denni_isl
  1. This is in /etc/dnsmasq.conf interface=eth0 # listen=192.168.4.1 dhcp-range=192.168.4.8,192.168.4.250,255.255.255.0,12h server=8.8.8.8 # domain-deeded bogus-priv sudo systemctl restart dnsmasq.service and sudo nmtui, edit connection, wired connection, edit ipv4 configuration, Manual (Shared) 192.168.4.1/24, ok
  2. Sharing is caring. Did finally manage to get this working. So lets make it simple clever. Actually i did this on a 64bit raspian light kernel 6.1 but it must be the same on Armbian 10 jan 24 Sharing the Raspberry Pi's WiFi over the ethernet port sudo apt get update && sudo apt install dnsmasq iptables iptables-persistent dhcpcd5 sudo vim /etc/dhcpcd.conf interface eth0 static ip_address=192.168.4.1/24 ------- sudo mv /etc/dnsmasq.conf /etc/dnsmasq.conf.bk sudo nano /etc/dnsmasq.conf - interface=eth0 dhcp-range=192.168.4.8,192.168.4.250,255.255.255.0,12h server=8.8.8.8 bogus-priv ------ sudo systemctl restart dnsmasq.service ------ sudo vim /etc/sysctl.conf net.ipv4.ip_forward=1 ------- sudo systemctl start dnsmasq ------- sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward" ------- sudo iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE sudo iptables -A FORWARD -i wlan0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT sudo iptables -A FORWARD -i eth0 -o wlan0 -j ACCEPT ------- sudo iptables -L -n -v ---------- sudo sh -c "iptables-save > /etc/iptables.ipv4.nat" --------- sudo vim /etc/rc.local iptables-restore < /etc/iptables.ipv4.nat exit0 --------- sudo reboot -------- Did get a perfect internet connection on odroid n2+ through eth0 - so the rpi4b is now supplying wifi for that board and providing petitboot with netbooting images through netboot_default after exit to shell.
  3. On odroid-n2+ and on the other machine - picocom -b 115200 -l -r /dev/ttyUSB0
