbian.com/nanopineocore2/Debian_stretch_next.7z
armbianmonitor -u results  http://ix.io/1xAA
Logs indicate formatting did occur correctly as far as I can tell. The volumes are formatted as I selected - along with an 'extra' ext4 volume that looks like it is just for boot. NOTE: Since I could not boot, I re-tried using default ext4 for both which works. System now boots Armbian without TF. ATM OS resides on sda1.
Console output:
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State ON
INFO:      AffInst: Level 0, MPID 0x2, State ON
INFO:      AffInst: Level 0, MPID 0x3, State ON
U-Boot SPL 2018.05-armbian (Oct 27 2018 - 08:32:18 +0200)
DRAM: 1024 MiB
Trying to boot from MMC2
NOTICE:  BL3-1: Running on H5 (1718) in SRAM A2 (@0x44000)
NOTICE:  Configuring SPC Controller
NOTICE:  BL3-1: v1.0(debug):c9f55c0
NOTICE:  BL3-1: Built : 08:32:12, Oct 27 2018
NOTICE:  DT: sun50i-h5-nanopi-neo-core2
NOTICE:  SCPI: dummy stub handler, implementation level: 000000
INFO:    BL3-1: Initializing runtime services
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
U-Boot 2018.05-armbian (Oct 27 2018 - 08:32:18 +0200) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: FriendlyARM NanoPi NEO Core 2
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
Loading Environment from EXT4... MMC: no card present
** Bad device mmc 0 **
Failed (-5)
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3090 bytes read in 4 ms (753.9 KiB/s)
## Executing script at 4fc00000
U-boot loaded from eMMC or secondary SD
Boot script loaded from mmc
208 bytes read in 2 ms (101.6 KiB/s)
30102 bytes read in 11 ms (2.6 MiB/s)
504 bytes read in 17 ms (28.3 KiB/s)
Applying kernel provided DT overlay sun50i-h5-usbhost1.dtbo
504 bytes read in 14 ms (35.2 KiB/s)
Applying kernel provided DT overlay sun50i-h5-usbhost2.dtbo
4179 bytes read in 13 ms (313.5 KiB/s)
Applying kernel provided DT fixup script (sun50i-h5-fixup.scr)
## Executing script at 44000000
4923549 bytes read in 247 ms (19 MiB/s)
13148168 bytes read in 649 ms (19.3 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
   Image Name:   uInitrd
   Data Size:    4923485 Bytes = 4.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49b4d000, end 49fff05d ... OK
   reserving fdt memory region: addr=4fa00000 size=6d000
   Loading Device Tree to 0000000049add000, end 0000000049b4cfff ... OK
Starting kernel ...
Loading, please wait...
starting version 232
done.
Begin: Will now check root file system ... fsck from util-linux 2.29.2
done.
mount: Invalid argument
done.
Begin: Running /scripts/init-bottom ... mount: No such file or directory
mount: invalid option --
done.
run-init: current directory on the same filesystem as the root: error 0
Target filesystem doesn't have requested /sbin/init.
No init found. Try passing init= bootarg.
Rebooting automatically due to panic= boot argument
To elaborate on the process, after writing TF card and booting, I ran armbian-config selecting option "eMMC boot | USB/SATA/NVMe root install" and selected format of btrfs for sda1. Also, "Select filesystem type for eMMC /dev/mmcblk2" ... "Formating /dev/mmcblk2 to f2fs ... please wait". The utility responded with the appropriate warnings (about erasing/formatting) and appeared to execute correctly, returning no errors and prompting for reboot at end of process. I shutdown, removed card, powered up and system did not come up properly. I saw no special advisories about additional manual steps etc.
Question:
Did I miss a step when using the alternative disk format options on this platform? Are they a WIP? Should I file a bug report?
'Bibliography:'
https://docs.armbian.com/User-Guide_Getting-Started/
https://docs.armbian.com/User-Guide_Armbian-Config/
Nearly all NanoPi NEO2 forum posts here
Many others...
Edited by Quanta
correct board reference in title and elsewhere
