Can anyone tell why I cant export PH3 as gpio?
It is the default "usb2_vbus-supply" for usb2 of allwinner A20.
In my application I need to control this "usb2_vbus-supply".
Example : exporting PH3
root@cubieboard2:~# echo 227 > /sys/class/gpio/export
-bash: echo: write error: Device or resource busy
Im using armbian vanilla for my cb2.
Thanks in advance.
PH3 is defined in sunxi-common-regulators.dtsi and used in sun7i-a20-cubieboard2.dts to define usb2_vbus-supply. I would suspect without changing these definitions you won't be able to switch the pin on/off from userspace?
Hello Thomas,
You're correct, after some modification in sunxi-common-regulators.dtsi and sun7i-a20-cubieboard2.dts, I can now control PH3 to be use in my application.
Thanks.
