79 -
Profile Information
Gender
Male
Location
Italy
Interests
electronics , informatics
the two orange pi are powered separately, the microusb (otg) port is connected to the other's usb type A port with the modified cable and it works perfectly. I cannot tell you why, but I have only experimented.
@going reinstalled the new kernel (trunk) and thedtb you suggested via dpkg -i everything seems to work fine (docker, etc), but if from command line I use reboot at next session I can't log in via ssh ; only if I manually reboot I can log in with sshdmesg.txtsyslog.txti should still have an armbian image from a few years ago i will install that and disable updates is the 'only way i have to reuse orangepizero.🥲
@going armbian 24.2.1 jammy ,linux 6.6.20 current -sunxi ;utility is btop. here we go again this morning returned the 'error 😵💫 and I can no longer access OPzero I have also tried from another host computer.
I let speedtest run with iperf for about ten minutes maximum reached 82 Mibps so far everything is still working fine , I really think the problem was caused by a botched upgrade or with some bugs in the updated packages.
running for about 24 hours and under stress with 100% CPU now seems to be holding up( I have fan and ceramic heatsink but temperatures are always high)🥵
@robertoj, on the first ssh connection it asked me to delete the previous key and I did ,then it asked me for the password which I re-entered and it let me in. As far as docker is concerned it has duned very well for a few years with portainer, minidlna,a tor relay , and deluge;managing the reserved storage it always worked then something broke , maybe due to an upgrade , and problems arose. Now I installed this old version of armbian as suggested by igor and it seems to be working fine since 24 hours.
yes I reset the ssh password, but after a while it gave that error. now I have put this in for a few hours ,Armbian 24.2.1 Jammy with Linux 6.6.20-current-sunxi
Yesterday evening I installed Armbian_community_24.8.0-trunk.443_Orangepizero_noble_current_6.6.36.img.xz I checked the sha , installed on sd verbatim 32gb unpacked new. Installed docker, portainer and container minidlna . First startup without a hitch worked until this morning, then the strange error, some ports remain open ;now I rebooted repaired with fsck , it starts responding to ping and after a few minutes is no longer reachable. I would like to try booting via SD and put the operating system on an external HDD, if it is possible.
@robertoj i did as you said, reinstalled latest version of armbian on new sd and i get this error when accessing via ssh: kex_exchange_identification: read: Connection reset by peer Connection reset by.... 🥵
after several attempts with the serial the boot stops like this, I think there is some problem in the boot sequence but I don't know how to unlock it.
yes Sune, I tried with the 'serial adapter, but the console won't boot (connection parameters are correct)
hi wulfy23, the problem is that you cannot use the console because the operating system no longer starts. If I extract the sd card and read it from the computer though, I can see all the OS files.
good morning everyone, I installed Armbian 23.02.2 on orangepizero about a year ago without ever having a problem . Today it suddenly stopped booting and I can't get it to start again and that's what I'm interested in, also possibly to recover internal docker configurations. The orangepizero is powered by a 3A power supply under UPS and properly cooled, if I use the latest release on a new SD it works perfectly, so I think it is not a hardware problem. The SD with Armbian 23.02.2 is not corrupted and I can read every part of it. Does anyone know any tricks to get it running again?
Introduction to U Boot? /Lack of fundamental understanding
FRANK333 replied to dfgsdgdfgf's topic in Beginners
@mongoose I didn't understand the problem, but if you need help here is a tutorial on the orange pi zero. https://hackaday.io/project/181169-orange-pi-zero-native-network-boot/log/196475-step-2-enable-spi-flash-and-and-write-u-boot
