SvenHz
  1. You could do a clean install.
  2. Hi all, just a quick note here that I am running 23.05 Bookworm successfully on Helios4 with ZFS. I did a clean install with a self-built image. Why the self-build? For two reasons: I wanted to have working fancontrol and that required the recent patch of @Heisath - https://github.com/armbian/build/pull/5392 I ran into an issue with not being able to install kernel headers (see below) so I needed to build an image with kernel headers built-in Build steps I wanted the release version so I did this in a clean build environment (WSL2 Ubuntu): git clone --depth=1 --branch=v23.05.2 https://github.com/armbian/build And then manually place this file in your local tree https://github.com/armbian/build/blob/main/patch/kernel/archive/mvebu-6.1/92-mvebu-gpio-remove-hardcoded-timer-assignment.patch. You need to touch .ignore_changes. Then run compile.sh INSTALL_HEADERS=yes. Testing After booting the image, I only did the following steps: systemctl disable helios4-wol # not sure why this service is failing but I do not use this anyway apt update apt upgrade reboot apt install zfs-dkms apt install zfsutils-linux Kernel header issue This is after apt update / apt upgrade / reboot. The repo seems to be out of sync. Also armbian-config fails altogether with a grep error (something with maximum count). root@helios4:~# apt search linux-headers|grep mvebu WARNING: apt does not have a stable CLI interface. Use with caution in scripts. linux-headers-current-mvebu/bookworm 23.02.2 armhf Linux kernel headers for 5.15.93-mvebu on armhf current linux-headers-edge-mvebu/bookworm 23.02.2 armhf Linux kernel headers for 6.1.11-mvebu on armhf edge root@helios4:~# uname -a Linux helios4 6.1.36-mvebu #2 SMP Wed Jun 28 11:12:41 CEST 2023 armv7l GNU/Linux root@helios4:~# cat /etc/armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=helios4 BOARD_NAME="Helios4" BOARDFAMILY=mvebu BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=961a103 VERSION=23.05.1 LINUXFAMILY=mvebu ARCH=arm IMAGE_TYPE=user-built BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage FORCE_BOOTSCRIPT_UPDATE=yes VENDOR=Armbian REVISION=23.05.1 BOOTSCRIPT_FORCE_UPDATE="yes" BOOTSCRIPT_DST="boot.cmd" root@helios4:~#
