I've loaded Armbian onto my Udoo Dual and am having issues getting it past starting the kernel. I really like this OS on my other sbc's and have had no issues before this. I'm mostly a Linux noob with an elementary grasp of compiling the kernel. I have had this problem for about a week and am finally asking the pro's on how to fix this. Any help would GREATLY appreciated. Below is what I get from the U-Boot startup. Thanks!
U-Boot SPL 2015.10-armbian (Jun 13 2017 - 15:51:16)
U-Boot 2015.10-armbian (Jun 13 2017 - 15:51:16 +0200)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: POR
Board: UDOO DualLite
DRAM: 1 GiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
auto-detected panel HDMI
Display: HDMI (1280x720)
In: serial
Out: serial
Err: serial
Net: using phy at 6
FEC [PRIME]
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc
Found U-Boot script /boot.scr
** File not found /boot.scr **
** Unrecognized filesystem type **
1757 bytes read in 99 ms (16.6 KiB/s)
Running bootscript from mmc ...
## Executing script at 12000000
Booting from SD
** File not found /boot/armbianEnv.txt **
4765629 bytes read in 363 ms (12.5 MiB/s)
6234592 bytes read in 440 ms (13.5 MiB/s)
0 bytes read in 70 ms (0 Bytes/s)
37690 bytes read in 393 ms (92.8 KiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x5f21e0 ]
## Loading init Ramdisk from Legacy Image at 14800000 ...
Image Name: uInitrd
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 4765565 Bytes = 4.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800c339
Starting kernel ...
Question
Tyler Vaught
5 answers to this question
