  2. @MeJune You can check out my work starting with the 'Add warpme kernel 6.17' commit here: https://github.com/NickAlilovic/build/commits/v20251014/ I’m using warpme patches from his minimyth2 repo, though I’ve modified them to ensure they apply correctly. I also used my own patches for Transpeed, as his implementation differs from mine. u-boot: https://github.com/warpme/minimyth2/tree/master/script/bootloaders/u-boot-aw/files https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-aw/Makefile kernel: https://github.com/warpme/minimyth2/tree/master/script/kernel/linux-6.19/files https://github.com/warpme/minimyth2/blob/master/script/kernel/linux-6.19/Makefile An easier way to do this is to create a board config and use the official Armbian patch set. While Transpeed is already mainlined, the implementation is incomplete. You will still need a patch to include your missing Transpeed DTS nodes. If you are happy with 6.17, then use this build: https://github.com/NickAlilovic/build/commits/v20251014/
  4. i recently purchased an orange pi 5 plus 16gb with the wifi / bt card, the aluminum wifi case, fan and 1tb ssd. when i go to the official website i see different images there none of which seem to work 100%. i mean i was able to get each up and running but what i noticed is that the graphical drivers would not load. i saw a youtube video claiming armbian has the right driver support for the mali 610 gpu. can someone assist me getting this to work? im big into emulation gaming and right now it doesnt even have Vulkan support i crave. someone help thanks
  5. @Nick A You previously taught how to build an image for Transpeed 8k618-t. If I want to replace the default version kernel with a newer kernel. Could I tell you if there's a way to create one?
  6. Boot with serial attached and see if the DRAM is being properly detected. If not this patch would appear to solve the issue. https://lore.kernel.org/linux-sunxi/2813637.mvXUDI8C0e@jernej-laptop/T/#t
  7. You should pipe the output from a serial console cable to another computer where you store it. Make sure kernel cmdline loglevel=7 AFAIR the OPI5+ can only use 5V as input supply power. Your 100W PSU might be a standard spec one so it does only deliver 3A at 5V. This might be a perfect 5.000V, but an extra cable in between will drop that a bit and the risk is then that short higher power drap will either make the 5V goo too low and/or the PSU will cut the power because more than 3A drawn during a short peak. You will need to look at powering first. Usually 5V only SBC's can be powered via other input then the USB-C input. You need to read the instruction for your OPI5+, and also OPi5, those might be different. OPI5+ and also OPi5 should transcode at more or less the same speed, large amount of memory does not really matter as it is just HW processing blocks doing the work in a rather limited memory space. You should do a manual CLI jellyfin-ffmpeg based transcode, see /var/log/jellyfin how commandline arguments for that specific video look like (and simplify it, output to 1 file instead of chunks m3u8). And or search this forum, I at least have posted examples for check/test earlier. You might also try to reproduce it with a publiclicy know video, look for big buck bunny test vids or so.
  8. Nanopi neo air stucks on "Starting kernel..." after some random power losses (2-50) during loading I think it's because of corruption of armbianEnv.txt. Normal UART logs: UART Logs with stucking on "Starting kernel" U-Boot SPL 2024.01_armbian-202ns16550_serial serial@1c28000: p024.01-S866c-P7738-Hadc5-Vefe9-B2eb2-R448a (Feb 06 2026 - 03:49:45 +0000) Allwinner Technology 0) Model: FriendlyARM NanoPi NEent from FAT... Unable to use mmc 1:1... ial Err: serial Net: No ethernet found. starting USB... No working controllers found 1(part 0) is current device Scacr 5475 bytes read in 2 ms (2.6 MiB/s) ## Executing script at 43100000 U-boot loaded from eMMC or secondary SD MMC: no card present * ** Failed to load '/boot/armbianEnv.txt' Load fdt: /boot/dtb/sun8i-h3-nan13293004 bytes read in 419 ms (30.3 MiB/s) 10014752 bytes read in 317 ms (30.1 MiB/s) ion 43400000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 13292940 Bytes = 12.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree bloing Ramdisk to 49352000, end 49fOK Loading Device Tree to 49 Starting kernel ... U-Boot SPL 2024.01_armbian-2024.01-S866c-P7738-Hadc5-Vefe9-B2eDRAM: 512 MiB Trying to boot frns16550_serial serial@1c28000: p CPU: Allwinner H3 (SUN8I 168Core: 64 devices, 16 uclasses, mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... In: serial,usbkbd Out: serial Err: serial Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc1(part 0) is current device Sca/s) ## Executing script at 4310dary SD MMC: no card present ** Bad device specification mmc 0Failed to load '/boot/armbianEnv.txt' Load fdt: /boot/dtb/sun8i-h3-nanopi-neo-air.dtb 13293004 bytes read in 433 ms (29.3 MiB/s) it Ramdisk from Legacy Image at 43400000 ... Image Name: uux RAMDisk Image (gzip compressed) Data Size: 13292940 Bytes = 12.7 MiB Load Address: 00000000 Entry Point: 0000b at 43000000 Booting using the fdt blob at 0x43000000 Working Ramdisk to 49352000, end 49fff58c ... 2e0000, end 49351fff ... OK Worns16550_serial serial@1c28000: p19 U-Boot 2024.01_armbian-22eb2-R448a (Feb 06 2026 - 03:49:45 +0000) Allwinner Technology O Air DRAM: 512 MiB ent from FAT... switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr /s) ## Executing script at 43100000 U-boot loaded from eMMC or secondary SD MMC: no card present ** Bad device specification mmc 0 ** Failed to load '/boot/armbianEnv.txt' 13293004 bytes read in 447 ms (2ing Ramdisk to 49352000, end 49f ing USB... No working controlleAutoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc1(part 0) is current device Sca0000 * Bad device specification mmc 0 ** Failed to load '/boot/armbianEnv.txt' Load fdt: /boot/dtb/sun8i-h3-nanopi-neo-air.dtb 13293004 bytes read in 433 ms (29.3 MiB/s) OK ## Flattened Device Tree blob at 43000000 Booting using ing FDT set to 43000000 Loading Ramdisk to 49352000, end 49fff58c ... OK Loading Device Tree to 492e0000, end 49351fff ... OK Working FDT set to 492e0000 Starting kernel ... I builded armbian image with compile.sh BOARD=nanopiair BRANCH=legacy RELEASE=bookworm BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no CLEAN_LEVEL="make,debs,cache" OVERLAYS="analog-codec i2c0 i2c1 i2c2 usbhost2 usbhost3" COMPRESS_OUTPUTIMAGE=sha,gz WIREGUARD=yes NAMESERVER=8.8.8.8 DOCKER_ARMBIAN_BASE_IMAGE="ubuntu:jammy" for Nanopi Neo Air. Image is flashed to eMMC. Is any way to solve it?
  9. Yesterday
  10. I am running Ubuntu 24.04 Noble (Armbian Linux 6.1.115-vendor-rk35xx) and no additional packages affecting VPU performance have been installed; everything is stock. Jellyfin is running in Docker, and transcoding works perfectly, except for some movies. I tried to play a 4K video in Chrome (native HEVC support), set the bitrate to 40mbps, and the video played normally at a transcoding speed of about 3x, but after a while, Orange Pi crashed. In Firefox inside neko (where there is no hardware acceleration and HEVC), the crash happened even faster, after ~2 seconds of playback. The crash happens as if the board loses power: journalctl is not saved, nothing is visible via ssh. I use a 100W Baseus GaN Pro Desktop Power Strip (model CCGAN100-1ACE) and the Orange Pi is the only device connected to it. I also have a 100W cable that shows the current consumption in watts. During transcoding, it showed 10, and then the board hard rebooted again, so I don't think this is related to power issues. Before that, I used Ubuntu 24.04 from Joshua Riek, and there was a problem with the Mali driver crashing under heavy load or simply after a while. A similar hard reboot also occurred if the driver was “too slow” to crash. Here is Jellyfin's video info: ffprobe: I also have a 4 GB model of Orange Pi 5 (not B), and there were no problems with transcoding this video; it was just slow due to the small amount of RAM. I don't even know where to start. What should I do to at least understand the cause of this issue?
  11. Hi Gaetano, I'd be suprised if Buster did work with such a newer kernel. dwc2 is Pi specific and will not work on Allwinner/Sunxi hardware. The OTG usb controller is completely different, please see the wiki: https://linux-sunxi.org/USB_OTG_Controller_Register_Guide Overlays will only load overlays found in /boot/dtb/overlay/ while user defined ones exist in /boot/overlay-user/ As expected otg is the default mode, firstly those warnings are normal when decompiling the dtb back dts as not everything gets translated back. For small modifications you can use sudo armbian-add-overlay which compiles the overlay and places it within /boot/overlay-user This problem seems to occur every now and again in some kernel releases, please refer to here: for a solution. I would refer back to the board schematic before adjusting the dts. On the Pcduino2 and Pcduino3, the OTG micro USB passes through a small resistor rather than a fuse so causes a slight voltage drop. Just make sure that you have a good quality lead that ensures the board gets 5V but slightly over is better. sudo armbianmonitor -m Stop monitoring using [ctrl]-[c] Time CPU load %cpu %sys %usr %nice %io %irq Tcpu PMIC DC-IN C.St. 22:19:42 960 MHz 0.39 14% 9% 5% 0% 0% 0% 33.7 °C 30.2 °C 5.34V 0/6^C Best of luck Ryzer
  12. I see there is a "UART" on the front board image, but I guess it does not work for you. Check the sorroundings for possibile missing resistors, sometimes they remove some small SMD resistors to make the UART non-functional. Also note that you must use an adapter that is capable of 1.5Mbps; not all of them can reach such baud rates (AFAIR pl2303 can't, but CH301 should work)
  13. Some logs that might help in resolving: cat /proc/asound/card0/eld* monitor_name SONY AVAMP connection_type HDMI eld_version [0x2] CEA-861D or below edid_version [0x3] CEA-861-B, C or D manufacture_id 0xd94d product_id 0x9301 port_id 0x0 support_hdcp 0 support_ai 1 audio_sync_delay 0 speakers [0x5f] FL/FR LFE FC RL/RR RC RLC/RRC sad_count 12 sad0_coding_type [0xc] MLP (Dolby TrueHD) sad0_channels 2 sad0_rates [0x1ec0] 44100 48000 88200 96000 176400 192000 sad1_coding_type [0xc] MLP (Dolby TrueHD) sad1_channels 6 sad1_rates [0x1ec0] 44100 48000 88200 96000 176400 192000 sad2_coding_type [0xc] MLP (Dolby TrueHD) sad2_channels 8 sad2_rates [0x6c0] 44100 48000 88200 96000 sad3_coding_type [0xb] DTS-HD sad3_channels 2 sad3_rates [0x1ec0] 44100 48000 88200 96000 176400 192000 sad4_coding_type [0xb] DTS-HD sad4_channels 6 sad4_rates [0x1ec0] 44100 48000 88200 96000 176400 192000 sad5_coding_type [0xb] DTS-HD sad5_channels 8 sad5_rates [0x6c0] 44100 48000 88200 96000 sad6_coding_type [0x1] LPCM sad6_channels 2 sad6_rates [0x1ee0] 32000 44100 48000 88200 96000 176400 192000 sad6_bits [0xe] 16 20 24 sad7_coding_type [0x1] LPCM sad7_channels 6 sad7_rates [0x1ee0] 32000 44100 48000 88200 96000 176400 192000 sad7_bits [0xe] 16 20 24 sad8_coding_type [0x1] LPCM sad8_channels 8 sad8_rates [0x1ee0] 32000 44100 48000 88200 96000 176400 192000 sad8_bits [0xe] 16 20 24 sad9_coding_type [0x2] AC-3 sad9_channels 6 sad9_rates [0xe0] 32000 44100 48000 sad9_max_bitrate 680000 sad10_coding_type [0x7] DTS sad10_channels 6 sad10_rates [0x6e0] 32000 44100 48000 88200 96000 sad10_max_bitrate 1536000 sad11_coding_type [0xa] E-AC-3/DD+ (Dolby Digital Plus) sad11_channels 8 sad11_rates [0xc0] 44100 48000 dmesg | grep -i hdmi [ 0.024452] /vop@fdd90000: Fixed dependency cycle(s) with /hdmi@fde80000 [ 0.024468] /hdmi@fde80000: Fixed dependency cycle(s) with /vop@fdd90000 [ 0.030657] /hdmi@fde80000: Fixed dependency cycle(s) with /hdmi-con [ 0.030674] /hdmi-con: Fixed dependency cycle(s) with /hdmi@fde80000 [ 1.328504] dwhdmiqp-rockchip fde80000.hdmi: registered DesignWare HDMI QP I2C bus driver [ 1.329303] rockchip-drm display-subsystem: bound fde80000.hdmi (ops rockchip_drm_fini [rockchipdrm]) [77523.181767] hdmi-audio-codec hdmi-audio-codec.4.auto: HDMI: Unknown ELD version 0 [77523.184450] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC error (-19): at snd_soc_dai_prepare() on i2s-hifi [77529.747875] hdmi-audio-codec hdmi-audio-codec.4.auto: HDMI: Unknown ELD version 0 [77529.749599] hdmi-audio-codec hdmi-audio-codec.4.auto: ASoC error (-19): at snd_soc_dai_prepare() on i2s-hifi [84820.893274] hdmi-audio-codec hdmi-audio-codec.4.auto: HDMI: Unknown ELD version 0 [84947.092875] dwhdmiqp-rockchip fde80000.hdmi: registered DesignWare HDMI QP I2C bus driver [84947.100550] rockchip-drm display-subsystem: bound fde80000.hdmi (ops rockchip_drm_fini [rockchipdrm])
  14. Collabora is excited to see Monado at the heart of the new OpenXR runtime for Android XR, a major milestone for Open Source XR interoperability. View the full article
  15. Collabora is excited to see Monado at the heart of the new OpenXR runtime for Android XR, a major milestone for Open Source XR interoperability. View the full article
  16. Disclaimer: I know it's not a good idea XD Is it possible somehow to upgrade the prebuilt image Armbian 12/OpenMediaVault 7 to Armbian 13/OpenMediaVault 8? Is there a guide?
  17. Hi all. i got Armbian for luckfox, compiled by builder, and also tried downloaded img binaries. but cannot find clear and complete instruction how to write thtat img to eMMC and for SDCard . what tools and steps should be used for get Armbian img boots and works on that board. thanks in advance PS. BigTreetech CB2 same problem - no clear info about flash eMMC and SDCard.
  18. Does anybody know how one could correct multichannel HDMI audio mapping in the current-rockchip64 build or kernel? When I run speaker-test -c6 -D plughw:0,0 on (kernel) 6.1.115-vendor-rk35xx + (dtb) dtb-6.1.115-vendor-rk35xx Everything is mapped correctly and I hear audio from all the correct channels. When I run the same command on (kernel) 6.18.12-current-rockchip64 + (dtb) dtb-6.18.12-current-rockchip64 I get no audio on center and rear right channels (others are working). Is this a mistake or error in the DTB file of dtb-6.18.12-current-rockchip64 (rk3588s-nanopi-r6s.dtb) ? How can we correct this?
  19. As long as you don't install Armbian to your emmc, you should be able to still boot android by removing the SD and/or usb drives. Once you install to emmc you will overwrite the android installation
  20. To get audio working on the Radxa Dragon (QCS6490) when the standard UCM (Use Case Manager) fails, you have to bypass the "official" path and manually bridge the hardware to the software. Here is the complete summary of the "manual bridge" method developed. I installed Armbian 25.11.1 Edge Image and below is how I fixed HDMI Audio. Step 1: Create the Hardware Bridge Script This script manually flips the hardware switches in the Qualcomm DSP that route audio to the HDMI/DisplayPort pins. File: /usr/local/bin/fix-hdmi-audio.sh Command: sudo nano /usr/local/bin/fix-hdmi-audio.sh Bash #!/bin/bash # Wait for hardware to initialize sleep 2 # Open the HDMI/DP Audio Bridge amixer -c 0 cset name='DISPLAY_PORT_RX_0 Audio Mixer MultiMedia1' 1 # Set initial hardware volume amixer -c 0 cset name='stream0.vol_ctrl0 MultiMedia1 Playback Volu' 75% Make it executable: sudo chmod +x /usr/local/bin/fix-hdmi-audio.sh Step 2: Create the Systemd Service This ensures the hardware switches are flipped automatically every time the board boots up. File: /etc/systemd/system/hdmi-audio.service Command: sudo nano /etc/systemd/system/hdmi-audio.service Ini, TOML [Unit] Description=Fix HDMI Audio Routing After=sound.target [Service] Type=oneshot ExecStart=/usr/local/bin/fix-hdmi-audio.sh RemainAfterExit=yes [Install] WantedBy=multi-user.target Enable it: Bash sudo systemctl daemon-reload sudo systemctl enable hdmi-audio.service Step 3: Configure the Desktop Audio Sink Since the system's "Built-in Audio" often defaults to a "Dummy Output" when UCM is broken, we force PulseAudio to create a manual "Sink" pointing directly to the hardware. File: /etc/pulse/default.pa Command: sudo nano /etc/pulse/default.pa Add these lines to the very bottom of the file: Plaintext # Manually bridge PulseAudio to the working hardware path load-module module-alsa-sink device=plughw:0,0 sink_name=Manual_HDMI sink_properties=device.description=HDMI_Audio_Output set-default-sink Manual_HDMI Step 4: Clean Up UCM (Optional but Recommended) To stop the "HDMI Audio failure" warnings during boot, you can ensure your UCM files are at least syntactically correct, even if the system ignores them. File: /usr/share/alsa/ucm2/QCS6490RadxaDra/HiFi.conf Plaintext Syntax 2 SectionDevice."HDMI" { Comment "HDMI Output" Value { PlaybackPriority 200 PlaybackPCM "hw:0,0" } } SectionVerb { EnableSequence [] DisableSequence [] } Summary of the Audio Path By following these steps, you have constructed the following data flow: Hardware: Qualcomm DSP (Card 0, Device 0). Bridge: amixer opens the path from the CPU to the HDMI port. ALSA: Provides the plughw:0,0 interface. PulseAudio: Grabs that interface and names it "HDMI_Audio_Output." Applications: YouTube/Browsers send audio to the "Default Sink," which is now your working HDMI path. Now I will put all these commands into a single "one-click" shell script so you can save it as a backup for future installs? The Radxa Dragon Audio "One-Click" Fix Create the file: nano fix_audio.sh Paste the code below. Run it: chmod +x fix_audio.sh && sudo ./fix_audio.sh Bash #!/bin/bash echo "🚀 Starting Radxa Dragon QCS6490 Audio Fix..." # 1. Create the Hardware Bridge Script echo "🔧 Creating hardware bridge script..." cat <<EOF | sudo tee /usr/local/bin/fix-hdmi-audio.sh > /dev/null #!/bin/bash # Wait for hardware to initialize sleep 2 # Open the HDMI/DP Audio Bridge amixer -c 0 cset name='DISPLAY_PORT_RX_0 Audio Mixer MultiMedia1' 1 # Set initial hardware volume amixer -c 0 cset name='stream0.vol_ctrl0 MultiMedia1 Playback Volu' 75% EOF sudo chmod +x /usr/local/bin/fix-hdmi-audio.sh # 2. Create the Systemd Service echo "⚙️ Creating boot-time service..." cat <<EOF | sudo tee /etc/systemd/system/hdmi-audio.service > /dev/null [Unit] Description=Fix HDMI Audio Routing After=sound.target [Service] Type=oneshot ExecStart=/usr/local/bin/fix-hdmi-audio.sh RemainAfterExit=yes [Install] WantedBy=multi-user.target EOF # 3. Enable and Start the Service sudo systemctl daemon-reload sudo systemctl enable hdmi-audio.service sudo systemctl start hdmi-audio.service # 4. Configure PulseAudio Sink echo "🔉 Configuring PulseAudio/PipeWire sink..." PA_CONFIG="/etc/pulse/default.pa" if [ -f "$PA_CONFIG" ]; then # Check if we already added the fix to avoid duplicates if ! grep -q "Manual_HDMI" "$PA_CONFIG"; then cat <<EOF | sudo tee -a "$PA_CONFIG" > /dev/null # Manually bridge PulseAudio to the working hardware path load-module module-alsa-sink device=plughw:0,0 sink_name=Manual_HDMI sink_properties=device.description=HDMI_Audio_Output set-default-sink Manual_HDMI EOF fi else echo "⚠️ Warning: /etc/pulse/default.pa not found. You may need to manualy add the sink to your specific sound server config." fi echo "✅ Success! Please reboot to finalize settings." echo " After reboot, select 'HDMI_Audio_Output' in Sound Settings if it doesn't auto-switch." Why this works for your specific board: This script performs a "Direct Injection." Instead of asking the operating system to figure out where the audio goes (which fails because the Qualcomm UCM profiles are currently buggy), it tells the hardware exactly which gate to open and tells the software exactly which "sink" to pour the audio into.
  21. Salve Marcão, did you try this method? https://github.com/armbian/community/releases/ https://forum.armbian.com/topic/28895-efforts-to-develop-firmware-for-h96-max-v56-rk3566-8g64g/page/8/#findComment-187569
  22. Hello everyone, I would like to test Armbian on my GS King-X (S-922X). I have prepared a SD Card by using Armbian Imager. Then I have followed the instructions here: modified the "armbi_boot/extlinux/extlinux.conf" file, specified: "fdt /dtb/amlogic/meson-meson-g12b-gsking-x.dtb"; copied "u-boot-s905x2-s922" as "u-boot.ext". Now before trying to make the device boot from the SD Card, I would like to know: If I do not install Armbian to the internal eMMC, will I be able to boot back to Android, by just removing the SD Card and powering off then back on the device? Later, if I decide to install Armbian to a USB drive or an internal SATA Hard-Drive, will I be able to boot back to Android, or it will modify the boot loader in a way that it will not be possible? Thank you in advance
  23. Thank you for the support. I made a short break tinkering with the tv box, but recently I did try installing to emmc, using the install-aml.sh script. Everything working as expected. I should have been more careful in the first place. It was a good lesson anyway. Tnx
  24. @billymore I got this from AI. It's not perfect. I haven't done this before. To convert a standard Armbian root filesystem (typically an ext4 partition) into the rootfs.cpio.lzma.uboot format required for RAM booting, you must package the file tree into a CPIO archive, compress it with LZMA, and then wrap it with a U-Boot header. 1. Extract the Armbian RootFS First, you need the actual files from your Armbian image. Mount the image to a temporary directory on your Linux PC: mkdir -p /tmp/armbian_root If you have your Armbian .img file ready, run this command to find the start sector of the root partition (usually the second partition): fdisk -l armbian_image.img Multiply that Start number by 512 to get the exact offset for the mount command. sudo mount -o loop,offset=YOUR_OFFSET armbian_image.img /tmp/armbian_root A standard Armbian rootfs doesn't have an init file in the root directory; it uses sbin/init (a symlink to systemd). A RAM disk requires an executable at /init. sudo ln -s sbin/init /tmp/armbian_root/init 2. Create the CPIO Archive Pack the entire filesystem into a newc format CPIO archive. It is critical to perform this step as root to preserve file permissions. cd /tmp/armbian_root sudo find . | sudo cpio -H newc -o > /tmp/rootfs.cpio 3. Compress with LZMA Compress the archive using the LZMA algorithm to minimize its size for RAM loading: lzma -9 /tmp/rootfs.cpio # This creates /tmp/rootfs.cpio.lzma 4. Add the U-Boot Header Use the mkimage tool (from the u-boot-tools package) to add the 64-byte legacy header that U-Boot uses to identify the ramdisk. mkimage -A arm64 -O linux -T ramdisk -C lzma -n "Armbian Initramfs" -d /tmp/rootfs.cpio.lzma /tmp/rootfs.cpio.lzma.uboot -A arm: Target architecture (use arm64 if applicable). -T ramdisk: Identifies the image type as a RAM filesystem. -C lzma: Specifies the compression used. -d: Input data file. sunxi-fel -v uboot u-boot-sunxi-with-spl.bin \ write 0x40080000 Image \ write 0x4fa00000 dtbs/allwinner/sun50i-h313-tanix-tx1.dtb \ write 0x4fe00000 rootfs.cpio.lzma.uboot (Note: If you are using a raw Image instead of a uImage, use booti instead of bootm). Once U-Boot initializes over the USB cable, it will drop to a prompt. You must run this to start the OS: Armbian’s default kernel might not have a large enough ramdisk_size allocated in its config. Update your bootargs to include a size limit (in KB). If your rootfs is 500MB: setenv bootargs "console=ttyS0,115200 root=/dev/ram0 rw" booti 0x40080000 0x4fe00000 0x4fa00000 ramdisk_size=600000
  25. Netplan, like the whole systemd is the worst thing that ever happened to what we call "linux" overall. It was a dirty hack by canonical to overscript things and mantain a "foot in the door" to coerce users into a useless .yaml. A classic example of a solution in search of a problem that DID NOT EXIST. It's made with the same mentality of SYSTEMD by redhat, systemwide-cancer that was useless in its inception, just to make "a brand" and softly "vendor-lock" your product and give credibility - and make a lot of moooney - on HELPDESK SERVICES. But many years have passed and since nobody removes the crap, because "UBUNTU=LINUX" in peoples mind, and distros have adapted to it, since not many care about complex networking, it's just an icon flashing on their desktop, and most of the time it boils down to just make a laptop wifi work reliably (not as trivial as it seems). If you have to deal with a LOT of complex networking setups i.e. bridges, lot of network interfaces,VPNs, VLAN/VXLAN etc, those YAML scripts are just something you REALLY DO NOT WANT. Even the "ifupdown" route sometimes is not feasible, because systemd is such a systemwide-cancer that silently breaks things because you know, 1000000 lines of init code - that even spreads to your boot code in EFI environments - seemed such a GREAT idea to redhat, and it -incredibly- linux users swallowed this lump of sh*t like it was fine a chocolate cookie, I read people all the time in forums saying "ohhh it's SOO easy!". My advice: go Alpine Linux or OpenWRT or other similar "skeletal" distros to regain control of your network interfaces (and your system as a whole). It's a lost battle with anything netplan/systemd, you have to rely on a script that writes another script that get interpreted by another script and finally by another "black box" like systemd JUST TO do things like "echo <PARAMETER> > /sys/something". It's exactly what we needed, 3 or 4 more "abstraction layers" with 3 or 4 different syntax. It was obvious vendor-locking, but hey, let's jump into the bandwagon, because why not ? I'm pretty sure lots of people made a lot of money out of this, also.
  26. Thanks Nick for the reply and the explanation - Appreciate your assistance. I think this is where I'm facing the problem with the Armbian version I have found (vs. MiniArch) I don't know what exactly and where to write using sunxi-fel. For MiniArch, image builder for the TX1 explains to use the following commands to boot via FEL (but where it crashes): sunxi-fel -v -p uboot bootloader/u-boot-sunxi-with-spl.bin write 0x40200000 Image write 0x4fa00000 dtbs/allwinner/sun50i-h313-tanix-tx1.dtb write 0x4fc00000 load-kernel.scr While for Armbian, I don't know exactly what to send (except sending the bootloader u-boot which works but starts Android). @Nick A : you suggested a command: write 0x4ff00000 rootfs.cpio.lzma.uboot I understand that I should use this with sunxi-fel - but could you tell me more? Should I add it to existing Sunxi-fel command or? What is the purpose of this command?
  27. The Nanopi M4 (not V2) has only 2GB of RAM. It could also possible that my device has an other (or older) Android. And you have to use the HDMI port 1 in the "middle". Not the HDMI under the TF slot!
  28. I didn't notice it. I'm away from Home now. Will try to do some tests this weekend
