rino
25 -
Using stable after update/upgrade today, with 5.0.14-meson64, I lost audio on Le Potato
@ning It worked. Thanks. @AndrewDB So in the procedure for LePotato is enough to change: "$FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0" in: "python $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0" and so the produced "u-boot.bin.sd.bin" boots.
@AndrewDB Here the content of the fip dir: root@ubuntu-uboot-compilation:~/u-boot_dev/u-boot# $FIPDIR/blx_fix.sh fip/bl30.bin fip/zero_tmp fip/bl30_zero.bin fip/bl301.bin fip/bl301_zero.bin fip/bl30_new.bin bl30 2172+0 records in 2172+0 records out 2172 bytes (2.2 kB, 2.1 KiB) copied, 0.00474344 s, 458 kB/s 3228+0 records in 3228+0 records out 3228 bytes (3.2 kB, 3.2 KiB) copied, 0.00798341 s, 404 kB/s root@ubuntu-uboot-compilation:~/u-boot_dev/u-boot# ls -l fip total 876 -rwxr-xr-x 1 root root 944 Mar 10 17:54 acs.bin -rwxr-xr-x 1 root root 38336 Mar 10 17:54 bl2.bin -rwxr-xr-x 1 root root 1112 Mar 10 17:54 bl21.bin -rw-r--r-- 1 root root 38788 Mar 10 17:55 bl30.bin -rwxr-xr-x 1 root root 10084 Mar 10 17:55 bl301.bin -rw-r--r-- 1 root root 13312 Mar 10 18:00 bl301_zero.bin -rw-r--r-- 1 root root 54272 Mar 10 18:00 bl30_new.bin -rw-r--r-- 1 root root 40960 Mar 10 18:00 bl30_zero.bin -rw-r--r-- 1 root root 99120 Mar 10 17:55 bl31.img -rw-r--r-- 1 root root 577516 Mar 10 17:55 bl33.bin
@AndrewDB > By any chance are there any errors before you get to that point? At the first "make" I get 2 warnings: DTC arch/arm/dts/meson-gxbb-nanopi-k2.dtb DTC arch/arm/dts/meson-gxbb-odroidc2.dtb DTC arch/arm/dts/meson-gxl-s905x-p212.dtb DTC arch/arm/dts/meson-gxl-s905x-libretech-cc.dtb DTC arch/arm/dts/meson-gxl-s905x-khadas-vim.dtb arch/arm/dts/meson-gxl-s905x-khadas-vim.dtb: Warning (avoid_unnecessary_addr_size): /gpio-keys-polled: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property DTC arch/arm/dts/meson-gxm-khadas-vim2.dtb arch/arm/dts/meson-gxm-khadas-vim2.dtb: Warning (avoid_unnecessary_addr_size): /gpio-keys-polled: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
root@ubuntu-uboot-compilation:~# uname -a Linux ubuntu-uboot-compilation 4.15.0-46-generic #49-Ubuntu SMP Wed Feb 6 09:33:07 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Yes I have, always the same at the python compiled (.pyc) launch step: $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 the error says: /root/u-boot_dev/blobs/amlogic-u-boot/fip/acs_tool.pyc: line 1: $'\003\363\r': command not found if the python source was available we can have a look into ...
@AndrewDB Here it is my history file compile_history.txt
Hi @AndrewDB, in the attached file you can find what I get on the Le Potato UART console using your u-boot.bin.sd.bin. Other than that I re-execute the procedure and I got the same errors at the same point. However, ignoring the errors, and continuing I made an "u-boot.bin.sd.bin" file. But it doesn't work (flashing it no boot) and "diff" comand says it is different than yours. console.txt
What about the python source script of "acs_tool.pyc"? It could be named "acs_tool.py". Is that available?
@AndrewDB I think the file "fip/bl2_acs.bin" is missing
@AndrewDB I have an error during the integration of compiled blobs into the mainline u-boot code. root@ubuntu-uboot-compilation:~/u-boot_dev/u-boot# $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 /root/u-boot_dev/blobs/amlogic-u-boot/fip/acs_tool.pyc: line 1: $'\003\363\r': command not found /root/u-boot_dev/blobs/amlogic-u-boot/fip/acs_tool.pyc: line 2: $'\373]\372Uc\a@s*\002dd\001lZdd\001l\001Z\001dd\001l\002Z\001dd\001l\003Z\003dd\002l\004Tdd\001l\005Z\005dd\001l\006Z\006dd\001l\aZ\add\001l\bZ\bd\003Z': command not found : No such file or directorygic-u-boot/fip/acs_tool.pyc: line 3: de /root/u-boot_dev/blobs/amlogic-u-boot/fip/acs_tool.pyc: line 4: d d e : No such file or directory /root/u-boot_dev/blobs/amlogic-u-boot/fip/acs_tool.pyc: line 11: unexpected EOF while looking for matching ``' /root/u-boot_dev/blobs/amlogic-u-boot/fip/acs_tool.pyc: line 41: syntax error: unexpected end of file
Year needs to be changed in the nightly build name. For example: https://dl.armbian.com/lepotato/nightly/Armbian_5.68.180101_Lepotato_Ubuntu_bionic_dev_4.19.13.7z should be: ... 190101 ...
Accelerated 4K full-screen video in vlc on Armbian Bionic 4.19 beta image of Le Potato is working. How to get it: -install beta image: Armbian Bionic nightly mainline kernel 4.19.y -add desktop via armbian-config -install vlc: $ sudo apt-get install vlc -configure VLC: Tools > Preferences > Input / Codecs > Codecs > Hardware-accelerated decoding > VA-API video decoder Tools > Preferences > Video > Display > Output > X11 video output (XCB) -open a 4k .mp4 video and double click on it in order to get full-screen and enjoy the baylibre work on the open source graphic driver in the mainline 4.19 kernel
On bionic 4.19.12-meson64 #5.67.181226: $ xrandr -d :0 -q Screen 0: minimum 320 x 200, current 1920 x 1200, maximum 16384 x 8192 Composite-1 connected (normal left inverted right x axis y axis) 720x576i 50.00 720x480i 59.94 HDMI-1 connected 1920x1200+0+0 (normal left inverted right x axis y axis) 546mm x 352mm 1920x1200 59.95*+ (yes) 1920x1080 60.00 (yes) 1600x1200 60.00 1680x1050 59.88 (yes) 1280x1024 75.02 60.02 (HDMI only) 1440x900 59.90 (yes) 1280x960 60.00 1152x864 75.00 1024x768 75.03 70.07 60.00 832x624 74.55 800x600 72.19 75.00 60.32 56.25 640x480 75.00 72.81 66.67 Legenda of test result: (yes) means that HDMI to HDMI and HDMI to DVI both work (HDMI only) means HDMI to HDMI works no () means that HDMI to HDMI and HDMI to DVI both don't work. PS To change resolution from UART console I used for example: $ xrandr -d :0 --output HDMI-1 --mode 1920x1080
Other test performed. I am starting to understand better the "HDMI to DVI" working/not working laziness problem: HDMI to DVI works BUT, just after the boot, I have to move the mouse to wake up the monitor and get the desktop (I usually interact with the SBC via the uart console). That's with the last: ARMBIAN 5.67.181221 nightly Ubuntu 18.04.1 LTS 4.19.11-meson64
