jmanes
  1. I am unfortunately seeing this instability even with the 1GB ethernet port... Not sure why. EDIT: Followed tweaks posted earlier, 1GB is now stable.
  2. @registr123 Ok we are on the same page then. I woke up this morning and saw my backup failed after around 20%, meaning it probably ran into a large file overnight. Now when it attempts to resume, it fails immediately on the same large file.
  3. Although SSH seems oddly unstable for me, I am noticing that my backups are no longer failing... so maybe that new firmware did fix something. @registr123 Did you run 'update-initramfs -u' after copying the firmware into the correct folder?
  4. @registr123 Same issue for me as of today. Sometimes SSH will cut out too if I just idle it, doesn't even require a large file transfer for me, with messages like so: Bad packet length 3617372545. ssh_dispatch_run_fatal: Connection to 10.0.0.10 port 22: Connection corrupted
