Chat | Social Media
#armbian at
irc.libera.chat or irc.oftc.net
Matrix or Discord
Mastodon | 𝕏 -
Activity Stream
10
Bridged AP does not work on BananaPiPro (Armbian_community_26.8.0-trunk.170_Bananapipro_trixie_current_6.18.35_minimal)
These error messages don't look good. Have you tried setting up and working with that wifi device alone (i.e. without all that bridging stuff)? This seems to me like a problem with either firmware loading for this adapter, or an unusable configuration, like unusable tx/rx power or channel for the specified region (e.g. if there has been no region code set for that interface). -
0
[Collabora] - From Apertis to SBOMs: Debian development at DebConf 2026
Next week we'll be in Santa Fe, Argentina, for DebConf 2026! Catch our 2 talks covering the latest Apertis developments and toolkits in Debian. View the full article -
0
[Armbian newsletter] - Github highlights
This week's updates center on expanded board support, Rockchip and Qualcomm platform maturation, and build system refinements. New hardware coverage grew across multiple SoC families, with the Lubancat 5IO (RK3588), KickPi K3B, Mellow Fly C5 3D printer board, and community support for the Orange Pi Zero 3W (Allwinner A733). The Arduino UNO Q advanced to mainline 7.1 on the edge kernel and gained desktop hardware acceleration via Mesa pinned to Trixie backports, while the BeagleY-AI received ISP, IMX219, and VPAC patches. Companion fixes addressed NVMe/SD boot conflicts on the NanoPi M6, Ethernet on the BigTreeTech CB1, and AIC8800 UART Bluetooth on Orange Pi A733 hardware. Rockchip work concentrated on the YY3588 and CM3588-NAS platforms, with device tree cleanups, a corrected HDMI-RX detect GPIO, and quieter DRM logging for dw-hdmi-qp and dw-dp bridges. Newer bl31, bl32, and DDR blobs landed for RK3576, and stale U-Boot was refreshed fleet-wide to resolve a SWIG build break. On the Qualcomm side, SC8280XP was refactored from a board to a family configuration, and the Radxa Dragon Q8B gained UFS image provisioning, QDL flashing support via the imager, and a mainline 7.1 edge target for the Q6A variant. Build and tooling improvements included a new show-extensions CLI command, a switch from the adduser suite to useradd/groupadd during first login, non-interactive Dpkg conffile handling in chroot, and clang compatibility fixes for carried Rockchip64 patches and SpacemiT RTL8852BS builds. The mainline kernel target advanced to 7.2-rc2, and MGLRU was enabled across sunxi, sunxi64, and sun60iw2 kernel configurations. #Armbian #EmbeddedLinux #Rockchip #Qualcomm #SBC ChangesAdd board: Lubancat 5IO (RK3588). by @lch08 in armbian/build#10029Add kickpi-k3b board and KICKPI vendor image. by @retro98boy in armbian/armbian.github.io#355Arduino UNO Q: bump edge kernel to mainline 7.1. by @SuperKali in armbian/build#10171arduino-uno-q: add BOARD_MAINTAINER, INTRODUCED, KERNEL_TEST_TARGET. by @igorpecovnik in armbian/build#10161arduino-uno-q: enable desktop hardware acceleration in Debian Trixie by pinning Mesa to trixie-backports. by @sdeleeuw in armbian/build#10160arm64: dts: rockchip: fix dynamic dclk for CM3588-NAS. by @rpardini in armbian/linux-rockchip#502arm64: dts: rockchip: overlay: yy3588: disable eDP overlay temporarily. by @SuperKali in armbian/linux-rockchip#509arm64: dts: rockchip: yy3588: drop non-existent SPI NOR flash. by @SuperKali in armbian/linux-rockchip#512arm64: dts: rockchip: yy3588: drop unused wifi_disable regulator. by @SuperKali in armbian/linux-rockchip#510BeagleY-AI Add Patches for ISP + IMX219 & VPAC. by @Grippy98 in armbian/build#10129Bigtreetech CB2: bump u-boot to 2026.04. by @JohnTheCoolingFan in armbian/build#10144boards/youyeetoo-yy3588: name audio outputs on pipewire too. by @SuperKali in armbian/build#10146cli: add show-extensions command to list extension hook points. by @iav in armbian/build#10023config: build and expose q8b UFS images on the debian:trixie base. by @SuperKali in armbian/os#478config: drop radxa-dragon-q6a from apps and community trixie base. by @SuperKali in armbian/os#479desktops: add libspa-0.2-bluetooth for OOB Bluetooth headphone audio. by @igorpecovnik in armbian/configng#948drm/bridge: dw-hdmi-qp: limit DDC i2c retries on NACK. by @SuperKali in armbian/linux-rockchip#513drm/rockchip: dw-dp: ratelimit AUX timeout logging. by @SuperKali in armbian/linux-rockchip#514feat(qdl): serve the board registry from the API. by @SuperKali in armbian/imager#163Feat: Add support for the Mellow Fly C5 3D Printer board. by @deece in armbian/build#9584feat: flash locally-built UFS images over QDL. by @SuperKali in armbian/imager#164firstlogin: use useradd/groupadd instead of the adduser suite. by @igorpecovnik in armbian/build#10127Fix ethernet on BigTreeTech CB1. by @JohnTheCoolingFan in armbian/build#10155fix(chroot): add Dpkg conffile options to prevent interactive prompts. by @Grippy98 in armbian/build#10134fix: stop setting LC_ALL in armbian-lang.sh. by @saschabuehrle in armbian/build#10132generate-build-lists: only gate manual runs on team membership. by @igorpecovnik in armbian/armbian.github.io#353jethome: fix jethub-burn extension: add BETA=yes support. by @adeepn in armbian/build#10152k3-beagle: fix malformed csi0-imx219 overlay patch (bad hunk count). by @igorpecovnik in armbian/build#10136kde-neon: switch to resolute base, then disable (broken). by @igorpecovnik in armbian/configng#949kickpik2b: Change vendor from SoC-level to board-level (KICKPI). by @retro98boy in armbian/build#10143mainline: bump to 7.2-rc2. by @EvilOlaf in armbian/build#10150Makena: add SC8280XP firehose and Radxa Dragon Q8B UFS provisioning. by @SuperKali in armbian/qcombin#3media: rockchip: hdmirx: quiet signal-not-lock polling spam. by @SuperKali in armbian/linux-rockchip#515Meson64: Update Waveshare CM4-IO-BASE-B DTS and add emc2305 fixups for driver to BLEEDINGEDGE branch. by @pyavitz in armbian/build#10169nanopi-m6: fix nvme prevents sd card from booting. by @efectn in armbian/build#10170orangepizero3w: Add community support for Orange Pi Zero 3W (Allwinner A733). by @shkolnik in armbian/build#10103Radxa Dragon Q6A: add mainline 7.1 edge kernel target. by @SuperKali in armbian/build#10162release-targets: add radxa-dragon-q8b with ufs extension. by @SuperKali in armbian/armbian.github.io#354rk3576: newer blobs bl31/bl32/ddr. by @rpardini in armbian/rkbin#49rockchip64: fix clang -Wincompatible-pointer-types-discards-qualifiers in carried patches. by @iav in armbian/build#10140rockchip64: yy3588: fix HDMI-RX detect GPIO to GPIO1_D5. by @SuperKali in armbian/build#10151rockchip: bump stale u-boot to fix the SWIG build break (fleet). by @igorpecovnik in armbian/build#10107SC8280XP: Initial refactor from board to family config. by @HeyMeco in armbian/build#9818SpacemiT: Add a current branch to the K3 and update K1 current kernel source URL. by @pyavitz in armbian/build#10138spacemit: rtl8852bs: guard GCC-only warning flags for clang builds. by @iav in armbian/build#10139sun60iw2: bring up AIC8800 UART Bluetooth on the Orange Pi A733 boards. by @shkolnik in armbian/build#10149sunxi, sunxi64, sun60iw2: enable MGLRU in kernel config. by @ValdikSS in armbian/build#10133sunxi: mellowflyc5: port U-Boot to v2026.07 & enable network boot. by @deece in armbian/build#10165Use relative symbolic links for some BSP files. by @retro98boy in armbian/build#10145View the full article -
0
[News from Armbian] - Github highlights
Member Statistics
