ChrisO
  1. Hi Armbian_25.5.1_Rpi4b_bookworm_current_6.12.28 broken after last upgrade. I run apt upgrade which installed kernel 6.18.10. It breaks ZFS. Provided ZFS version, 2.3.2, supports kernels up to 6.14. Don't forget a snapshot before "apt upgrade" ๐Ÿ™‚ Regards, Chris
  2. Thanks Igor. Just for reference, I also tried Armbian_community_26.2.0-trunk.332_Odroidhc4_forky_current_6.18.7_minimal.img apt update apt upgrade apt install linux-headers-current-meson64 apt install zfsutils-linux zfs-initramfs zfs-dkms zfs-zed Everything went fine and seams to working OK. Chris
  3. Thanks Werner and Gaetano I fear DIY an image exceeds my skils ๐Ÿ˜‰ I tried linux-headers-arm64. Result: kernel downgraded to 6.12 and wrong links in /boot: lrwxrwxrwx 1 root root 30 Dec 29 22:28 Image -> vmlinuz-6.18.2-current-meson64 lrwxrwxrwx 1 root root 27 Jan 23 13:27 uInitrd -> uInitrd-6.12.63+deb13-arm64 Corrected, built ZFS but at the end USB not working. It's not worth the hassle. I ended up installing Armbian_25.8.1_Odroidhc4_bookworm_current_6.12.41_minimal.img Everything seams OK, especially ZFS. Anyway, the link to Armbian_community_26.2.0-trunk.151_Odroidhc4_trixie_current_6.18.2_minimal.img is not there anymore ๐Ÿ™‚ Thanks for your time. Chris
  4. Hi I installed Armbian_community_26.2.0-trunk.151_Odroidhc4_trixie_current_6.18.2_minimal.img Trying to build zfs-dkms I discovered that I was missing the linux-headers for this kernel version and there is no package containing it. At least apt-cache didn't find anything. Any idea where to find it? Thanks, Chris
  5. Thank you very much! Regards, Chris
  6. Hi Wanted to try this Debian rolling release with Linux v6.18 from https://www.armbian.com/rockpie/ page, but both links there https://dl.armbian.com/nightly/rockpi-e/Forky_current_minimal https://dl.armbian.com/nightly/rockpi-e/Plucky_current_minimal lead to a 404 page on github.com. Thanks, Chris
  7. @laibsch, the answer to your question is in my last post. All those bad/"half-broken" adapters don't have problems with sequential writing/reading. And if you consider helpful pointing me to some obscure GUI writing tools as helpful, sorry, it's was not. I trust "dd" more then any of them. Very helpful was, however, @eselarm's post and I expressed my gratitude for it. To be honest, I don't really understand the intention of your last post. Could be my English is not good enough... Anyway, if my tone was was too harsh, I apologize for it.
  8. Hi Installed Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img and one of the USB-3 port, the top one, doesn't work. No reaction when inserting something, nothing in /var/log/syslog. The same with Armbian_25.11.1_Rock-5c_noble_current_6.12.58_minimal.img The Armbian_25.11.1_Rock-5c_trixie_vendor_6.1.115_minimal.img however is OK. What could be the cause of this problem? Thanks and regards, Chris
  9. Hi I have a Rock5c with a Penta SATA hat and it works OK. It is the only (?) way of having several disk connected to Rock5c. Note, it cannot boot of the disks on the hat. Have two SSDs and mirrored ZFS pool. No problems at all. Setting it up to act as Frigate server. The fifth SATA, in fact e-SATA connector comes very handy to connect a large disc for constant recording. You may also consider Odroid HC4. I think it's the cheapest solution and it's fan is negligible ๐Ÿ™‚ Have three of them, acting as mail/backup/HomeAssistant servers. Had in the past some problems with USB but recent kernels are OK. Hope it helps.
  10. Brillant, eselarm! I followed your suggestion to avoid USB-adapter issues and took my quite old laptop with a MCC/SD slot. Run fsck -fn /dev/mmcblk0p1 - no errors! As you suspected, the USB-adapter is at fault! I grabbed all SD-USB adapters I collected over the years and tried them. Different results, fsck without errors using few of them. My lesson lerned is: NEVER TRUST A USB-SD ADAPTER! The strange thing however is, that using this faulty adapter (14cd:1212 Super Top microSD card reader (SY-T18)) some images like Armbian_25.8.1_Rockpi-e_noble_current_6.12.41.img fsck'ed OK. I think all my adapters can cope w/o problems with simple, more or less sequntiell, reads/writes. It's what they do most of the time. I guess, when it comes to more complex I/O operations requested by fsck, some of them give out. What eselarm also suggested. Just for reference, the bad ones: 2 x 14cd:1212 Super Top microSD card reader (SY-T18) 5136:4678 Generic USB2.0 Device aaaa:8816 MXT microSD CardReader The OK ones: two with this inside: 090c:6200 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) microSD card reader and 14cd:127b Super Top SDXC Reader (very old, labeled hama) Thanks and regards, Chris
  11. I should have mentioned, I tried fsck on loop device and it was fine. It's what I cannot understand. In my script after writing the image I read it back and compare with the source: dd status=progress if=Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img of=/dev/sdc bs=1M conv=fsync 2032140288 bytes (2.0 GB, 1.9 GiB) copied, 79 s, 25.7 MB/s2034237440 bytes (2.0 GB, 1.9 GiB) copied, 79.2902 s, 25.7 MB/s Reading image from disk ... dd status=progress if=/dev/sdc of=Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img.from-disk bs=1M count=1941 2032140288 bytes (2.0 GB, 1.9 GiB) copied, 127 s, 16.0 MB/s They are equal in size. Produce same SHA hash: $ sha256sum Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img* ab74fc6f34f4f235ca224bc8d282feb1acf94cfe56bdf0b93c21894838ea0c71 Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img ab74fc6f34f4f235ca224bc8d282feb1acf94cfe56bdf0b93c21894838ea0c71 Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img.from-disk Tried also simple cmp on image file and SD card: $ sudo cmp Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img /dev/sdc cmp: EOF on Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img after byte 2034237440, in line 14175730 See, after byte 2034237440, so the 2034237440 bytes are equal on disk and on the SD card, .img is 2034237440 bytes of size: $ stat Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img File: Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img Size: 2034237440 Blocks: 1643993 IO Block: 131072 regular file $ sudo -fn /dev/sdc1 gives FS errors, hundreds of "Unattached inode" and such. Pass 5: Checking group summary information armbi_root: ********** WARNING: Filesystem still has errors ********** armbi_root: 64131/123136 files (0.1% non-contiguous), 441689/492539 blocks Voodoo? ๐Ÿ˜‰ A spare SD card anyone to try it: ๐Ÿ™‚
  12. This is really a strange question, Werner. fsck for filesystems like ext2/3/4 is for a purpose, no? But here you go. Normally when I install a new system, configure it to my needs and liking I make a backup image of it. To let say quickly restore after breaking the system with some "experiments" or such. Is much easier then install from scratch. As first step in this procedure i shrink the filesystem on the 1st partition which requires a fsck -f on it. Theodore's telling us to do so, he must know why ๐Ÿ™‚ So I discovered those two images I mentioned give me filesystem errors. As there is nobody in my neighborhood messing up with Armbian, I asked here for help. If somebody could try to see if he/she reproduced my problem. Instead I was instructed what tools are recommended (by whom?) and "scolded" for using fsck. ๐Ÿ™‚ BTW, after fsck lost+found contains several hundreds of files, most of them .c/.h from kernel source/headers. Thanks.
  13. I do verify what is written to the SD card. It's a homegrown script I have used for at least ten years. It's not the cause of my problem. And as for all those shiny clicky-clickity tools, no thanks! I prefer to know what is going on on my computer. Any comments on my question, anyone? If anybody could write one of the images using his his preferred/recommended imaging tool and run fsck on the resulting partition it would help me much. Thank you.
  14. Hi I dd the Armbian_25.11.1_Rock-5c_trixie_current_6.12.58_minimal.img to a SD card (/dev/sdc) and then run a fsck -f /dev/sdc1 and got errors: sudo fsck -f /dev/sdc1 fsck from util-linux 2.39.3 e2fsck 1.47.0 (5-Feb-2023) Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Entry '.' in ??? (1065) is duplicate '.' entry. Fix<y>? .... Tried few SD cards, same result. Tried those SD cards with other images, i.e. Armbian_24.8.4_Rock-5c_bookworm_vendor_6.1.75_minimal.img no problems. Could anybody verify this behavior? Thanks Chris Armbian_25.11.1_Rock-5c_trixie_vendor_6.1.115_minimal.img image generates the same problem.
  15. I started from scratch. Installed Armbian_25.2.2_Rpi4b_bookworm_current_6.12.15_minimal.img Having in mind what @eselarm suggested as culprit, I put raspi-firmware on hold root@rpi5b:~# apt-mark hold raspi-firmware then dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi4b-current apt --fix-broken install apt install armbian-bsp-cli-rpi4b-current everything OK apt upgrade everything OK Reboot root@rpi5b:~# uname -a Linux rpi5b 6.12.31-current-bcm2711 #1 SMP PREEMPT Wed Jun 4 14:00:53 UTC 2025 aarch64 GNU/Linux Tried the same with raspi-firmware unhold and got this . . Setting up raspi-firmware (1:1.20250430-1) ... ERROR: Unsupported kernel version (6.12.15-current-bcm2711) Setting up libraspberrypi0:arm64 (1:2+git20231018~131943+3c97f76-1) ... Setting up libraspberrypi-bin (1:2+git20231018~131943+3c97f76-1) ... Processing triggers for libc-bin (2.36-9+deb12u9) ... Processing triggers for man-db (2.11.2-2) ... Processing triggers for initramfs-tools (0.142+deb12u1) ... update-initramfs: Generating /boot/initrd.img-6.12.15-current-bcm2711 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152 W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152 ERROR: Unsupported initramfs version (6.12.15-current-bcm2711) I then did apt-mark hold raspi-firmware apt purge raspi-firmware and apt upgrade went through but the system is not in a good shape. root@rpi5b:~# uname -a Linux rpi5b 6.12.15-current-bcm2711 #1 SMP PREEMPT Wed Feb 19 13:49:50 UTC 2025 aarch64 GNU/Linux The /boot/firmware/initrd.img was not updated. Then I installed Armbian_25.2.4_Rpi4b_bookworm_current_6.12.22_minimal.img First thing after boot: root@rpi4b:~# update-initramfs -u update-initramfs: Generating /boot/initrd.img-6.12.22-current-bcm2711 ERROR: Unsupported initramfs version (6.12.22-current-bcm2711) The same with Armbian_25.5.1_Rpi4b_bookworm_current_6.12.28_minimal.img I don't have anymore a clean 25.2.3 but the homeassistant_minimal.img one has the same problem. No idea how to fix it. raspi-firmware has status optional and the 25.2.2 works OK without it, I think I will go this way hoping somebody with better skills then me will fix it one day. Regards, Chris
ร—
ร—
