jadamcak Posted March 27, 2019 Posted March 27, 2019 Armbianmonitor: http://ix.io/1EBb Hi guys, I am newbie, my monitor iiyama ProLite B2888UHSU is flickering random white lines on black screen. U-boot console was displayed correctly. Same flickering I have seen on stock Armbian Bionic mainline kernel 4.19.y (next). Only Armbian Xenial desktop legacy kernel 3.10.y is working correctly. Can you help me? Maybe I can fix it, too, but I don't know, how and where to start. Thanks
jadamcak Posted March 27, 2019 Author Posted March 27, 2019 (edited) /var/log/Xorg.0.log Spoiler [ 37.580] X.Org X Server 1.19.6 Release Date: 2017-12-20 [ 37.580] X Protocol Version 11, Revision 0 [ 37.580] Build Operating System: Linux 4.4.0-138-generic aarch64 Ubuntu [ 37.581] Current Operating System: Linux pine64 4.19.25-sunxi64 #5.77 SMP Tue Mar 26 21:53:58 CET 2019 aarch64 [ 37.581] Kernel command line: root=UUID=1d81c52f-d529-4718-a9b5-66fc30647cbd rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 panic=10 consoleblank=0 loglevel=1 ubootpart=75ea6992-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=memory swapaccount=1 [ 37.581] Build Date: 25 October 2018 04:10:37PM [ 37.581] xorg-server 2:1.19.6-1ubuntu4.2 (For technical support please see http://www.ubuntu.com/support) [ 37.581] Current version of pixman: 0.34.0 [ 37.581] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 37.581] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 37.581] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Mar 27 09:24:32 2019 [ 37.582] (==) Using config directory: "/etc/X11/xorg.conf.d" [ 37.582] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 37.582] (==) No Layout section. Using the first Screen section. [ 37.582] (==) No screen section available. Using defaults. [ 37.582] (**) |-->Screen "Default Screen Section" (0) [ 37.582] (**) | |-->Monitor "<default monitor>" [ 37.583] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 37.583] (**) Option "BlankTime" "0" [ 37.583] (**) Option "StandbyTime" "0" [ 37.583] (**) Option "SuspendTime" "0" [ 37.583] (**) Option "OffTime" "0" [ 37.584] (==) Automatically adding devices [ 37.584] (==) Automatically enabling devices [ 37.584] (==) Automatically adding GPU devices [ 37.584] (==) Automatically binding GPU devices [ 37.584] (==) Max clients allowed: 256, resource mask: 0x1fffff [ 37.584] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 37.584] Entry deleted from font path. [ 37.584] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. [ 37.584] Entry deleted from font path. [ 37.584] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. [ 37.584] Entry deleted from font path. [ 37.584] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist. [ 37.584] Entry deleted from font path. [ 37.584] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. [ 37.584] Entry deleted from font path. [ 37.584] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. [ 37.584] Entry deleted from font path. [ 37.584] (==) FontPath set to: /usr/share/fonts/X11/misc, built-ins [ 37.584] (==) ModulePath set to "/usr/lib/xorg/modules" [ 37.584] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 37.584] (II) Loader magic: 0xaaaae76e0010 [ 37.584] (II) Module ABI versions: [ 37.584] X.Org ANSI C Emulation: 0.4 [ 37.584] X.Org Video Driver: 23.0 [ 37.584] X.Org XInput driver : 24.1 [ 37.584] X.Org Server Extension : 10.0 [ 37.586] (++) using VT number 7 [ 37.586] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration [ 37.588] (II) xfree86: Adding drm device (/dev/dri/card0) [ 37.589] (II) xfree86: Adding drm device (/dev/dri/card1) [ 37.589] (II) no primary bus or device found [ 37.589] falling back to /sys/devices/platform/display-engine/drm/card0 [ 37.589] (II) LoadModule: "glx" [ 37.590] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so [ 37.593] (II) Module glx: vendor="X.Org Foundation" [ 37.593] compiled for 1.19.6, module version = 1.0.0 [ 37.593] ABI class: X.Org Server Extension, version 10.0 [ 37.593] (==) Matched modesetting as autoconfigured driver 0 [ 37.593] (==) Matched fbdev as autoconfigured driver 1 [ 37.593] (==) Assigned the driver to the xf86ConfigLayout [ 37.593] (II) LoadModule: "modesetting" [ 37.594] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so [ 37.594] (II) Module modesetting: vendor="X.Org Foundation" [ 37.594] compiled for 1.19.6, module version = 1.19.6 [ 37.594] Module class: X.Org Video Driver [ 37.594] ABI class: X.Org Video Driver, version 23.0 [ 37.594] (II) LoadModule: "fbdev" [ 37.595] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so [ 37.595] (II) Module fbdev: vendor="X.Org Foundation" [ 37.595] compiled for 1.19.3, module version = 0.4.4 [ 37.595] Module class: X.Org Video Driver [ 37.595] ABI class: X.Org Video Driver, version 23.0 [ 37.595] (II) modesetting: Driver for Modesetting Kernel Drivers: kms [ 37.595] (II) FBDEV: driver for framebuffer: fbdev [ 37.756] (II) modeset(0): using drv /dev/dri/card0 [ 37.756] (WW) Falling back to old probe method for fbdev [ 37.756] (II) Loading sub module "fbdevhw" [ 37.756] (II) LoadModule: "fbdevhw" [ 37.757] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so [ 37.757] (II) Module fbdevhw: vendor="X.Org Foundation" [ 37.757] compiled for 1.19.6, module version = 0.0.2 [ 37.757] ABI class: X.Org Video Driver, version 23.0 [ 37.757] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support [ 37.758] (II) modeset(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 [ 37.758] (==) modeset(0): Depth 24, (==) framebuffer bpp 32 [ 37.758] (==) modeset(0): RGB weight 888 [ 37.758] (==) modeset(0): Default visual is TrueColor [ 37.758] (II) Loading sub module "glamoregl" [ 37.758] (II) LoadModule: "glamoregl" [ 37.759] (II) Loading /usr/lib/xorg/modules/libglamoregl.so [ 37.775] (II) Module glamoregl: vendor="X.Org Foundation" [ 37.775] compiled for 1.19.6, module version = 1.0.0 [ 37.776] ABI class: X.Org ANSI C Emulation, version 0.4 [ 37.776] (II) glamor: OpenGL accelerated X.org driver based. [ 37.890] (II) glamor: EGL version 1.4 (DRI2): [ 37.890] EGL_MESA_drm_image required. [ 37.892] (EE) modeset(0): glamor initialization failed [ 37.892] (II) modeset(0): ShadowFB: preferred NO, enabled NO [ 38.096] (II) modeset(0): Output HDMI-1 has no monitor section [ 38.301] (II) modeset(0): EDID for output HDMI-1 [ 38.301] (II) modeset(0): Manufacturer: IVM Model: 7102 Serial#: 16843009 [ 38.301] (II) modeset(0): Year: 2014 Week: 0 [ 38.301] (II) modeset(0): EDID Version: 1.3 [ 38.301] (II) modeset(0): Digital Display Input [ 38.301] (II) modeset(0): Max Image Size [cm]: horiz.: 62 vert.: 34 [ 38.301] (II) modeset(0): Gamma: 2.20 [ 38.301] (II) modeset(0): DPMS capabilities: Off [ 38.301] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [ 38.301] (II) modeset(0): First detailed timing is preferred mode [ 38.301] (II) modeset(0): redX: 0.633 redY: 0.340 greenX: 0.311 greenY: 0.633 [ 38.301] (II) modeset(0): blueX: 0.158 blueY: 0.061 whiteX: 0.313 whiteY: 0.329 [ 38.301] (II) modeset(0): Supported established timings: [ 38.301] (II) modeset(0): 720x400@70Hz [ 38.301] (II) modeset(0): 640x480@60Hz [ 38.301] (II) modeset(0): 640x480@67Hz [ 38.301] (II) modeset(0): 640x480@72Hz [ 38.301] (II) modeset(0): 640x480@75Hz [ 38.301] (II) modeset(0): 800x600@56Hz [ 38.301] (II) modeset(0): 800x600@60Hz [ 38.301] (II) modeset(0): 800x600@72Hz [ 38.301] (II) modeset(0): 800x600@75Hz [ 38.301] (II) modeset(0): 832x624@75Hz [ 38.301] (II) modeset(0): 1024x768@60Hz [ 38.301] (II) modeset(0): 1024x768@70Hz [ 38.301] (II) modeset(0): 1024x768@75Hz [ 38.301] (II) modeset(0): 1280x1024@75Hz [ 38.301] (II) modeset(0): 1152x864@75Hz [ 38.301] (II) modeset(0): Manufacturer's mask: 0 [ 38.301] (II) modeset(0): Supported standard timings: [ 38.301] (II) modeset(0): #0: hsize: 2048 vsize 1152 refresh: 60 vid: 49377 [ 38.301] (II) modeset(0): #1: hsize: 1920 vsize 1080 refresh: 60 vid: 49361 [ 38.302] (II) modeset(0): #2: hsize: 1600 vsize 900 refresh: 60 vid: 49321 [ 38.302] (II) modeset(0): #3: hsize: 1920 vsize 1200 refresh: 60 vid: 209 [ 38.302] (II) modeset(0): #4: hsize: 1600 vsize 1200 refresh: 60 vid: 16553 [ 38.302] (II) modeset(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179 [ 38.302] (II) modeset(0): #6: hsize: 1280 vsize 1024 refresh: 60 vid: 32897 [ 38.302] (II) modeset(0): #7: hsize: 1280 vsize 720 refresh: 60 vid: 49281 [ 38.302] (II) modeset(0): Supported detailed timing: [ 38.302] (II) modeset(0): clock: 296.7 MHz Image Size: 621 x 341 mm [ 38.302] (II) modeset(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0 [ 38.302] (II) modeset(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0 [ 38.302] (II) modeset(0): Serial No: 0 [ 38.302] (II) modeset(0): Ranges: V min: 23 V max: 76 Hz, H min: 30 H max: 92 kHz, PixClock max 305 MHz [ 38.302] (II) modeset(0): Monitor name: PL2888UH [ 38.302] (II) modeset(0): Supported detailed timing: [ 38.302] (II) modeset(0): clock: 296.7 MHz Image Size: 621 x 341 mm [ 38.302] (II) modeset(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0 [ 38.302] (II) modeset(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0 [ 38.302] (II) modeset(0): Supported detailed timing: [ 38.302] (II) modeset(0): clock: 241.5 MHz Image Size: 621 x 341 mm [ 38.302] (II) modeset(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0 [ 38.302] (II) modeset(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0 [ 38.302] (II) modeset(0): Supported detailed timing: [ 38.302] (II) modeset(0): clock: 148.5 MHz Image Size: 621 x 341 mm [ 38.302] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 38.302] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0 [ 38.302] (II) modeset(0): Supported detailed timing: [ 38.302] (II) modeset(0): clock: 74.2 MHz Image Size: 621 x 341 mm [ 38.302] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0 [ 38.302] (II) modeset(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0 [ 38.302] (II) modeset(0): Number of EDID sections to follow: 1 [ 38.302] (II) modeset(0): EDID (in hex): [ 38.302] (II) modeset(0): 00ffffffffffff0026cd027101010101 [ 38.303] (II) modeset(0): 00180103803e22782a08a5a2574fa228 [ 38.303] (II) modeset(0): 0f5054bfef80e1c0d1c0a9c0d100a940 [ 38.303] (II) modeset(0): b300818081c0e6730030f2705a80b058 [ 38.303] (II) modeset(0): 8a006d552100001e000000ff00300a20 [ 38.303] (II) modeset(0): 20202020202020202020000000fd0017 [ 38.303] (II) modeset(0): 4c1e5c1e000a202020202020000000fc [ 38.303] (II) modeset(0): 00504c3238383855480a2020202001c7 [ 38.303] (II) modeset(0): 02032ef353100504030207061f141312 [ 38.303] (II) modeset(0): 1116152001dddedf23097f0783010000 [ 38.303] (II) modeset(0): 6d030c001000b83c200060010203e673 [ 38.303] (II) modeset(0): 0030f2705a80b0588a006d552100001e [ 38.303] (II) modeset(0): 565e00a0a0a02950302035006d552100 [ 38.303] (II) modeset(0): 001b023a801871382d40582c45006d55 [ 38.303] (II) modeset(0): 2100001e011d8018711c1620582c2500 [ 38.303] (II) modeset(0): 6d552100009e00000000000000000092 [ 38.303] (--) modeset(0): HDMI max TMDS frequency 300000KHz [ 38.303] (II) modeset(0): Printing probed modes for output HDMI-1 [ 38.303] (II) modeset(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz eP) [ 38.303] (II) modeset(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e) [ 38.303] (II) modeset(0): Modeline "3840x2160"x25.0 297.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (56.2 kHz e) [ 38.303] (II) modeset(0): Modeline "3840x2160"x24.0 297.00 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e) [ 38.303] (II) modeset(0): Modeline "3840x2160"x24.0 296.70 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e) [ 38.304] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e) [ 38.304] (II) modeset(0): Modeline "2048x1152"x60.0 162.00 2048 2074 2154 2250 1152 1153 1156 1200 +hsync +vsync (72.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080i"x60.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080i"x50.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080"x24.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080i"x59.9 74.18 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e) [ 38.304] (II) modeset(0): Modeline "1920x1080"x24.0 74.18 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e) [ 38.304] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e) [ 38.304] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e) [ 38.304] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e) [ 38.304] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e) [ 38.304] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e) [ 38.304] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e) [ 38.304] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e) [ 38.304] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e) [ 38.304] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e) [ 38.305] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e) [ 38.305] (II) modeset(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e) [ 38.305] (II) modeset(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 38.305] (II) modeset(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e) [ 38.305] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e) [ 38.305] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e) [ 38.305] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e) [ 38.305] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 38.305] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e) [ 38.305] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e) [ 38.305] (II) modeset(0): Output HDMI-1 connected [ 38.305] (II) modeset(0): Using exact sizes for initial modes [ 38.305] (II) modeset(0): Output HDMI-1 using initial mode 3840x2160 +0+0 [ 38.305] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0) [ 38.305] (==) modeset(0): DPI set to (96, 96) [ 38.305] (II) Loading sub module "fb" [ 38.305] (II) LoadModule: "fb" [ 38.305] (II) Loading /usr/lib/xorg/modules/libfb.so [ 38.306] (II) Module fb: vendor="X.Org Foundation" [ 38.306] compiled for 1.19.6, module version = 1.0.0 [ 38.306] ABI class: X.Org ANSI C Emulation, version 0.4 [ 38.306] (II) UnloadModule: "fbdev" [ 38.306] (II) Unloading fbdev [ 38.306] (II) UnloadSubModule: "fbdevhw" [ 38.306] (II) Unloading fbdevhw [ 38.306] (==) Depth 24 pixmap format is 32 bpp [ 38.307] (EE) Fatal server error: [ 38.307] (EE) AddScreen/ScreenInit failed for driver 0 [ 38.307] (EE) [ 38.307] (EE) Please consult the The X.Org Foundation support at http://wiki.x.org for help. [ 38.307] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 38.307] (EE) [ 38.436] (EE) Server terminated with error (1). Closing log file. Edited March 27, 2019 by Tido added spoiler - for better reading, please do that yourself next time. thx
jadamcak Posted March 27, 2019 Author Posted March 27, 2019 Solved by ugly user hack: I changed file /etc/X11/xorg.conf.d/01-armbian-defaults.conf to Section "Monitor" Identifier "Monitor0" Option "DPMS" "false" Modeline "1920x1080" 148.50 1920 2448 2492 2640 1080 1084 1089 1125 # Modelline "3840x2160" 296.70 3840 4016 4104 4400 2160 2168 2178 2250 EndSection Section "ServerFlags" Option "BlankTime" "0" Option "StandbyTime" "0" Option "SuspendTime" "0" Option "OffTime" "0" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" SubSection "Display" Viewport 0 0 Depth 24 Modes "1920x1080" # Modes "3840x2160" EndSubSection EndSection I run on 1920x1080 resolution, because on 3840x2160 crashes Xserver. U-boot works with 3840x2160 console view fine, but font is small Credits (for hack)
