Armbianmonitor:
I'm trying to run the example.cpp that comes with Pine64-CPP  but I am throwing segmentation faults.
The man-setup() call initialzes the board with the following if statement in the setup() function in gpio.cpp
    if((uint64_t)gpio_mem % PAGE_SIZE)
and the  this->gpioMap = statement that uses SUNXI_GPIO_BASE
In the example code, I initialize the pin with
   man->pinMode (PI_GPIO_24, OUTPUT);
The pinMode function in gpio.cpp, launches _setPullupdn with gpio=78 and pud = 1.  As expected
Inside _setPullupdn,  the following is set
     bank= 2
     index = 0
    offset = 28
The segmentation fault seems to come from this line:
   regval = *(&pio->PULL[0] + index);
I have a 4 GB Rock64 running the latest Armbian desktop from this site.
sudo cat /sys/kernel/debug/gpio   gives me
GPIOs 0-31, platform/pinctrl, gpio0:
 gpio-0   (                    |vcc_host_5v         ) out hi
 gpio-2   (                    |?                   ) out lo
 gpio-30  (                    |vcc_sd              ) out lo
GPIOs 32-63, platform/pinctrl, gpio1:
 gpio-50  (                    |mdio-reset          ) out hi
GPIOs 64-95, platform/pinctrl, gpio2:
GPIOs 96-127, platform/pinctrl, gpio3:
GPIOs 510-511, platform/rk8xx-gpio, rk8xx-gpio, can sleep:
 gpio-510 (                    |?                   ) out lo
 gpio-511 (                    |?                   ) out lo
Anyone have any thoughts?
Thanks.
So, I never resolved the problems with the Pine64-CPP library but I found an alternate.
First, I used bash scripts to make sure the Rock64 was working, and I had the right pin addresses.
       https://github.com/Leapo/Rock64-BashGPIO
I used the table table from this website to correctly identify the gpio indices.
        https://github.com/Leapo/Rock64-R64.GPIO...GPIO-Modes
        I used the items from the column labeled GPIO# (ROCK)
Lastly, I used the GPIO Class from the following.
      https://github.com/halherta/RaspberryPi-GPIOClass-v2
Even though it is was created for the Raspberry Pi, I found that it correctly manipulated the files in /sys/class/gpio on my Rock64.
Note: I have only tested the GPIO read function, since that is what I'm trying to do for my project.
