paradigman
Other groups
Support
3180 profile views
  1. I would like to use my device as a VPN client, i.e. connect to a remote OpenVPN server. How can I enable the Tun/Tap module on my board?
  2. I would like to use my device as a VPN client, i.e. connect to a remote OpenVPN server. How can I enable the Tun/Tap module on my board?
  3. Can someone help me how I can fix my kernel build system? Whatever image I flash on my board, the armbian-config -> "install kernel headers" function does not install everything needed to compile the kernel.
  4. @Jean-Francois Lessard : could you share with us the compiled objects (*.o) and the kernel object (*.ko)? I have been unable to compile kernel on armbian for a week because there is some general error at the system level (kernel headers).
  5. @Jean-Francois Lessard: First of all, I would like to thank you for your great work with the tm16xx display driver. I would like to ask for your help on how I can avoid the warnings below when compiling? scripts/Makefile.build:403: warning: overriding recipe for target 'built-in.a' Makefile:1168: warning: ignoring old recipe for target 'built-in.a' scripts/Makefile.build:418: warning: overriding recipe for target 'modules.order' Makefile:1848: warning: ignoring old recipe for target 'modules.order' scripts/Makefile.build:403: warning: overriding recipe for target 'built-in.a' Makefile:1168: warning: ignoring old recipe for target 'built-in.a' scripts/Makefile.build:418: warning: overriding recipe for target 'modules.order' Makefile:1848: warning: ignoring old recipe for target 'modules.order' scripts/Makefile.build:403: warning: overriding recipe for target 'built-in.a' Makefile:1168: warning: ignoring old recipe for target 'built-in.a' scripts/Makefile.build:418: warning: overriding recipe for target 'modules.order' Makefile:1848: warning: ignoring old recipe for target 'modules.order' scripts/Makefile.build:403: warning: overriding recipe for target 'built-in.a' Makefile:1168: warning: ignoring old recipe for target 'built-in.a' scripts/Makefile.build:418: warning: overriding recipe for target 'modules.order' Makefile:1848: warning: ignoring old recipe for target 'modules.order'
  6. For some reason I can't install the kernel headers in the latest minimal image. I tried the usual way with armbian-confi, but the modules build directory always remained empty. Where can I download the headers for the latest current image in .deb format?
  7. @dfahren : "it works like never before! Even Wifi and Bluetooth.". Please share with us this image. "how I can accelerate xfce desktop". I suggest to you try install cinnamon. With cinnamon you get wayland too... and probaly that will good.
  8. I'm curious when rolling images are expected to be made with kernel 6.10 or 6.12?
  9. @maka: "Success with amazingfate rockchip_ vdec2 activartion". Please describe the necessary steps for it. Also write down exactly which image you used. Thanks.
  10. @Hqnicolas there is problem with Mainline images above trunk 205. Those don't boot after flash mode v1.1.
  11. @Hqnicolas I tried flas to eMMc your POP OS images, but to the 4/32 don't able because too big the image for that eMMC, on 8/64 don't boot after flash. I tried with the v1.1 mode.
  12. Hi @Hqnicolas , I'm very interested in this "pop" image, but unfortunatelly the file is corrupt (and very large).
  13. I also want to try the latest images, but I don't see it described anywhere, which method should be used to flash either these special editions or the mainline images to the emmc?
  14. Could someone make an update image that already has Wayland pre-installed, with working acceleration?
  15. @Martynas Skapas : I have already played through this problem with another rockchip box. The problem there was that the manufacturer unexpectedly replaced the 6334 chip with the 2734C. Here is my post about it from the past: https://forum.armbian.com/topic/26978-csc-armbian-for-rk3318rk3328-tv-box-boards/?do=findComment&comment=143890
