Upcoming Events
Volunteering positions
Single board computer maintainer
Position: Board maintainerNumber of places: 64Applicants: 72
Chat | Social Media
#armbian at
irc.libera.chat or irc.oftc.net
Matrix or Discord
Mastodon | 𝕏 -
Popular Now
Activity Stream
257
Hello. I have x96q DDR3 v5.1 box. I flashed vontar h618 image with patched dtb. Everything seems fine except extended file properties. Docker need these properties to operate normally. Can you suggest image with extended file properties support for my box with working ethernet? -
11
Kali Linux as supported distro
Orange pi 5 wifi now supports injection mode using nexmon. Kali distro available from setup menu. -
12
Armbian Linux 6.6 (Ubuntu 24.04 Noble) Cubox server image doesn't boot
You don't have to run on bare-metal. A proper VM will do too and is probably the better solution. Yes. Cross-compiling is used for everything that's not native. You're aware that the command in the docs is just an example, right? -
1
working with the orange Pi 3B
Armbian does not come with some sort of admin console. Please elaborate. Try different patch cable. moved -
1
Cannot download images?
where exactly does this error show up? while downloading with your browser? while writing to the sdcard? while booting? Please elaborate. debug boot issues: https://debug.armbian.de
Member Statistics
