bofibo
  1. I will show you how I successfully enabled pcie gen2 on my Rock Pi 4b and now my nvme is running at 1.1 GB/s. The solution which you can find on the web to activate pcie gen2 on an Armbian did NOT work for me: sudo nano /boot/armbianEnv.txt and insert: dtoverlay=pcie-gen2 The following solution activated pcie gen2: 0. check your current nvme speed to compare it afterwards with: sudo dd if=/dev/nvme0n1 of=/dev/null bs=1M count=2048 iflag=direct status=progress --> 618 MB/s 1. find out which rk3399-rock-pi-xxx.dtb your Rock Pi 4 is using. cat /boot/armbianEnv.txt | grep fdtfile --> fdtfile=rockchip/rk3399-rock-pi-4b.dtb --> In my example I will use rk3399-rock-pi-4b.dtb 2. make a backup of your *.dtb file sudo cp /boot/dtb/rockchip/rk3399-rock-pi-4b.dtb /boot/dtb/rockchip/rk3399-rock-pi-4b.dtb.bak 3. copy *.dtb to /tmp sudo cp /boot/dtb/rockchip/rk3399-rock-pi-4b.dtb /tmp/rk3399-rock-pi-4b.dtb 4. we need to make *.dtb into *.dts to edit it sudo dtc -I dtb -O dts -o /tmp/rk3399-rock-pi-4b.dts /tmp/rk3399-rock-pi-4b.dtb (4b). If you don't have dtc on rockpi than install it with: sudo apt-get install device-tree-compiler 5. edit *.dts sudo nano /tmp/rk3399-rock-pi-4b.dts search with [Ctrl + w] for the string: max-link-speed you will find something like this replace it with: save your file 6. turn *.dts into *.dtb sudo dtc -I dts -O dtb /tmp/rk3399-rock-pi-4b.dts -o /tmp/rk3399-rock-pi-4b.dtb 7. copy new *.dtb to /boot/dtb/rockchip sudo cp /tmp/rk3399-rock-pi-4b.dtb /boot/dtb/rockchip/rk3399-rock-pi-4b.dtb 8. give the file the same rights as before sudo chmod 0755 /boot/dtb/rockchip/rk3399-rock-pi-4b.dtb REBOOT Now check your vnme speed again and if everything worked you should see 1.0 GB/s [ ] sudo dd if=/dev/nvme0n1 of=/dev/null bs=1M count=2048 iflag=direct status=progress --> 2134900736 bytes (2.1 GB, 2.0 GiB) copied, 2 s, 1.1 GB/s """THERE WE HAVE THE SALAD""" """B0F1B0"""
