CeeGO
  1. Thanks. I'll have to look into that. I expect that's for customizing the packages installed?
  2. Looks good! Thank you. What's the best way to get start customizing the build?
  3. Great! Thank you. I will try it.
  4. Thank you for the reply and suggestion. I tried trixie and got the same error with the same patch. I guess I can't tell it to skip VP9?
  5. Hi, I'm trying to build for the Rock 3C so that I can minimize what goes into the kernel and system. I'm new at this and tried mostly default values (current, bookworm), except that I did minimal image instead of standard. The build failed at applying a patch. I don't know what to do with that. Can anyone help me diagnose? Also, how would I get into more details about building the image and choosing what to add/remove? Thanks!
  6. I noticed the BPI-M4 Zero is supported. It's the same SoC as the BPI-M4 Berry and mostly the same hardware (8GB eMMC, 2GB RAM). The main differences seem to be the ports. Is there a chance the image would work? Is the BPI-M4 Berry possibly going to get support?
