Howdy.
I m running a Helios64 on Armbian 21.02.1 Buster with Linux 5.10.63-rockchip64. I realise this is somewhat old, but it works for me.
I have been using MergerFS to present a big "vritual" storage area on my server:
jon@OXYGEN:~$ more /etc/fstab
UUID=a79a14c0-3cf4-4fb9-a6c6-838571351371 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
# "Disk 2" = /dev/sda3 = 8d360e1c-1908-4d8d-8289-2b1c83604950
UUID=8d360e1c-1908-4d8d-8289-2b1c83604950 /srv/mnt/disk2 btrfs defaults,noatime,nodiratime,nofail,subvol=@data 0 2
# "Disk 3" = /dev/sdb2 = eceee45f-5be5-48ba-a928-8f61686923b0
UUID=eceee45f-5be5-48ba-a928-8f61686923b0 /srv/mnt/disk3 btrfs defaults,noatime,nodiratime,nofail,subvol=@data 0 2
# "Disk 4" = /dev/sdc3 = 8ba04a0d-92eb-44e5-a4f0-99ebe2431b22
UUID=8ba04a0d-92eb-44e5-a4f0-99ebe2431b22 /srv/mnt/disk4 btrfs defaults,noatime,nodiratime,nofail,subvol=@data 0 2
# "Disk 5" = /dev/sdd3 = c3f0e61b-67af-4b35-acb8-e6698f8c9f64
UUID=c3f0e61b-67af-4b35-acb8-e6698f8c9f64 /srv/mnt/disk5 btrfs defaults,noatime,nodiratime,nofail,subvol=@data 0 2
# MergerFS - aggregate the mounted disks together
/srv/mnt/disk2:/srv/mnt/disk3:/srv/mnt/disk4:/srv/mnt/disk5 /srv/mnt/virtual fuse.mergerfs defaults,allow_other,use_ino,fsname=/srv/mnt/virtual 0 0
I have recently begun exporting this virtual disk via nfs. Nice! It relly is easy to set up, and it does "just work":
jon@OXYGEN:~$ more /etc/exports
/srv/mnt/virtual/oxygen/media 192.168.2.0/24(rw,sync,insecure,no_root_squash,no_subtree_check,nohide,fsid=0)
But, when my server is rebooted, the nfs-server.service fails to start:
_ _ _ _ __ _ _
| | | | ___| (_) ___ ___ / /_ | || |
| |_| |/ _ \ | |/ _ \/ __| '_ \| || |_
| _ | __/ | | (_) \__ \ (_) |__ _|
|_| |_|\___|_|_|\___/|___/\___/ |_|
Welcome to Armbian 21.02.1 Buster with Linux 5.10.63-rockchip64
No end-user support: work in progress
System load: 3% Up time: 9 min
Memory usage: 17% of 3.77G IP: 172.19.0.1 172.22.0.1 172.21.0.1 192.168.2.105
CPU temp: 43°C Usage of /: 41% of 15G
[ General system configuration (beta): armbian-config ]
Last login: Thu May 23 16:18:16 2024 from 1975:1976:1977:e00:dead:beef:0000:1111
jon@OXYGEN:~$ sudo service nfs-kernel-server status
[sudo] password for jon:
● nfs-server.service - NFS server and services
Loaded: loaded (/lib/systemd/system/nfs-server.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2024-05-25 15:36:31 NZST; 10min ago
Process: 1210 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=1/FAILURE)
Process: 1218 ExecStopPost=/usr/sbin/exportfs -au (code=exited, status=0/SUCCESS)
Process: 1219 ExecStopPost=/usr/sbin/exportfs -f (code=exited, status=0/SUCCESS)
May 25 15:36:31 OXYGEN systemd[1]: Starting NFS server and services...
May 25 15:36:31 OXYGEN exportfs[1210]: exportfs: Failed to stat /srv/mnt/virtual/oxygen/media: No such file or directory
May 25 15:36:31 OXYGEN systemd[1]: nfs-server.service: Control process exited, code=exited, status=1/FAILURE
May 25 15:36:31 OXYGEN systemd[1]: nfs-server.service: Failed with result 'exit-code'.
May 25 15:36:31 OXYGEN systemd[1]: Stopped NFS server and services.
Running "$ sudo service nfs-kernel-server start" manually, however, gets it going:
jon@OXYGEN:~$ sudo service nfs-kernel-server start
Active: active (exited) since Sat 2024-05-25 16:03:04 NZST; 1s ago
Process: 7428 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=0/SUCCESS)
Process: 7429 ExecStart=/usr/sbin/rpc.nfsd $RPCNFSDARGS (code=exited, status=0/SUCCESS)
Main PID: 7429 (code=exited, status=0/SUCCESS)
May 25 16:03:03 OXYGEN systemd[1]: Starting NFS server and services...
May 25 16:03:04 OXYGEN systemd[1]: Started NFS server and services.
So, to me, it seems that the MergerFS-provided "virtual" filesystem at /srv/mnt/virtual is not ready at the time that the NFS service is starting up.
Does anyone know:
1. whether I can modify the definition of the NFS Service, within systemd, so that it starts up later in the boot process? Am I able to define a dependency on some other filesystem service that has yet to be started?
2. whether I can define something else that gets kicked off late in the boot process, which simply attempts to restart the NFS Server service, in the hope that by this late stage in the boot process the MergerFS location is "ready"?
Many thanks,
Jon
