ericde45
8 -
Asus Tinkerboard on kernel 4.4.213-rockchip bricked after shutdown
ericde45 replied to ericde45's topic in Tinkerboard
ok, thanks, i will follow the next steps on your link -
i flashed file Armbian_21.05.1_Tinkerboard_buster_legacy_4.4.213_xfce_desktop.img.xz to SD i booted and followed boot log through serial , log above i got the error : ** File not found /boot/dtb/rk3288-tinker-s.dtb ** so i get to the conclusion that the current 4.4.213 build for tinkerboard is broken. do you agree ? ---------------------------------------------------------------------------------------------------------- U-Boot 2018.11-armbian (May 06 2021 - 19:47:58 +0000) Model: Tinker-RK3288 DRAM: 2 GiB MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0 Loading Environment from EXT4... Card did not respond to voltage select! In: serial Out: serial Err: serial Model: Tinker-RK3288 Net: eth0: ethernet@ff290000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3395 bytes read in 1 ms (3.2 MiB/s) ## Executing script at 00000000 Boot script loaded from mmc 1 161 bytes read in 1 ms (157.2 KiB/s) 5829234 bytes read in 2450 ms (2.3 MiB/s) 8580280 bytes read in 3588 ms (2.3 MiB/s) ** File not found /boot/dtb/rk3288-tinker-s.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 286 bytes read in 1 ms (279.3 KiB/s) Applying kernel provided DT overlay rockchip-i2c1.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 286 bytes read in 1 ms (279.3 KiB/s) Applying kernel provided DT overlay rockchip-i2c4.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 311 bytes read in 1 ms (303.7 KiB/s) Applying kernel provided DT overlay rockchip-spi2.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 537 bytes read in 2 ms (261.7 KiB/s) Applying kernel provided DT overlay rockchip-spidev2.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 287 bytes read in 1 ms (280.3 KiB/s) Applying kernel provided DT overlay rockchip-uart1.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 287 bytes read in 1 ms (280.3 KiB/s) Applying kernel provided DT overlay rockchip-uart2.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Error applying DT overlays, restoring original DT ** File not found /boot/dtb/rk3288-tinker-s.dtb ** ## Loading init Ramdisk from Legacy Image at 21000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 5829170 Bytes = 5.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... starting USB... USB0: USB1: scanning bus 0 for devices... cannot reset port 1!? cannot reset port 3!? 5 USB Device(s) found scanning bus 1 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device ethernet@ff290000 Waiting for PHY auto negotiation to complete....... done Speed: 1000, full duplex BOOTP broadcast 1 BOOTP broadcast 2 *** Unhandled DHCP Option in OFFER/ACK: 125 *** Unhandled DHCP Option in OFFER/ACK: 125 DHCP client bound to address 192.168.1.113 (457 ms) *** Warning: no boot file name; using 'C0A80171.img' Using ethernet@ff290000 device TFTP from server 192.168.1.1; our IP address is 192.168.1.113 Filename 'C0A80171.img'. Load address: 0x800800 Loading: T T T T T T T T T T Retry count exceeded; starting again missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-2c-4d-54-42-b1-16 Speed: 1000, full duplex Using ethernet@ff290000 device TFTP from server 192.168.1.1; our IP address is 192.168.1.113 Filename 'pxelinux.cfg/01-2c-4d-54-42-b1-16'. Load address: 0x100000 Loading: T T T -
u-boot version 4.4213 once updated with apt-get install tries to find the file /boot/dtb/rk3288-tinker-s.dtb. It acts as the 5.9.14 version. if i copy /boot/dtb/rk3288-tinker.dtb to /boot/dtb/rk3288-tinker.dtb , yes ,it boots i will try another test : download current 4.4.213 version of armbian, and check it. before apt-get upgrade and after. -
i have 2 tinkerboard, one S and one not S. i have several SD cards with 4.4.213 and 5.9.14 how could i have done that ? you mean upgrading to 5.9.14 and downgrading to 4.4.213 ? i am not able to that i had issues with a small lcd panel with 5.9.14. so i made a lot of tests with 5.9.14 but never managed to have it work fine. so i reversed back to 4.4.213 but i only download ambian images, write them to SD or emmc, and then apt-get upgrade them. i am not good enough on linux kernel to try to make any change on them or something a bit 'clever' and how could my current working 4.4.213 version, just applying a apt-get upgrade, got some 5.9.14 update for u-boot ? what i find to be installed as u-boot packages before apt-get update are : linux-u-boot-tinkerboard-legacy/bionic,now 20.11.3 armhf [installed,upgradable to: 21.05.1] u-boot-tools/now 2019.07+dfsg-1ubuntu4~18.04.1 armhf [installed,upgradable to: 2020.10+dfsg-1ubuntu0~18.04.2] and after apt-get upgrade still on 4.4.213: linux-u-boot-tinkerboard-legacy/bionic,now 21.05.1 armhf [installé] u-boot-tools/bionic-updates,now 2020.10+dfsg-1ubuntu0~18.04.2 armhf [installé] -
so i made progress serial is working ont TTYS2 i mounted the SD card not booting as USB media. i have an error message saying : ** File not found /boot/dtb/rk3288-tinker-s.dtb ** in the dtb folder, i have no rk3288-tinker-s.dtb file i only have : rk3288-tinker.dtb on a working 5.9.14 kernal Armbian, i have in dtb folder : -rwxr-xr-x 1 root root 55821 déc. 11 22:00 rk3288-tinker-s.dtb on a working 4.4.213, on which i did not do an apt-get upgrade i have : -rw-r--r-- 1 root root 70323 Dec 11 21:57 rk3288-tinker.dtb and no -s command load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile} in boot.cmd might be the issue : it seems that "apt-get upgraded 4.4.13 kernel" finds my board to be a tinker-s, even it is not really a tinker-s the tinker i am testing on is not a tinker-s, no Emmcs on it. and the working 'not apt-get upgraded' 4.4.13 is a tinker-s but has only rk3288-tinker.dtb and is booting fine. copying rk3288-tinker.dtb to rk3288-tinker-s.dtb fixed the issue. and regarding third party software , i have none, i am running python scripts i wrote on this Armbian device. and Node.js running javascript. nothing that goes into U-Boot complete bootup text is : U-Boot 2018.11-armbian (May 06 2021 - 19:47:58 +0000) Model: Tinker-RK3288 DRAM: 2 GiB MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0 Loading Environment from EXT4... Card did not respond to voltage select! In: serial Out: serial Err: serial Model: Tinker-RK3288 Net: eth0: ethernet@ff290000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3395 bytes read in 2 ms (1.6 MiB/s) ## Executing script at 00000000 Boot script loaded from mmc 1 210 bytes read in 0 ms 7233242 bytes read in 319 ms (21.6 MiB/s) 8580280 bytes read in 378 ms (21.6 MiB/s) ** File not found /boot/dtb/rk3288-tinker-s.dtb ** libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 286 bytes read in 3 ms (92.8 KiB/s) Applying kernel provided DT overlay rockchip-i2c1.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 286 bytes read in 0 ms Applying kernel provided DT overlay rockchip-i2c4.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 311 bytes read in 1 ms (303.7 KiB/s) Applying kernel provided DT overlay rockchip-spi2.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 537 bytes read in 2 ms (261.7 KiB/s) Applying kernel provided DT overlay rockchip-spidev2.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 287 bytes read in 1 ms (280.3 KiB/s) Applying kernel provided DT overlay rockchip-uart1.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! 287 bytes read in 1 ms (280.3 KiB/s) Applying kernel provided DT overlay rockchip-uart2.dtbo No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Error applying DT overlays, restoring original DT ** File not found /boot/dtb/rk3288-tinker-s.dtb ** ## Loading init Ramdisk from Legacy Image at 21000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 7233178 Bytes = 6.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ERROR: Did not find a cmdline Flattened Device Tree Could not find a valid device tree SCRIPT FAILED: continuing... starting USB... USB0: USB1: scanning bus 0 -
and i dealt with my problem ! i avoid doing apt-get update for now and my system is up and running. but i also got back from storage an USB serial cable, and i will check serial communication using my second board and an SD running the same issue i had on the emmc version. and don't be condescendant, i am a 50 years old IT coder, since i am 11. i checked your link after i sent the answer, and what i provided is important. if users never come here to tell what's wrong, would you be able to find all issues by yourself ? -
the image i restore is a backup made using win32diskimager of my Tinkerboard Emmc done on 21 december 2020. information i can find are ( i just restored it once again right now ): Linux tinkerboardBuanderie4_4 4.4.213-rockchip #3 SMP Fri Dec 11 21:57:14 CET 2020 armv7l armv7l armv7l GNU/Linux Welcome to Armbian 20.11.3 Bionic with Linux 4.4.213-rockchip the apt-get upgrade says it can upgrade : The following packages have been kept back: armbian-config linux-bionic-root-legacy-tinkerboard sunxi-tools ttf-mscorefonts-installer The following packages will be upgraded: apt apt-transport-https apt-utils armbian-bionic-desktop armbian-firmware bind9-host binutils binutils-arm-linux-gnueabihf binutils-common ca-certificates chromium-browser chromium-codecs-ffmpeg-extra curl dirmngr distro-info-data dnsutils firefox ghostscript gir1.2-appindicator3-0.1 gir1.2-gst-plugins-base-1.0 gir1.2-gstreamer-1.0 git git-man gnupg gnupg-l10n gnupg-utils gnupg2 gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-pulseaudio hostapd initramfs-tools initramfs-tools-bin initramfs-tools-core iproute2 isc-dhcp-client libappindicator3-1 libapt-inst2.0 libapt-pkg5.0 libaudit-common libaudit1 libbind9-160 libbinutils libcaca0 libcurl3-gnutls libcurl4 libdjvulibre-text libdjvulibre21 libdns-export1100 libdns1100 libexiv2-14 libglib2.0-0 libglib2.0-bin libglib2.0-data libglib2.0-dev libglib2.0-dev-bin libgs9 libgs9-common libgstreamer-gl1.0-0 libgstreamer-plugins-base1.0-0 libgstreamer-plugins-good1.0-0 libgstreamer1.0-0 libhogweed4 libirs160 libisc-export169 libisc169 libisccc160 libisccfg160 libjavascriptcoregtk-4.0-18 libldap-2.4-2 libldap-common libldb1 liblwres160 liblz4-1 libmysqlclient20 libnettle6 libnginx-mod-http-geoip libnginx-mod-http-image-filter libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream libnss-myhostname libp11-kit0 libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g libproxy1v5 libpython2.7 libpython2.7-minimal libpython2.7-stdlib libpython3.6 libpython3.6-dev libpython3.6-minimal libpython3.6-stdlib libsasl2-2 libsasl2-modules-db libseccomp2 libsmbclient libssl-dev libssl1.0.0 libssl1.1 libsystemd0 libtiff5 libudev1 libwavpack1 libwbclient0 libwebkit2gtk-4.0-37 libx11-6 libx11-data libx11-dev libx11-xcb1 libzstd1 linux-dtb-legacy-rockchip linux-image-legacy-rockchip linux-libc-dev linux-u-boot-tinkerboard-legacy nginx nginx-common nginx-core openssl openvpn p11-kit p11-kit-modules python-apt-common python2.7 python2.7-minimal python3-apport python3-apt python3-httplib2 python3-problem-report python3-xdg python3.6 python3.6-dev python3.6-minimal samba-libs screen sudo systemd systemd-sysv tar tzdata u-boot-tools ubuntu-keyring udev wpasupplicant xdg-utils xserver-common xserver-xorg-core reading that, i have the feeling that not upgrading linux-bionic-root-legacy-tinkerboard might be in conflict with upgrading some other parts of the low level system such as linux-u-boot-tinkerboard-legacy ? currently my kernel packages are : root@tinkerboardBuanderie4_4:~# apt list --installed | grep -i tinker WARNING: apt does not have a stable CLI interface. Use with caution in scripts. linux-bionic-root-legacy-tinkerboard/bionic,now 20.11.3 armhf [installed,upgradable to: 21.05.1] linux-u-boot-tinkerboard-legacy/bionic,now 20.11.3 armhf [installed,upgradable to: 21.05.1] -
Hello, yesterday i got a powerloss , and my Asus tinkerboard got shutdown. i think i had some updates installed but not yet rebooted the Tinkerboard never restarted again. i first suspected a crashed Emmc disk but i did the following tests and got to the conclusion that Armbian for Tinkerboard is currently broken - restored a past complete image to either SD or Emmc : boots ok. - shutdown then unplug/replug power : OK - update with apt-get update + apt-get upgrade => reboot OK, but shutdown, and then never restart, bricked. shutdown down either with desktop or command line tested also with a second Tinkerboard with no Emmc, SD re-image from working backup, boot on SD : OK. apt-get upgrade. reboot : OK. shutdown => bricked. what can i check on my SD card ( i installed a Windows ext2/ext4 explorer) to correct the issue ?
