z28z34man
  1. Just an FYI i just tried it with a different armbian version and it works fine. it works with Armbian_25.5.1_Orangepi5-plus_bookworm_current_6.12.28_xfce_desktop.img it doesn't work with Armbian_25.8.1_Orangepi5-plus_trixie_current_6.12.43_xfce_desktop.img
  2. I know I am bringing this back from the dead but i am having issued getting wiringop-python installed. with the fallowing i was able to do a gpio readall echo "BOARD=orangepi5plus" | sudo tee /etc/orangepi-release but when i get errors from the sudo python3 setup.py install. (wiringpi_warp.c:3901:29: error: implicit declaration of function 'getGpioNum' [-Wimplicit-function-declaration]) # get the dependencies sudo apt-get update sudo apt-get -y install git swig python3-dev python3-setuptools # clone wiringOP-python repo, the branch should be "next" and NOT "main" or "master" git clone --recursive https://github.com/orangepi-xunlong/wiringOP-Python -b next cd wiringOP-Python git submodule update --init --remote python3 generate-bindings.py > bindings.i sudo python3 setup.py install is there a fix for this?
  3. never mind I started messing with options in my .desktop file an was able to get it to work.
  4. I have an orange pi 3 LTS running armbian 25.2 noble gnome that i installed an xfce4 desktop i am trying to autostart a remmina RDP session when a user logs in. I started by making a .desktop file in file in the home/(xxx user name xxx).config/AutoStart and making it executable. the .desktop file will run fine when ran manually but doesn't start on boot I then tried making a .service file in /home/(xxx user name xxx)/.config/systemd/user/ then doing a systemctl --user daemon-reload then doing a systemctl --user enable (my service name) when i do a systemctl --user start (my service name) it runs fine on reboot it fails and when i check the status by systemctl --user status (my service name) it comes back failed with can not open display as the fault. what should I try next
  5. For the RK dev tools from the Orange pi website you can change the language by going in to the config file and changing selected to 2 [Language] Kinds=2 Selected=2 LangPath=Language\
  6. this is what i currently have in /boot/armbianEnv.txt verbosity=1 bootlogo=true console=both disp_mode=1920x1080p60 overlay_prefix=sun50i-h6 rootdev=UUID=07b4bb7c-d23b-458d-b7cc-ede2328d23b0 rootfstype=ext4 overlays=uart3 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  7. i also tried changing overlay_prefix=sun50i-h6 to overlay=sun50i-h6 and it did not help. https://github.com/armbian/configng/issues/360
  8. The /boot/armbianEnv.txt file has overlay_prefix=sun50i-h6 in it. Is there anything else i need to check to make sure it loaded properly? I have done sudo apt update fallowed by a sudo apt upgrade last week.
  9. yes i did a sudo armbian-config then i selected System then i selected Kernel then i selected SYS210 Manage device tree overlays then i enabled sun50i-h6-uart3 then i rebooted.
  10. How do i enable UART 3 in an orange pi 3-LTS. i checked the /boot/armbianEnv.txt file and it has overlay_prefix=sun50i-h6. i then did a sudo armbian-config > System > Kernel > SYS210 Manage device tree overlays > enabled sun50i-h6-uart3 > reboot. after all that i am still only seeing ttys0 when i do a dmesg | grep tty
  11. i had the same issues i rolled back to Armbian_23.8.1_Orangepi5_bookworm_legacy_5.10.160_cinnamon_desktop.img
  12. I was able to get the EMMC back by using RKDevTool V3.5 and flashing one of orange pi's Linux images to it. The orange pi 5b manual has instruction for how to use RKDevTool.
  13. I have an orange pi 5b running Armbian_24.2.1_Orangepi5_bookworm_legacy_5.10.160_cinnamon_desktop on EMMC just fine. i wanted to try a newer version with hardware acceleration so i tried Armbian_24.11.2_Orangepi5_bookworm_current_6.12.0_cinnamon-backported-mesa_desktop. I edited the file in the boot folder and could see the EMMC on reboot. i did a sudo apt update and sudo apt upgrade. then an armbian-install to install it to the EMMC. it would not boot from the EMMC but i could at least still see it. Then i tried Armbian_24.11.2_Orangepi5_bookworm_vendor_6.1.75_cinnamon-backported-mesa_desktop and did the same but now i cant see the EMMC even with the original Armbian_24.2.1_Orangepi5_bookworm_legacy_5.10.160_cinnamon_desktop i had another orange pi 5b so i tried to do the same thing, but this time not do an update and upgrade before the armbian-install and again i cant see the EMMC. Is there anyway i can get the EMMC back. both of them run fine off the micro SD card but i prefer running off the EMMC if possible. I am assuming it may have corrupted the EMMC and when Linux boots it doesn't add the drive. Is there a way to manually add it after boot and reformat.
  14. Just incase someone is searching and this comes up i have it working just fine with the EMMC and i am not quite sure what i was doing wrong before. i just updated the armbianEnv.txt file then sudo armbian-install option 2 then option 5. this is with Armbian bookworm cinnamon.
  15. I have several orange pi 5B running Armbian Bookworm Cinnamon doing various task and they are working quite well. when i want to check up on a system that was booted without a monitor connected at boot time i get no video output on the HDMI. when reboot with the HDMI connected the HDMI outputs video just fine. Are there any settings i can change so the HDMI will output video if a HDMI monitor is connected it boots with no monitor connected
