ilmich
  1. Hi @n3o please don't say things I've never said. I won't do what you wrote. You are still free to use my (hard) work because I believe in healthy sharing, which is already the basis of my work on libreelec. Without @jock and @fabiobassa these boxes would not have this level of support. Cheers Michele
  2. @Benedito Portela in your dmesg i see [ 34.427778] dwhdmi-rockchip 200a0000.hdmi: failed to get edid [ 34.432114] dwhdmi-rockchip 200a0000.hdmi: failed to get edid [ 34.470696] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 34.470753] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 34.470795] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 34.470818] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 34.470842] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property [ 34.470865] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property Can you please indicate the model of the TV/monitor you are using?! The problem seems to lie in the edid. Some old tv's have edid with problems. It may also depend on hardware configurations, but I imagine that with the original firmware it works.
  3. Hi @n3o, are you using Windows? Linux ? OpenBSD? binary or compiled rkflashtool? This is because * on Linux maybe you don't have the right USB permission. You can switch to the super user account (super easy), or write an udev rule that chmod the USB node(easy if you know what are you doing) * my rkflashtool uses libusb which on Windows needs the generic USB driver called WinUsb. With Windows 7 you need to right-click and install this file https://raw.githubusercontent.com/ilmich/rkflashtool/master/rockwinusb.inf. With Windows > 7 there is no need to install a driver, but you need to associate the unknown device with the USB generic driver WinUsb (I'm not a Windows user so try starting reading this link https://github.com/libusb/libusb/wiki/Windows#user-content-How_to_use_libusb_on_Windows) * there is a bug on Windows (fixed with the latest alpha version) with multiple USB devices connected. Try, if you can, to have only the box connected with USB. About your experiments, you wrote a lot, but I'm sorry, I'm too lazy to read. So if I can give you some advice, format the internal storage and forget it. Write the Armbian version you like on the SD card and stop. This is because in addition to having a few problems, sd cards with 64/128GB are cheap and for Linux use are better than the 'little' 8 GB of internal storage that you often find in our boxes. Cheers Michele edit: rkflashtool is an external tool made with love by volunteers. Obviously, there is also the contribution of @jock and @fabiobassa, but for any problem with the tool, I ask you the courtesy of opening an issue here https://github.com/ilmich/rkflashtool/issues
  4. @TU-Student the reason why we often write .. read the first post .. is because someone has already wasted time and health trying to make everything work. The reason why some boxes do not boot from the sd card is because there is an old bootloader or one that does not activate the sd controller at the boot stage (often vendor's choice). So if you are unlucky, and multitool/armbian doesn't boot, the safest way is to delete the internal memory because in this mode (maskrom) the soc activates the sd card and starts the OS from there (99.9999999% of the time) If you need a backup (of a system that for me is unusable) you can use the USB OTG cable method (with tools like rkdeveloptool or my fork of rkflashtool) @fangis strange, the 6051p I think is the best supported chip. what's your problem?!
  5. Hi all, I'm not writing to ask for help, but only to share my experience, and to thank @jock for his work in allowing us to use linux with these boxes. My board is an android tv with soc rk3229/NAND/DDR3/Wifi SSV6051p which I'm using as a network appliance (pihole - simple nas - network web server). I followed the instructions in the first post and understood that the NAND is not supported, I preferred to empty it to avoid old bootloader problems and installed armbian bookworm on the SD card. The rest is linux... I installed the software I needed and now the box provides services for my home network without any problems (and I reused hardware that otherwise would have gone in the trash). Thanks again @jock and of course the armbian community Cheers Michele
