icce Posted February 7, 2019 Posted February 7, 2019 Mainline stable Armbian stable for Pine64 worked great. I have successfully make my 3.5 TFT screen work but not the touch screen. I read some tutorials, mostly guide. This guide for TFT and Touch is really detailed. For touch: - Step 1: ads7846 driver seems ok - Step 2: ads7846_device there is a warning after make and make install, and it said to skip depmod - After this, I tried sudo modprob ads7846 sudo modprob ads7846_device model=7846 cs=1 gpio_pendown=1 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900 ads7846 is ok (confirmed with lsmod). But ads7846_device return invalid argument, it means that module ads7846_device is not in the system. Anyone succeed with Pine64?
icce Posted February 7, 2019 Author Posted February 7, 2019 Follow my attempt to make touch work on Pine64. I confirmed that "ads7846" and "ads7846_device" already installed. Even though there was a warning about missing "system.map" but it seems those modules have been installed. lsmod and ads7846 was there but not ads7846_device. I tried dmesg | grep ads7846 but it gave error: ads7846_device: Unable to get IRQ assigned to gpio_pendown' It seems that Armbian Mainline on Pine64 has not configured assign interrupt for pin?! Or kernel for Pine64 cannot IRQ for GPIO71 sudo modprobe ads7846_device model=7846 cs=1 gpio_pendown=71 keep_vref_on=1 swap_xy=1 pressure_max=255 x_plate_ohms=60 x_min=200 x_max=3900 y_min=200 y_max=3900 Any idea?!
shaddow501 Posted June 2, 2019 Posted June 2, 2019 Hello I am having the same issue with the BPI-M64 (same chipset) is there any new information of what we should do? or where should we look for a solution? Any guidance of how to proceed?
