FanDjango Posted January 17, 2019 Posted January 17, 2019 Odroid XU4 with Cloudshell2 Coming from 4.14.69, upgraded to 4.19.14 The fbtft_device module for the Cloudshell-LCD now reports: fbtft_device: display not supported: 'hktft9340' And yes, the source for fbtft_device seems to no longer contain hktft9340. I will ask in the Hardkernel Forum - this is just for info here. Question: When I use armbian-config to switch to an earlier package, I get a nice list, I select one and say ok, but after reboot nothing has changed. Is there something I could be missing in order to make this switch work? Never tried it before - I was hoping this would help me temporarily.
FanDjango Posted January 17, 2019 Author Posted January 17, 2019 Ok, here is what I found out about 4.14.xx vs 4.19.xx on Odroid XU4: Quote Kernel 4.19 is not officially supported by HardKernel. It's unlikely that Armbian ported all patches made on the Kernel 4.14 to 4.19 but rather take the stock Kernel, which does not have the modules that were added to Kernel 4.14. Ok, I've never gone backwards before. I'm back to the original question: After switching back in armbian-config, after a reboot, Nothing happens. LOL - a solitary update for armbian-config just came in. I installed it in the hopes… but now it doesn't give me a list of possible other kernels like before - it says 'No other kernels available'. Ok, I'll do it the hard way, I have backups...
FanDjango Posted January 18, 2019 Author Posted January 18, 2019 Could one of the armbian gurus comment on this statement by hardkernel? Quote Kernel 4.19 is not officially supported by HardKernel. It's unlikely that Armbian ported all patches made on the Kernel 4.14 to 4.19 but rather take the stock Kernel, which does not have the modules that were added to Kernel 4.14. because then I would worry that some other specific XU4 or ordroid features might have silently dissapeared after the upgrade from 4.14 -> 4.19
jshc1 Posted January 18, 2019 Posted January 18, 2019 41 minutes ago, FanDjango said: Could one of the armbian gurus comment on this statement by hardkernel? because then I would worry that some other specific XU4 or ordroid features might have silently dissapeared after the upgrade from 4.14 -> 4.19 4.19 for xu4 at the moment is a mess. Stay at 4.14 if you are able. I currently have 4.14.87 https://forum.armbian.com/topic/9319-problem-with-underclocking-odroid-hc1hc2xu4-with-kernel41914armbian570/
FanDjango Posted January 18, 2019 Author Posted January 18, 2019 Thanks for the info. Meanwhile I have found and solved my issues with armbian-config / system / other not working. I have opened up a separate issue concerning that. https://forum.armbian.com/topic/9361-armbian-configsystemother-fail-3-issues-on-my-system/
