sunzone Posted January 21, 2019 Posted January 21, 2019 Armbianmonitor: http://ix.io/1yQZ Hello. When my orange pi zero is booted, Pin16,18(PA19,PA18) seems to record high value(3.3v) I want the pins to stay low. In the dtb file, PA18 and PA19 are assigned to i2c1 and i2s0. But in the /boot/armbianEnv.txt file those overlays are not enabled. Can someone please help me how to keep ping 16 and 18 low at t he boot time? Image used: ARMBIAN 5.38 stable Ubuntu 16.04.4 LTS 4.14.18-sunxi Thank You.
sunzone Posted February 14, 2019 Author Posted February 14, 2019 Hi, After some more digging, I found out that this happens because of hardware. This is due to the Orange Pi Zero board's pull up resistors attached to the specified pins. After removing the pull-up resistors, Pin16,18(PA19,PA18) did not record high value at the bootup. Thanks.
